praegune kellaaeg 05.11.2026 14:11:29
Tomv
30.05.2008 20:14:14
VirtueMarti bug. Cannot use a scalar value as an array. |
Tere jälle,
Jooksutan virtuemarti uusimat versiooni (1.1.0) Joomla 1.5-el. Eile oli kõik normaalne, täna peale CHMODide muutmist hakkas iga leht, mis puudutas VirtueMarti loopima erroreid:
Warning: Cannot use a scalar value as an array in /htdocs/administrator/components/com_virtuemart/classes/ps_perm.php on line 86
Warning: Cannot use a scalar value as an array in /htdocs/administrator/components/com_virtuemart/classes/ps_perm.php on line 92
Warning: Cannot use a scalar value as an array in /htdocs/administrator/components/com_virtuemart/classes/ps_perm.php on line 93
Warning: Cannot use a scalar value as an array in /htdocs/administrator/components/com_virtuemart/classes/ps_perm.php on line 137
Warning: Cannot use a scalar value as an array in /htdocs/administrator/components/com_virtuemart/classes/ps_perm.php on line 139
Warning: Cannot use a scalar value as an array in /htdocs/administrator/components/com_virtuemart/classes/ps_perm.php on line 140
Warning: Cannot use a scalar value as an array in /htdocs/administrator/components/com_virtuemart/classes/ps_perm.php on line 141
Warning: Cannot use a scalar value as an array in /htdocs/administrator/components/com_virtuemart/classes/ps_perm.php on line 142
Warning: Cannot use a scalar value as an array in /htdocs/administrator/components/com_virtuemart/classes/ps_perm.php on line 143
Igal neist ridadest üritatakse muutujale $auth omistada mingit väärtust. Loogiliselt võttes peaks see error tekkima sellest, et varem on $auth muutujale antud mingi väärtus, mis pole array. Nüüd kui $auth['bla']-le üritatakse anda väärtust, hakkab php erroreid pilduma. On keegi VirtueMarti koodiga lähemalt tutvunud ning oskaks öelda kus sellele muutujale võiks väärtus olemas olla? Või miks tekkis probleem just peale chmodi muutmist (arvatavasti)?
Tegin virtuemartile reinstalli. Ei aidanud. Nii kui toote korvi lisasin, oli jälle kööga. Nüüd tundub et erroreid pillub vaid sisseloginud kasutajatele.
No mis jama on? Iga kord kui posti muuta tahan, pean selle kustutama ja uuesti lisama.
| Kommentaarid: 20 loe/lisa |
19 |
