peeter90
12.03.2008 19:17:32
"Obatain DNS server address automatically" probleem. |
| Probleem selles, et sülearvuti (Dell XPS M1330, Vista HP) ei taha DNS serveri aadressi ruuterist kätte saada. Olen proovinud nii wifi kui ka LAN kaudu ja mõlemal juhul on sama tulemus. Kui ma kodus manuaalselt DNS seadistan, siis töötab internet ideaalselt, kuid "Obtain DNS server address automatically" puhul näitab Local Area Connection details alt, et IPv4 DNS Server on 192.168.1.1. Olen proovinud drivereid uuesti installida, kuid ikka ei aita.
| Kommentaarid: 4 loe/lisa |
Dijital
| Kommentaarid: 41 loe/lisa |
peeter90
12.03.2008 19:46:21
| Ruuteris on DNS paigas. Teised lauaarvutid ja sülearvuti(HP NC6120) saavad ilusti DNS automaatselt kätte. Olen proovinud enda arvutit mitme erineva ruuteriga ning sama probleem.
tommionu
tubli telepoiss
12.03.2008 20:17:31
ei ole küll vista kasutaja, aga olen kuulnud, et vistal on nö vaikimisi mõlemad IPv4 kui ka IPv6 kohe aktiiviseeritud ja kui nüüd tiba googel'dada, saab sellise tulemuse:
Note: Due to misconfigured DNS servers on the Internet, computers that use both IPv4 and IPv6 might not be able to resolve names and connect to Internet resources. This rare problem occurs when a misconfigured DNS server receives a request to resolve a name to one or more IPv6 addresses (a request for AAAA records). If the DNS server does not support IPv6, the name query fails. The querying node then sends a request to resolve the name to a set of IPv4 addresses (a request for A records). The misconfigured DNS server drops the subsequent DNS query for IPv4 addresses and the entire name resolution attempt fails, resulting in impaired network connectivity for the requesting node. If you are experiencing this problem, ask your Internet service provider to reconfigure their DNS server to accept the subsequent DNS query for A records after failing the DNS query for AAAA records. Alternately, you can temporarily disable IPv6 on the requesting computer. This issue exists on the DNS servers and is common to all computers that use both IPv4 and IPv6.
allikas:
http://technet.microsoft.com/en-us/library/bb878121.aspx
link lisaks, kust selle eelmise lingi sain:
http://forum.notebookreview.com/archive/index.php/t-129103.html
kokkuvõte lühidalt, kui IPv6 ei kasuta, disable see.
Google - see on imelihtne
| Kommentaarid: 39 loe/lisa |
37 |
peeter90
12.03.2008 21:11:06
| Proovitud, ei aita.
tommionu
tubli telepoiss
37 |
jonnipunn
| Kommentaarid: 24 loe/lisa |
24 |
peeter90
13.03.2008 19:02:01
IPv6 disable tegin täpselt nii, nagu seal MS lehel ja see teine registri muutmine kah ei aidanud. Kahtlen, et asi Vistas on, sest sõbra laptop(Vista HP) saab DNS kätte ja sama probleem esineb veel ühel Dell D820, millel on XP Pro SP2.
EDIT: Niisiis probleem lahendatud. Aitas see, kui lülistasin välja IPv6 Network Connections kaudu, ehks sealt iga ühenduse properties alt linnuke Link-Layer Topology Discovery Mapper I/O, Link-Layer Topology Discovery Responder ja TCP/IPv6 eest ära võtta. Tänud kõigile, kes aitasid.
