alariv
08.03.2008 18:08:55
Arvuti teeb lambist resette |
Ei saa aru üldse, milles teema on, aga arvuti on hakanud juba mõnda aega tagasi lambist restarte tegema..
Error Signature:
BCCode : 1000008e BCP1 : C0000005 BCP2 : FA55F00A BCP3 : AD757A30
BCP4 : 00000000 OSVer : 5_1_2600 SP : 2_0 Product : 256_1
--------[ EVEREST Home Edition (c) 2003-2005 Lavalys, Inc. ]------------------------------------------------------------
Version EVEREST v2.20.405/ee
Homepage http://www.lavalys.com/
Report Type Quick Report
Computer COB-D4QL7V1JES6 (CoB)
Generator Childofbass
Operating System Microsoft Windows XP Professional 5.1.2600 (WinXP Retail)
Date 2008-03-08
Time 18:03
--------[ Summary ]-----------------------------------------------------------------------------------------------------
Computer:
OS Service Pack Service Pack 2
DirectX 4.09.00.0904 (DirectX 9.0c)
Computer Name COB-D4QL7V1JES6 (CoB)
User Name Childofbass
Motherboard:
CPU Type AMD Athlon 64, 1800 MHz (9 x 200) 3000+
Motherboard Name DFI nF4 Series
Motherboard Chipset nVIDIA nForce4, AMD Hammer
System Memory 512 MB (PC3200 DDR SDRAM)
BIOS Type Award (06/23/05)
Communication Port Communications Port (COM1)
Display:
Video Adapter NVIDIA GeForce 6600 (128 MB)
3D Accelerator nVIDIA GeForce 6600 PCI-E
Monitor Samsung SyncMaster 177N/710N/MagicSyncMaster CX701N/CX711N [17" LCD] (HMEXA14126)
Multimedia:
Audio Adapter Creative SB X-Fi [NoDB]
Storage:
IDE Controller NVIDIA nForce4 ADMA Controller
IDE Controller NVIDIA nForce4 Parallel ATA Controller
SCSI/RAID Controller D347PRT SCSI Controller
Disk Drive ST380011A (80 GB, 7200 RPM, Ultra-ATA/100)
Disk Drive WDC WD5000AAKS-65YGA0 (465 GB, IDE)
Optical Drive Generic DVD-ROM SCSI CdRom Device
Optical Drive LITE-ON LTR-52327S (52x/32x/52x CD-RW)
Optical Drive Optiarc DVD RW AD-7173A
SMART Hard Disks Status OK
Partitions:
C: (NTFS) 76308 MB (32837 MB free)
F: (NTFS) 476938 MB (185007 MB free)
Total Size 540.3 GB (212.7 GB free)
Input:
Keyboard Standard 101/102-Key or Microsoft Natural PS/2 Keyboard
Mouse PS/2 Compatible Mouse
Network:
Network Adapter NVIDIA nForce Networking Controller - Packet Scheduler Miniport (192.168.0.34)
Peripherals:
Printer \\UDO\Samsung SCX-4x16 Series
--------[ Sensor ]------------------------------------------------------------------------------------------------------
Sensor Properties:
Sensor Type ITE IT8712F (ISA 290h)
Temperatures:
Motherboard 43 °C (109 °F)
CPU 29 °C (84 °F)
North Bridge 46 °C (115 °F)
Seagate ST380011A 33 °C (91 °F)
WDC WD5000AAKS-65YGA0 34 °C (93 °F)
Cooling Fans:
CPU 680 RPM
Chassis 1688 RPM
Power Supply 3835 RPM
Voltage Values:
CPU Core 1.38 V
+3.3 V 3.36 V
+5 V 4.97 V
+12 V 12.16 V
+5 V Standby 5.03 V
VBAT Battery 3.10 V
Debug Info F F8 64 2C
Debug Info T 29 43 46
Debug Info V 56 49 D2 B9 BE 5D 9E (41) |
Toiteplokiks siis Fortron Blue Storm 500W
voldid ja temperatuurid tunduvad igati korras olevat...võtsin masinalt kella ka maha..ideid?
| Kommentaarid: 15 loe/lisa |
15 |
olc
08.03.2008 18:09:43
| midagi on katki äkki, mälu ja hdd test oleks abiks
130 |
janek87
08.03.2008 18:10:05
| Viimasel ajal midagi installinud? Kuidas voolukõikumistega on?
alariv
08.03.2008 18:12:13
| olc kirjutas: |
| midagi on katki äkki, mälu ja hdd test oleks abiks |
kas see BIOSe memtest86 on objektiive? tead?
| janek87 kirjutas: |
| Viimasel ajal midagi installinud? Kuidas voolukõikumistega on? |
installin kogu aeg midagi, see ei tohiks segada..voolukõikumisi kahtlustan ise ka, aga kas fortron ei peaks pisematega ise hakkama saama?
või on lihtsalt siin elektrisüsteemiga midagi korrast ära ja peab UPSi poole vaatama?
15 |
XYZ
08.03.2008 19:27:01
| UPS ei tee kahju vaid nii mõnigi kord päästab arvuti
| Kommentaarid: 81 loe/lisa |
12 :: |
56 |
est4ever
21.03.2008 00:55:16
| põhjuseid võib erineviad olla.. võib toide olla pihta saanud mõne kõikumisega või lähevad kuskil pinged üles..mem test (nagu ka eespool soovitatud) ei teeks tõesti paha, kui muu enam ei aita, tee format ka igaks juhuks ja võta 10 ks sekiks biosi patarei välja, kui mõni kala on, siis see peaks resettima need.. igatahes katseta kõikvõimalik lihtsam enne läbi kui raha investeerima hakkad, aga ups ei tee jah kunagi paha
| Kommentaarid: 91 loe/lisa |
85 |
Kalle
21.03.2008 15:35:20
error code viitab:
1. Motherboard or BIOS or some other hardware related incompatibilities
2. A memory access violation occurred.
Kui memtest86 ei näita, et mõni mälu on vigane (arvan, et siia see koer maetud ongi) siis vaata edasi, kas on saadaval BIOS'i uuendus ja raudvara driverite uuendus.
kas see BIOSe memtest86 on objektiive? tead? - see ei ole mitte BIOS'i memtest86 (BIOS'i testimisega pole siin midagi ühist) vaid testib sinu masinas olevat RAM ning siiani on 1 objektiivsemaid mälu testimise programme. Tean !
Tiri kodulehelt kas floppy või CD versioon ja edasi käitu nagu seal juhistes kirjas.
| Kommentaarid: 4 loe/lisa |
az
24.03.2008 19:20:35
mul sama jama oli, et tegi ise restarte ja selgus, et mälu oli vigane, peale mäluvahetust see jama kadus
_________________ ??? |
| Kommentaarid: 21 loe/lisa |
19 |
