praegune kellaaeg 16.11.2026 14:02:33
TuleRebane
09.05.2008 15:24:28
WebcamMax send/don't send error. |
AppName: webcammax.exe AppVer: 3.0.0.0 ModName: vcamsrc.ax
ModVer: 0.0.0.0 Offset: 000012f0
Reporting details
This error report includes: information regarding the condition of WebcamMax Panel when the problem occured; the operating system version and computer hardware in use; your Digital Product ID, which could be used to identify your license; and the Internet Protocol (IP) adress of your computer.
We do not intentionally collect your files, name, address, email address or any other form of personally identifiable iformation. However, the error report could contain customer-specific information such as data from open files. While this information could potentially be used to determine your identify, if present, it will not be used.
The data that we collect will only be used to fix the problem. If more information is available, we will tell you when you report the problem. This error report will be sent using a secure connection to a database with limited access and will not be used for marketing purposes.
Milles asi? Infot raali kohta juurde vaja, siis andke teada.
14.05.2008 16:44:27
ja mure on milles?
_________________ - londiste
217 |
