praegune kellaaeg 16.10.2026 09:30:31
BT
03.01.2008 20:33:26
DVD kirjutamisega probleemid - palun abi |
DVD kirjutaja ei taha kuidagi DVD-de kirjutamisega hakkama saada. CD-dega probleeme ei ole.
Tegemist siis Slimtype DVDRW SOSW-852S error log on järgmine, vast on keegi kes aidata oskab
indows XP 5.1
IA32
WinAspi: -
ahead WinASPI: File 'C:\Program Files\Nero\Nero 7\Core\Wnaspi32.dll': Ver=2.0.1.74, size=164112 bytes, created 11/2/2004 11:54:32 EL
NT-SPTI used
Nero Version: 7.5.9.1
Internal Version: 7, 5, 9, 1
(Nero Express)
Recorder: <Slimtype DVDRW SOSW-852S>Version: PSU2 - HA 1 TA 0 - 7.5.9.1
Adapter driver: <IDE> HA 1
Drive buffer : 2048kB
Bus Type : default (0) -> ATAPI, detected: ?
CD-ROM: <Slimtype DVDRW SOSW-852S >Version: PSU2 - HA 1 TA 0 - 7.5.9.1
=== Scsi-Device-Map ===
DiskPeripheral : TOSHIBA MK6025GAS atapi Port 0 ID 0 DMA: On
CdRomPeripheral : Slimtype DVDRW SOSW-852S atapi Port 0 ID 1 DMA: On
=== CDRom-Device-Map ===
Slimtype DVDRW SOSW-852S D: CDRom0
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 72351744 (0) Byte
BUFE : 0
Physical memory : 495MB (507248kB)
Free physical memory: 160MB (164072kB)
Memory in use : 67 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
3.1.2008
ISO compilation
6:28:43 PL #1 Text 0 File SCSIPTICommands.cpp, Line 411
LockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
6:28:44 PL #2 Text 0 File Isodoc.cpp, Line 6509
Iso document burn settings
Determine maximum speed : FALSE
Simulate : FALSE
Write : TRUE
Finalize CD : FALSE
Multisession : TRUE
Multisession type: : Start multisession
Burning mode : DAO
Mode : 1
ISO Level : 1 (Max. of 11 = 8 + 3 char)
Character set : ISO 9660
Joliet : TRUE
Allow pathdepth more than 8 directories : TRUE
Allow more than 255 characters in path : TRUE
Write ISO9660 ;1 file extensions : TRUE
6:28:44 PL #3 ISO9660GEN -11 File Geniso.cpp, Line 3332
First writeable address = 0 (0x00000000)
6:28:44 PL #4 Text 0 File Burncd.cpp, Line 3451
Turn on Disc-At-Once, using DVD media
6:28:44 PL #5 Text 0 File DlgWaitCD.cpp, Line 306
Last possible write address on media: 2295103 (510:01.28, 4482MB)
Last address to be written: 1071455 (238:06.05, 2092MB)
6:28:44 PL #6 Text 0 File DlgWaitCD.cpp, Line 318
Write in overburning mode: NO (enabled: CD)
6:28:44 PL #7 Text 0 File DlgWaitCD.cpp, Line 2903
Recorder: Slimtype DVDRW SOSW-852S, Media type: DVD+R
Disc Manufacturer ID: MBIPG101, Media Type ID: R05, Product revision number: 1
Disc Application Code: 0, Extended Information Indicators: 7
6:28:44 PL #8 Text 0 File DlgWaitCD.cpp, Line 490
>>> Protocol of DlgWaitCD activities: <<<
6:28:44 PL #9 Text 0 File ThreadedTransferInterface.cpp, Line 821
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 ()
2 indices, index0 (150) not provided
original disc pos #0 + 1071456 (1071456) = #1071456/238:6.6
relocatable, disc pos for caching/writing not required/ required
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 1071456 blocks [D: Slimtype DVDRW SOSW-852S]
6:28:44 PL #10 Text 0 File ThreadedTransferInterface.cpp, Line 1024
Prepare [D: Slimtype DVDRW SOSW-852S] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc not fixated
Tracks 1 to 1: Idx 0 Idx 1 Next Trk
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 2194341888, ISRC ""
DAO layout:
___Start_|____Track_|_Idx_|_CtrlAdr_|_____Size_|______NWA_|_RecDep__________
0 | lead-in | 0 | 0x41 | 0 | 0 | 0x00
0 | 1 | 0 | 0x41 | 1071456 | 0 | 0x00
0 | 1 | 1 | 0x41 | 1071456 | 0 | 0x00
1071456 | lead-out | 1 | 0x41 | 0 | 0 | 0x00
6:28:44 PL #11 Text 0 File SCSIPTICommands.cpp, Line 209
SPTILockVolume - completed successfully for FCTL_LOCK_VOLUME
6:28:44 PL #12 Phase 24 File dlgbrnst.cpp, Line 1746
Caching of files started
6:28:44 PL #13 Text 0 File Burncd.cpp, Line 4278
Cache writing successful.
6:28:44 PL #14 Phase 25 File dlgbrnst.cpp, Line 1746
Caching of files completed
6:28:44 PL #15 Phase 36 File dlgbrnst.cpp, Line 1746
Burn process started at 6x (8,310 KB/s)
6:28:44 PL #16 Text 0 File ThreadedTransferInterface.cpp, Line 2743
Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
6:28:44 PL #17 Text 0 File Cdrdrv.cpp, Line 9235
---- DVD Structure: Physical Format Information (00h) ----
Media Type: 0, Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
Book Type: DVD+R (10), Part Version: 1.0x (1)
Disc Size: 120 mm, Maximum Rate: <not specified> (F h)
Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable
Linear Density: 0,267 um/bit, Track Density: 0,74 um/track
Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
End Physical Sector Number of Data Area: 26053F h
End Sector Number in Layer 0: 0 h (LBN: FFFD0000 h, 4193920 MB)
Data in Burst Cutting Area (BCA) does not exist
Disc Application Code: 0 / 0 h
Extended Information indicators: 7 h
Media type ID: R05
Number of Physical format information bytes in use in ADIP up to byte 63: 56
Media Specific [16..63]:
00 00 07 4D 42 49 50 47 - 31 30 31 52 30 35 01 38 ...MBIPG101R05.8
23 54 37 13 02 50 6B 02 - 8C 63 15 15 0B 0B 08 08 #T7..Pk..c......
01 19 1B 0C 0C 0C 0D 01 - 00 00 00 00 00 00 00 00 ................
6:28:44 PL #18 Text 0 File DVDPlusRW.cpp, Line 674
Start write address at LBA 0
DVD high compatibility mode: No
6:35:37 PL #19 SPTI -1135 File SCSIPassThrough.cpp, Line 179
CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1135)
Sense Key: 0x03 (KEY_MEDIUM_ERROR)
Sense Code: 0x0C
Sense Qual: 0x00
CDB Data: 0x2A 00 00 0C 17 20 00 00 20 00 00 00
Sense Area: 0x71 00 03 00 00 00 00 0A 00 00 00 00 0C
Buffer x0bbc8180: Len x10000
0x30 37 AA AC F8 D2 5F CD B2 6C 58 77 EB 46 56 29
0xF8 D0 3E 0B CC 11 C7 F8 C7 AD F5 2F C9 A3 B6 77
0x63 32 69 67 9A 1C FF 26 2F 08 0F 03 0F C0 F1 72
6:35:37 PL #20 CDR -1135 File Writer.cpp, Line 299
Write error
6:35:37 PL #21 Phase 38 File dlgbrnst.cpp, Line 1746
Burn process failed at 6x (8,310 KB/s)
6:35:38 PL #22 Text 0 File SCSIPTICommands.cpp, Line 254
SPTIDismountVolume - completed successfully for FSCTL_DISMOUNT_VOLUME
6:35:40 PL #23 Text 0 File Cdrdrv.cpp, Line 10472
DriveLocker: UnLockVolume completed
6:35:40 PL #24 Text 0 File SCSIPTICommands.cpp, Line 411
UnLockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
Existing drivers:
File 'Drivers\CDRALW2K.SYS': Ver=8.0.0.212 , size=9464 bytes, created 3/8/2007 1:51:00 EL
File 'Drivers\PXHELP20.SYS': Ver=3.00.56a, size=43528 bytes, created 3/8/2007 1:51:00 EL (Prassi/Veritas driver for win 2K)
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
frygor
03.01.2008 21:35:31
mis kiirusega sa kõrvetad dvd-sid? maximum ehk mingi 16x-18x vms?
_________________ Hunt kriimsilm 9 ametiga! |
| Kommentaarid: 70 loe/lisa |
65 |
ajnurm
03.01.2008 21:54:59
| frygor kirjutas: |
| mis kiirusega sa kõrvetad dvd-sid? maximum ehk mingi 16x-18x vms? |
| BT kirjutas: |
_________________ Jälestan ja vihkan õpitud abitust! RTFM & UTFG! |
| Kommentaarid: 41 loe/lisa |
37 |
