uus teema   vasta Tarkvara »  Turvalisus »  Kuhu saata kahtlane fail kontrollimiseks? service.exe märgi kõik teemad loetuks
Sokimeez
sõnum 17.11.2007 14:30:57 Kuhu saata kahtlane fail kontrollimiseks? service.exe vasta tsitaadiga
system32 kaustast leitud fail service.exe, spybot, adaware, Kaspersky, ega trendmicro housecall ei andnud ühtegi veateadet, kui hijackthis.de näitas et see on trooja, kuigi infot rohkem ei andnud.
Lord Ami
Lord Ami
sõnum 17.11.2007 15:03:12 vasta tsitaadiga
Virustotal.com
Lae sinna üles.
Kaspersky on sul originaal?
http://forum.kaspersky.com/index.php?showtopic=13881
Sokimeez
sõnum 17.11.2007 15:24:45 vasta tsitaadiga
Tänud. fail saadetud, ning kaspersky on trial variant.
Muhkel
Muhkel
sõnum 17.11.2007 15:26:47 vasta tsitaadiga
http://virusscan.jotti.org/
Kurda kõigile oma rasket saatust... ning sa näed enda ümber ainult rõõmsaid inimesi.
Laurikre
Laurikre
sõnum 17.11.2007 15:28:25 vasta tsitaadiga
Windows errors related to service.exe ?
service.exe is a process belonging to the Dell Solution Center which offers worldwide technical support and training for it's products. This program is important for the stable and secure running of your computer and should not be terminated. This process is also installed alongside Adaptec SCSI cards, and again should not be terminated unless causing problems.
Note: service.exe could also be a process which belongs to the . This program is a non-essential process, but should not be terminated unless suspected to be causing problems.
Note: service.exe is a process which is registered as a trojan. This Trojan allows attackers to access your computer from remote locations, stealing passwords, Internet banking and personal data. This process is a security risk and should be removed from your system.
Determining whether service.exe is a virus or a legitimate Windows process depends on the directory location it executes or runs from. Check that service.exe is stable on your computer.
Recommendation for service.exe:
service.exe is not a critical component.
It is highly recommended to Run a Free Performance Scan to automatically optimize memory, CPU and Internet settings.
Determining whether service.exe is a virus or a legitimate Windows process depends on the directory location it executes or runs from. Click to Scan your PC including service.exe to Detect any Security Threat.
Link: http://www.liutilities.com/products/wintaskspro/processlibrary/service/
Laurikre:.
Need: Windows, .Net, Sharepoint, Exchange, Dynamics, Visual Studio, XNA, Expression, Silverlight, SQL and many other skills? Talk to me icon_smile.gif
Rohkem IT uudiseid iga päev BattleIT lehelt
Kommentaarid: 154 loe/lisa Kasutajad arvavad:  :: 0 :: 5 :: 131
Sokimeez
sõnum 17.11.2007 16:41:45 vasta tsitaadiga
Päris nii lihtne see siiski ei ole @ laurikre. Uurides faili natuke lähemalt, leidsin toote nimeks M i r a r ErrorDns Test
Kuna arvutis esines lisaks Mirar toolbar, siis seosasin faili sellega.
http://www.viruslist.com/en/viruses/encyclopedia?virusid=108890 Saab antud Mirari kohta infot, kuid siiski, mida teeb see service.exe fail?
Kaspersky leidis ja eemaldas küll muud Mirari failid, kuid selle jättis puutumata.
kahtlust tekitas nimelt selle faili leidumine startup-listis.
Aga fail saadetud nii kasperskyle, kui virustotal.com-i
(Tean et lihtsam oleks see fail nüüdseks kustutada, kuid uudishimu on suur)
sõnum 17.11.2007 18:00:36 vasta tsitaadiga
Windowsil on services.exe, mitte service.exe. Ja service-nimelist exe-faili ma oma kettalt ei leidnud ka - seega minu loogika kustutaks selle ära.
M: HP Elitedesk 800 G3 SFF
Kommentaarid: 765 loe/lisa Kasutajad arvavad:  :: 1 :: 1 :: 571
Lord Ami
Lord Ami
sõnum 17.11.2007 21:05:35 vasta tsitaadiga
Sokimeez kirjutas:
Mis versioon Kaspersky-st?
Mine settings-threats and exclusions vms ja pane seal märk ette riskwarele.Või siis oli v6-l see protection all.
Siis peaks Kaspersky seda leidma.
