Scart
04.01.2008 13:20:16
Chris Taylor's Demigod |
link :: kae siit
Chris Taylor's Gas Powered Games is best known for its RTS Supreme Commander and its action-RPG series Dungeon Siege -- so maybe it's just the natural course of evolution that the developer's newest game, Demigod, should borrow a bunch from both of those genres: It's an action/RPG/RTS hybrid, inspired partly by the popular WarCraft III mod Defense of the Ancients.
For those who've never tried DotA, it concentrates on two teams trying to destroy each others' bases; though rather than managing all the units or gathering resources as in a regular RTS, players each control a single Hero unit with different powers, leveling up by killing A.I. enemies around the map.
In Demigod, you control one of many "demigod" heroes -- some of which survive solely on the strength of their own powers, others of which thrive on building smaller units and structures of their own for support. The guy on the left in the screenshot below is one such hero, "The Rook," a former king whose spirit now animates an anthropomorphic castle. Demigod is, as you'd expect, a multiplayer game at heart, with an emphasis on co-op play. There's a single-player mode, too, though Gas Powered Games says it will serve mainly as a "training ground" for the multiplayer.
101 |
Ulfus
Aeg Maha 2a
04.01.2008 16:57:00
Mis mängu eesmärk siis on kui co-op?või on vastas tiimi pooljumalad AI kontrollitud?
Tea järsku lähevad mõned dota mängijad sellele üle, kuigi vähe usutav .igatahes dota on viimase 2-3 aasta jooksul alla käinud IMO.
_________________ Need mingid teised |
| Kommentaarid: 20 loe/lisa |
17 |
Oakwarrior
28.07.2008 10:37:11
Et siis uus mahukas Q&A ja treiler väljas. Tundub tore mäng olevat
vajuta mind
Keegi preorderinud ka on peale minu?
Et beetasse saada ma mõtlen.
Eestlased vist väga huvitatud pole sellest siin ma vaatan... haipi pole ka mängul eriti (õnneks), aga eks seda tuleb ka veel
Araablane
28.07.2008 10:56:26
| Proovin ära kui tuleb aga mingit erilist tõmmet sellele mängule pole.
| Kommentaarid: 30 loe/lisa |
28 |
Oakwarrior
28.07.2008 10:58:25
Eks kui beeta algab võin ehk natukesekene muljetada siin kuidas mäng tundub
Araablane
28.07.2008 11:00:21
| Oakwarrior kirjutas: |
Eks kui beeta algab võin ehk natukesekene muljetada siin kuidas mäng tundub  |
See oleks küll väga super, siis teaks kohe ära kas on mõtet mängu muretseda või mitte
28 |
Sarin
29.07.2008 17:34:31
Võiksid kohe öelda kui palju ta dotale sarnaneb
Võiks sama kaasakiskuv olla...
| Kommentaarid: 7 loe/lisa |
Oakwarrior
29.07.2008 19:53:44
Noo, kui palju ta dotale sarnaneb saab isegi kohe järeldada: Väga palju.
Järeldus on tehtud kõigest sellest infost mida ma olen kuulnud, näinud, lugenud jne
Azatris
30.07.2008 06:57:04
Tundub väga hea. DotA't mängin ka.
Trackin seda mängu
| Kommentaarid: 40 loe/lisa |
36 |
Oakwarrior
Azatris
03.08.2008 21:24:46
| Oakwarrior, suht huvitav siiamaani jah. Kuna ta AI'dega mängis, siis järeldan, et on singleplayer mäng multiplayer võimalustega.
36 |
Oakwarrior
03.08.2008 21:50:23
| On olemas ka võimalused AI vs AI raunde korraldada. Ütleks siiski et on multiplayer mäng singleplayer võimalustega, sest põhiline omadus mida reklaamitakse selle mängu puhul on ikkagi võimas player vs. player värk. Singleplayer on põhimõtteliselt tutorial, enne kui sa õigesse lahingusse satud Multiplayeris, nagu nad on öelnud. SP's räägitakse ära mängu stoori ja tutvustatakse funtksioone.
Azatris
03.08.2008 22:42:55
| Loodame siis suure library nimel spellidele ja demigodeidele.
36 |
Sarin
NeverL
15.04.2009 20:43:13
Mäng nüüd väljas.
täpselt nagu Dota aga kuna kohe algusest saadik on mõeldud teha dotat, lõpptulemus tundub nagu mugavam ja terviklikum
single player puudub ning AI on skirmishites üsna lollakas.
Sarin
16.04.2009 10:36:20
| NeverL kirjutas: |
Mäng nüüd väljas.
single player puudub ning AI on skirmishites üsna lollakas. |
Kas seal on ikka itemite ostmine ka sees?
veso
16.04.2009 11:43:31
| Potioneid ja igast kraami saad osta, pilt on ilus, gameplay ka normaalne. See on jama, et aint mingi 8 herot hetkel, patchidega lisatakse juurde tho naug ma kuulnud olen.
NeverL
16.04.2009 12:33:40
jep, itemeid saab osta ja igast muud nodi kah.
mängu balancimisega läheb veel aega kuna assasinid on kõvasti kasulikumad kui generalid hetkel.
muide on keegi leidnud võimaluse kuidas attack move'i panna nö. genereliga mängides kuradi minionid jäävad kohati passima kasutult.
Azatris
16.04.2009 18:11:50
| Päris huvitav mäng. Tegin kohe alguses single player easy tournamenti ja võitsin kõik mängud. Skillide süsteem tundub päris hea olevat, kuid ma siiski arvan, et mulle meeldib DotA ta mitmekülgsuse pärast rohkem ning seal on asi kõik tasakaalus.
36 |
Scart
17.04.2009 11:35:12
| Hea, et enne ostmist proovida tahtsin. Minu masina peal jookseb mäng küll hullemini, kui GTA ilma patchideta. Ei tea, mis nii sassis on - nagu SupCom steroididel.
101 |
DODONPACHI
| Kommentaarid: 23 loe/lisa |
22 |
Scart
17.04.2009 16:02:45
Huvitav, kas nende idee oli müüa 20k mängu ja sellega piirduda? Ainult onlainis mängimiseks mõeldud mäng võiks ikka nagu evida ka robustset süsteemi selle jaoks. Igatahes, ostsin ära ja eks näis, kuidas siis see mäng ajale vastu peab.
101 |
Traf
17.04.2009 16:13:21
| Scart kirjutas: |
Huvitav, kas nende idee oli müüa 20k mängu ja sellega piirduda? Ainult onlainis mängimiseks mõeldud mäng võiks ikka nagu evida ka robustset süsteemi selle jaoks. Igatahes, ostsin ära ja eks näis, kuidas siis see mäng ajale vastu peab. |
"Our stress tests had counted on having maybe 50,000 people playing at once at peak and that wouldnt be reached for a few weeks by which time we would have slowly seen things becoming problematic. With Sins of a Solar Empire, the game was incredibly successful but its user base grew slowly and steadily over time. Sometimes on a peak time the server would start to get slow and we would adjust so that it would be better next time."
On ju kirjas, et olid arvestanud väiksema nõudlusega alguses, et siis hiljem vastavalt vajadusele muutusi teha. Lisaks veel see 18'000 legaalset vs 100'000 pirajat võrdlus - ilma pirajateta oleks tunduvalt pehmemalt läinud.
| Kommentaarid: 49 loe/lisa |
48 |
Scart
18.04.2009 13:30:39
See kõik on väga tore, aga mina näiteks hetkel MPd küll mängida ei saa. Kui isegi leiab mõne mängija üles, on minut hiljem time-out ja kõik.
Peaaegu nelja tunni peale siis 1 õnnestunud mäng. Loomulikult pandi mulle minu enda valikust mööda vaates teine demigod, kellest oli suht null kasu ja meid steamrolliti üle. Üks mäng õhtu kohta kisub kuidagi väga niruks ära.
Õhtu poole on päris stabiilne ja iga teine mäng läheb ka käima. Mis aga ei muuda fakti, et nüüd, kui tehnilised probleemid näikse olevat lahendatud - on community täies hiilguses väljas. Sellist abjuusi ja pasaladu pole ikka päris kaua aega kogenud - kui pühapäeva õhtuks asi ei muudu, saadan refundi soovi.
Master server maas, viimased 5 tundi pole olnud võimalik ühtegi MP mati käima lasta. Põnev.
101 |
t2ring
18.04.2009 17:06:37
| Scart kirjutas: |
| Master server maas, viimased 5 tundi pole olnud võimalik ühtegi MP mati käima lasta. Põnev. |
Kui nüüd sinu posti lugeda, siis ma küll ei julge seda mängu endale soetada On siis tõesti asi nii hull???
| Kommentaarid: 97 loe/lisa |
94 |
