Jah. Kindel on see, et kindel ei saa milleski olla, aga huvitav lugemine on. Paljud astronoomid usuvad, et pauk on sel korral ära käinud. Miski ei välista ka, et see ongi nimetatud tähe normaalne elutsükkel...
Särab ja paugutab vaheldumisi? _________________ Teie küsimused on vastatavad, kuid meie vastused on küsitavad.
IT uudissõnad. Pihuarvuti - pihkur, pihuarvuti kasutaja - pihkar.
Moevärvid on must minevik ja lilla tulevik.
Täht on taevas vahel heledam, vahel tumedam. Põletab ilmselt erinevaid kütuseid ja erinevad reaktsioonid tekitavad erineva tugevusega valgust.
Raivo Hein näiteks avastas ka kunagi oma piltidelt ühe tähe, mis oli kunagi päris tuhm, 2 aastat hiljem üpris ere.
NASA and SpaceX are targeting 8 a.m. EST, Sat., Jan. 18 for the In-Flight Abort Test. The launch window is four hours. This uncrewed test will demonstrate the Crew Dragon spacecraft's escape capabilities, showing that it can protect astronauts even in the unlikely event of an emergency during launch. Crew Dragon will lift off from Launch Complex 39A aboard a Falcon 9 rocket, then separate from the rocket after an intentionally triggered launch escape. Dragon’s drogue and main parachutes will sequence to provide for a soft landing in the Atlantic Ocean.
SpaceX is targeting Sunday, January 19 for an in-flight test of Crew Dragon’s launch escape capabilities from Launch Complex 39A (LC-39A) at NASA’s Kennedy Space Center in Florida. This test, which does not have NASA astronauts onboard the spacecraft, is intended to demonstrate Crew Dragon’s ability to reliably carry crew to safety in the unlikely event of an emergency on ascent.
The six-hour test window opens at 8:00 a.m. EST, or 13:00 UTC. A backup opportunity with the same six-hour launch window opening at 8:00 a.m. EST, or 13:00 UTC, is available on Monday, January 20.
Current weather data suggests our best opportunity for the launch escape test will be towards the end of the four-hour window, but we will continue to provide updates as new data becomes available.
19.01.2020 15:00-21:00 Eesti aja järgi või 20.01.2020 15:00-21:00. _________________ “Always remember that the crowd that applauds your coronation is the same crowd that will applaud your beheading. People like a show.” - sir Terry Pratchett
Purgis . _________________ “Always remember that the crowd that applauds your coronation is the same crowd that will applaud your beheading. People like a show.” - sir Terry Pratchett
Milliseid kütuseid veel peale vesiniku põletatakse? _________________ Teie küsimused on vastatavad, kuid meie vastused on küsitavad.
Mingil hetkel hakkab heeliumi põletamine pihta, pmst oli vist kuni rauani välja. Vaata wikist järgi. _________________ a.k.a Ummikummi
Kuni rauani jah, vist sõltuvalt tähe massist. Väiksemad rauani ei jõuagi vist.
Kõik mis elementide tabelis rauast kaugemal, sünteesitakse supernoovaplahvatustes.
__________________________
Oli õigesti meeles jah:
As a guideline, a star that has about one half the mass of the sun is too small and cool to fuse helium to carbon. So it will end up as a white dwarf made of helium. Stars between one half to four times the mass of the sun are massive and hot enough to fuse carbon to oxygen. Carbon and oxygen are fused more or less at the same time, and you’ll end up with a white dwarf made out of carbon and oxygen. I want to jump off topic here for a moment and ask a basic chemistry/physics question to all you readers. What happens when you introduce large amounts of heat and pressure to carbon? A girl’s best friend, diamonds!
The star has died and it’s a white dwarf made out of carbon: a giant diamond in the sky. Stars with masses greater than four times the mass of the sun are massive and hot enough to fuse oxygen to silicon. No, not the stuff they make implants out of, that’s “silicone” (sometimes, one letter can make a big difference).
Stars that have earned the title of “supergiant” are so massive and so hot that they begin fusing silicon to a solid core of iron. Once the star starts fusing iron, that’s it– it’s doomed. Fusing silicon to iron takes more energy than it gives off. This means that the star is going to die soon; it is causing its own death by using more of its own energy than it is getting back from nuclear fusion.
Ehk meie Päikesest saab kunagi suur teemant, raua põletamiseks peaks täht olema superhiidude klassist (alates 10 Päikese massi) _________________ Tee inimesele lõke ja tal on soe üheks päevaks, pista ta põlema ja tal on soe elu lõpuni. (Terry Pratchett)
poliitiline korrektsus - doktriin, mis on seisukohal, et sitajunni on võimalik end määrimata üles noppida, kui haarata selle puhtast otsast (lüh, Uncyclopedia)
SpaceX is targeting Tuesday, January 28 at 9:28 a.m. EST, or 14:28 UTC, for its fourth launch of Starlink satellites from Space Launch Complex 40 (SLC-40) at Cape Canaveral Air Force Station, Florida.
Falcon 9’s first stage previously launched Crew Dragon on its first demonstration mission in March 2019 and the RADARSAT Constellation Mission in June 2019. Following stage separation, SpaceX will land Falcon 9’s first stage on the “Of Course I Still Love You” droneship, which will be stationed in the Atlantic Ocean. Approximately 45 minutes after liftoff, SpaceX’s two fairing recovery vessels, “Ms. Tree” and “Ms. Chief,” will attempt to recover the two fairing halves.
Homme, 16:28 Eesti aja järgi. _________________ “Always remember that the crowd that applauds your coronation is the same crowd that will applaud your beheading. People like a show.” - sir Terry Pratchett
Pead kõigepealt oma asukoha määrama, siis saad sekundilise täpsusega ülelennuaja. StarLink satid on viienda tähesuuruse heledusega, seega linna valgusreostuses ei ole palja silmaga eriti näha.
Lift-off of the Birds Of A Feather mission occurred at 02:56 UTC on January 31 2019 from Rocket Lab Launch Complex 1 on New Zealand's Mahia Peninsula.
While Johnson and her cohort of “computers” didn’t get the recognition they deserved at the height of the space race, their work has become part of the mythos of American spaceflight. But their story is also an object lesson in how history is written—who is included and who is not.
Ilma nende naiste panuseta oleksid Neil Armstrong ja Buzz Aldrin jäänudki kuult naastes kosmosesse, suutmata koduteed leida. _________________ Müüa kõlarid on
