praegune kellaaeg 16.10.2026 19:25:52
Tyc
13.03.2003 15:14:13
MICCER |
Selline probleem on, et mikrofoniga ei saa lindistada!
Sound Recording optionsist ei saa wave panna lihtsalt ei saa x maha võtta!
ihvike
13.03.2003 15:43:07
Mis x, mis options? On ikka recording source valitud microphone?
| Kommentaarid: 12 loe/lisa |
12 |
Tyc
13.03.2003 16:19:55
MIC |
Control Panel/Sounds and audio devices/sound recordig Ja viskab selle klikkides sellise texti:
"Theres a problem with your soundhardware. You may install or active mixer devices from the control panel"
