uus teema   vasta Hinnavaatlus »  Sülearvutid »  HP pavilion dv6000 audio draiver märgi kõik teemad loetuks
HNS
HNS
sõnum 20.02.2008 12:41:39 HP pavilion dv6000 audio draiver vasta tsitaadiga
tere
downgradesin pealkirjas nimetatud läpaka mudeliga dv6225eu Vistalt XP' peale.
kõik draiverid olen tööle saanud, ainult audio ei hakka tööle ja ka need soundi ja muu meedia nupud.
olen proovinud mingi 15 erinevat draiverit hp kodukalt, no luck.
äkki on kellelgi esinenud sama probleem.
proovisin ka seda varianti, aga mul ei näita device manageris "Audio device on High Definition Audio Bus"
To install audio / modem drivers, first download and install Microsoft Universal Audio Architecture (UAA) Bus driver from the following link:
ftp://ftp.hp.com/pub/softpaq/sp33501-34000/sp33566.exe
Now, download and install the audio driver from the following link:
ftp://ftp.hp.com/pub/softpaq/sp34001-34500/sp34204.exe (UAA Driver needed)
This will create a swsetup folder in C drive
Installing this driver may result in an error. But continue with the following steps to get the audio driver installed correctly.
1. Click on Start and select Run. Now type devmgmt.msc and press enter.
2. Right click on "Audio device on High Definition Audio Bus" and click Update driver.
3. Select "Install from a list or specific location"
4. Click Next. Then select "Don't search, I will choose the driver to install"
5. Click Next and then select "Sound, video and game controller" from the list.
6. Click Next and then click Have Disk.
7. Click Browse C:\sp34204 folder and select the .inf file and click open and Continue with the onscreen instructions.
est4ever
est4ever
sõnum 20.02.2008 12:49:41 vasta tsitaadiga
mul oli 6315ea ga sama kamm..lõpuks sain mingi teise firma draiveriga tööle, aga heli pole hoopiski nii hea kui vista all õige draiveriga..need läpparid vist lihtsalt vista jaoks tehtud rohkem nigu
HNS
HNS
sõnum 20.02.2008 13:03:33 vasta tsitaadiga
aga vista on saast. äkki leaid selle draiveri nime mida kasutasid?
est4ever
est4ever
sõnum 20.02.2008 13:22:41 vasta tsitaadiga
raske juhus, võin otsida, aga eriti ei luba, see oli tükk aega tagasi. mul küll vistaga pretensioone pole
rundll
rundll
sõnum 24.02.2008 16:35:05 vasta tsitaadiga
HNS kirjutas:
hmm...julge avaldus. siiski maitse asi.
vistalt xp-le minejatel üldse päris palju probleeme. paljusid on aidanud see et tööle hakkavad sama seeria vanemate mudelite ajurid (driver), ükskõik mis seadme puhul siis. tasub proovimist
HNS
HNS
sõnum 24.02.2008 20:29:42 vasta tsitaadiga
rundll kirjutas:
HNS kirjutas:
selge. proovin kindlasti.
ja vista kohapealt oli see lause suht vihahoos kirja pandud. tegelikult ikka nii hull ka ei ole. icon_smile.gif
sõnum 26.04.2008 15:12:27 vasta tsitaadiga
https://foorum.hinnavaatlus.ee/viewtopic.php?t=366685&highlight=pavilion+audio
