sõnum |
R A T
06.02.2008 09:30:30
Relee kontroller LPT porti |
Tere,
Juba pikemat aega uurin netist õpetust, kuidas teha releede kontrollerit LPT porti.
Mida see teeb? Põhimõtteliselt lülitab erinevaid vooluvõrke sisse ja välja.
Vaata SIIT näidet mis sellega teha saab.
Antud lehel on kasutatud kontrollerit valmistootena.
Kuid plaan on taoline karbike ise valmis treida.
Siin pilt ka valmistootena ostetavast kontrollerist:
Üks kõige konkreetsemaid õpetusi, mis olen leidnud, asub siin.
Põhimõtteliselt on tegu väga lihtsalt tehtava asjaga.
Kuid kuna minu teadmised elektroonika vallas pole just kõige mahukamad, siis komponentide ostmisega tekib mul probleeme.
Kui ma õigesti aru saan, siis on 220v ja 12v vooluvõrkude jaoks erinevad releed (neid releesid on üldse nii, et tapab).
Peale selle tuleb LPT pordist nõrka voolu, oleks vaja releesid mis suudaksid selle peal ennast lülitada. (LPT pordi infoleht on koduarvuti favorites, ei saa praegu linkida)
Siit ka esimene probleem, ma ei oska õigeid releesid valida
Natuke infi releede kohta:
tsitaat: |
CARLS ELECTRONICS
http://www.electronickits.com
Relay Contact Information:
Relay contacts on most of our kits and in the industrial world are labeled with NO (Normally Open), NC (Normally Closed), and C (Common). These labels and the function of the relays seems to cause a great deal of confusion among people, however once you understand the meaning it is quite simple and literal.
The first thing you need to know is that a relay contact is a switch, nothing more, nothing less. It does not provide power; it simply opens and closes an electrical circuit, just like the light switch on a wall. When the relay is de-energized or turned off there is an electrical connection between NC and Common, hence normally closed. In the off state there is not a connection between NO and common, hence normally open. When the relay is energized or turned on the NO and C make an electrical connection, and the electrical connection between NC and C is removed.
Here is a sample of connecting a simple 110 VAC light to a relay so that it will turn on when the relay is energized. Wire the hot 110VAC to the Common (C), Normally Open (NO) to hot side of the light bulb, Neutral from the light bulb to the neutral of the 110VAC wiring. Now when the relay is energized the NO will close connecting to the C and allowing power to flow through the bulb.
The last issue is voltage and current ratings. A typical relay rating will be 24VDC @ 5 Amps, 110VAC @ 10 Amps, 220 VAC @ 5 Amps. This is simply telling you the max amperage that the relay contacts can handle at the voltage you are using. For example a 100 Watt light bulb is going to be about 100 VAC @ 1 Amp. This is 9 Amps below the rating, so the circuit can handle turning on an off the light bulb with no problem.
Kui nüüd idee poolest detailsemaks minna, siis tahaks teha universaalset boxi, millel saaks releesid vahetada vastavalt vajadusele. (Kuigi pesadega vist lähe veidike kallimaks). Peale selle tahaks ka natuke keerulisemat asja. Main Switch, mis vahetaks releelülituse ja koguaeg väljas olemise vahele.
Samas oleks võimalik kasutada NC releesid, et siis arvuti kinnioleku ajal oleksid kõik vooluringid sisse lülitatud. Samas arvuti käimasoleku ajal kasutataks koguaeg voolu asjade käimashoidmise jaoks, mis võib mõttetu energiakulu olla.
Idee selle tegemiseks tekkis peale seda, kui sain eriti ereda LED taskulambi, mille nuppu kiiresti vajutades avastasin, et see on sama ere kui strobo.
Kuna ka muusika toas pea põhjas oli, vilgutasin selle taktis. Edasi arenes idee, et võiks muusika järgi reageeriva programmi kirjutada ja arvutiga lülitusi teha
Kuna aga LPT pordilt saab 8 väljuvat signaali, siis saaks variandiga tervet valgusshowd juhtida (nagu ka sellelt halloweeni lehelt näha oli).
Lisaks sellele saaks juhtida arvutist lampe, koduelektroonika jmt. Lülitusi saaks teha nii hiire, klaviatuuri, puldi, mobiili, üle veebilehe ja variante on veelgi, vaid koodikirjutamise vaev
Et siis, kellel antud vallas teadmised, kas siis analoogse valmistehtud karbi näol, või lihtsalt 5+ teadmised elektroonikas - Aidake
_________________ Jogani pogani pooh |
wicked
06.02.2008 11:26:04
R A T: Muide - ei pea ilmtingimata olema releed, millega midagi sisse-välja lülitad On veel olemas ka kõikvõimalikud "lülitustransistorid, türistorid" jms.
Relee puhul pead jälgima 2-e lihtsat asja:
1. Relee enda juht- ehk lülituspinge. Tavaliselt 5-24V, sõltuvalt tüübist.
2. Pinge või vool, mida võib rakendada relee kontaktidele.
NB! Ja kui on tegu kõrgete pingete ja vooludega (näiteks 220V 1kW), siis on palju mõistlikum kasutada juba seadet nimega "Kontaktor" (sellised suured klotsid, mida näiteks elektrikilpides kasutatakse). Ja Kontaktorit lülitab sisse-välja kas siis relee või lülitustransistor mis saab oma juhtsignaali kas lülitist, LPT-st...
On muidu ka olemas Kontaktoreid, mida saab ka "väikevooluga otse juhtida", aga sellist pead siis andmete järgi otsima.
R A T
06.02.2008 20:15:31
Mul on häbi tunnistada, et tegelt ma olen suht suures mahus saanud elektroonika koolitust ja ma peaksin vabalt oskama lugeda skeeme ja kõigest täielikult aru saama (diplomid näitavad ka seda), peale selle töötasin elektroonikaga tegelevas firmas aparaatide kokkupanemisega (releed, kontaktorid jmt kraami põhimõtted on teada ) aga samas dioodid, sümistorid ja türistorid ei ütle mulle suurt midagi.
wicked-i antud juhend tundub olevat täiuslik, kuid suurt midagi ma sellega teha ei oska - arusaamine ei ole täielik ja lampi kah ei taha katsetada
Seal on tegemist COM, mitte LPT pordiga. Ok, see pmst sobib kah...
Samas on seal juttu sümistoridega juhtimisest, kas oskate nende koha pealt veidike lähemalt rääkida? (Mis osad skeemist ära jäävad jmt...)
Mis on nende lülitusaeg, mispoolest nad erinevad releedest (hea/halb va. häälitsemine). Ma ise arvan, et kui selle skeemi järgi teha, siis peaks kasutama just seda varianti. Kõva plõgin võib pinda käima hakata (plaanis mitmeid kordi sekundis lülitada osasid, ja kuna aegajalt töötan keskkonnas kus palju-palju kontaktoreid/releesid klõbisevad, siis peaks neid ehk tõesti vältima).
Kilovattides ei ole plaanis hakata ühe liini peal asju käivitama
06.02.2008 20:49:53
com või lpt port - vahet ei ole, signaalide tugevused on samad
pohhkar
06.02.2008 20:52:13
Endal just selle asja tegemine pooleli. Hetkel mässan programmi kallal mis releesi juhtima hakkab. Skeemina kasutan seda (sealt natuke allpool safer new design). Programmi tuleb veel lisaks releede juhtimisele arvutiprogrammide käivitamine, scheduler, häälkäsklused ja ir saatmine ja vastuvõtmine. Kõik peale ir saatja ja vastuvõtja on peaaegu valmis. Com pordi kaudu ir saatmine ja vastuvõtmine on veel natuke probleemne. Idee poolest hakkaks see kaadervärk juhtima kodus olevaid tulesi, automaatselt liikuvaid kardinaid ja veel mõnda seadet. Ir hakkab lülitama muusikakeskust ja telekat(annan häälkäskluse meediakeskus ja arvuti lülitab sisse teleka(programmiks AV1) muusikakeskuse(sisendiks aux), kustutab tuled ja käivitab htpc programmi.
ahjaa releedeks kasutan tõenäoliselt vist neid
viimati muutis pohhkar 06.02.2008 20:55:23, muudetud 1 kord |
R A T
06.02.2008 20:53:36
sedan'd küll, aga LPT pordist peaks pmst saama igale releele oma impulsi, mitte ei peaks kasutama serveerimist...
Samas COM pordiga pole kogemusi eriti, ei oska kindlalt öelda
LPT oleks hea variant, sest mul selle taga oleva LCD jaoks programmid valmis kirjutatud juba, vähe muutmist oleks tarvis selle variandi jaoks
pohhkar
06.02.2008 20:58:14
lpt pordil on 8 data pinni. Järelikult saab kaheksat releed korraga juhtida. Seega tuleb seda skeemi lihtsalt 8 tükki teha ja ongi kõik. Kui on vaja rohkemaid asju juhtida, saab lisada lisakaardiga lpt porte või teha siis juba pic baasil midagi(sel juhul juba võibolla usb juhtimisega)
R A T
07.02.2008 17:43:24
pohhkar - oma viimast teadet kirjutades ma ei märganud sellele eelnevat sinu tehtud postitust (samal ajal kirjutasime ).
Loen selle lingi läbi ja ehk läheb käiku. 8tk on mulle piisav!
pupsik46
08.02.2008 14:58:43
R A T, arvesta sellega, et arvuti käivitamisel, saadetakse parallel porti igasuguseid testsignaale. Ehk siis käivitamise ajal releed plõksuvad
_________________ M/V: Estonia 010 , Odissei 010 võimendid
O/V: 10.1", 12,1" ja 13.3" LCD paneeli |
R A T
08.02.2008 18:58:05
ahaa, see küll sakib
felch
08.02.2008 21:01:26
See minu loos kirjeldet e-pikendus töötab ka kenasti. Juhtmeid vähem, võib masinast kaugemal olla. Proset ka ei ol skeemis!
Sümistoride kasutamise puhul jäävad ära releed. Optronid ühendatakse nende asemele ULN-ouhvri külge. Toide muidugi mitte 12V vaid 5V pealt. Kui väga tahaks 12v, peab optroni eeltakisti võtma 1k väärtusega ja ongi korras.
Seal oli vist seletav skeemijupika ka olemas.
Juhtkood on vabavara ja lähtekood netis.
Kui selle skeemi kohta küsimusi, võib meilida.
On olemas ka powerswitchi nimeline AVR-prosega otse USBi käiv tükk: http://www.obdev.at/products/avrusb/powerswitch.html
R A T
09.02.2008 18:01:39
Tere Felch
Usutavasti lähebki käiku sinu kirjelduse järgi süsteem.
Mingiaeg peab poodi minema ja komponente ostma hakkama.
Enne tuleb mul välja uurida, mida mul üldse tarvis on, sest seal nimekirjas on nii mõnigi asi valikuline...
likoor
R A T
10.02.2008 13:38:28
Hmm, see discolitez on ka huvitav idee, skeem tundub kõvasti lihtsam kui muude puhul
zbx
16.02.2008 16:58:11
R A T: Niipalju Sulle väikseks hoiatuseks, et Triac (türistor)skeemilahendused tekitavad väga tugevaid võrguhäireid. Nii, et sellise lahenduse korral vajad kindlasti üsna tugevaid ja efektiivseid võrgufiltreid.
Vastasel juhul võid nii ise kui naabrimees lahti saada oma kallihinnalisest LCD-telerist, muusikakeskusest vms. kodutehnikast.
likoor
16.02.2008 18:39:29
tahanteada, TRIAC on siiski Sümistor (ehk siis kaks türistori kokkupandud). Kuid võrguhäired võivad tekkida küll.
R A T
JanQ
01.04.2008 20:55:21
Võrguhäireid ei teki, kui teha skeem "faasikontrolliga" + filtrid, teadjad teavad mida ma tahan öelda... s.t. avanemisimpulssi hakatakse andma siinuse tõusul, mitte suvalisel hetkel. Mäletan vene skeeme: jooksvaid tulesid ja värvimuusikaid,
kus seda vahel kasutati, loomulikult ka tööstusseadmetes...
...... ja.... naabriga kaklemine jääb ära.
lockpock
14.01.2011 18:26:24
Kas USb le oleks ka ise võimalik see 16 releega kontroller teha. LPT pordi kaudu endale nagu 8 releest jääks väheks. Ehk teab keegi, kust oleks võimalik saada mõnda programmi 16 relee juhtimiseks USB kaudu? Enamus on tasulised ja mingi 30 päevased, ja osta nagu küll ei jõuaks, tahetakse mingi 2500eeku
sekonic
14.01.2011 21:49:53
Näiteks selline programm nagu Quick Timer R16X see on 16 relee juhtimiseks com pordist, aga kuida com pordist 16 releed juhtida seda mina ei tea, seal ju ainult 9 väljundit
Cert85
21.01.2011 20:28:44
Järelikult on eraldi kontroller veel, mis com-pordiga eelnevalt suhtleb ja saab com-pordist tuleva info põhjal aru, millisele releele käsklus tuleb edasi anda.
_________________ Cert85 @ flickr.com |
