praegune kellaaeg 24.10.2026 09:18:53
vill147
24.02.2008 16:37:49
Kuhu panna PS CS3 pluginid? |
Sain internetist PS CS3 me pluginite collektioni. Üks suur fail, umbes 400 mega. Faili laiend on .uif Kuidas ja kuhu ma selle siis nüüd panen, et PS ta ära tunneks? PS-il endal on plug-ins -ide kataloog küll olemas, aga seal on sees veel 11 folderit ja nende failide laiendid on hoopis teistsugused. (8Li, 8bf jms). PS-ist endast ka sellist kohta ei leidnud, et ....install plugin vms.
Tegemist siis win XP-ga, ning PS CS3 Extendiga.
| Kommentaarid: 7 loe/lisa |
punktiir
24.02.2008 17:05:43
Extension: UIF
Magic ISO Universal Image Format File
MagicISO is a CD/DVD image file creating / editing / extracting tool. It can open / create / edit / extract CD/DVD image files, and it can convert bin to iso and back. Universal Image Format (UIF) is a compression image file format for backing up CD/DVDs. MagicISO has a freeware program called MagicDisk that can open UIF files on Windows computers. A UIF file on a Macintosh should be handled like a DMG file.
| Kommentaarid: 49 loe/lisa |
38 |
vill147
24.02.2008 17:53:57
| to-punktiir; Tänud, sain hakkama. Lihtsalt ei tulnud selle peale, et toppida see uif googlesse; mõtsin et see on mingi PS-i enda failiformaat.
