uus teema   vasta Tarkvara »  Turvalisus »  efcccc.dll on nakatunud win32/adware.virtumonde sitaga märgi kõik teemad loetuks
-IFFI-
-IFFI-
sõnum 15.10.2007 23:52:47 efcccc.dll on nakatunud win32/adware.virtumonde sitaga vasta tsitaadiga
Selline jama siis nuid
HJT logi asub SIIN
Lord Ami
Lord Ami
sõnum 16.10.2007 06:56:16 vasta tsitaadiga
http://www.atribune.org/content/view/24/2/
Proovi seda.
Siis ka SAS-i
http://www.superantispyware.com/downloadfile.html?productid=SUPERANTISPYWAREFREE
sõnum 16.10.2007 07:17:32 vasta tsitaadiga
Please download VundoFix.exe to your desktop.
* Double-click VundoFix.exe to run it.
* Click the Scan for Vundo button.
* Once it's done scanning, click the Remove Vundo button.
* You will receive a prompt asking if you want to remove the files, click YES
* Once you click yes, your desktop will go blank as it starts removing Vundo.
* When completed, it will prompt that it will shutdown your computer, click OK.
* Turn your computer back on.
* Please post the contents of C:\vundofix.txt and a new HiJackThis log.
http://www.atribune.org/ccount/click.php?id=4 = vundofix
siit threadist http://www.geekstogo.com/forum/Win32-Adware-Virtumonde-t89807.html
google otsingu win32/adware.virtumonde peale. huvitav, et kõigil, kellel sellenimneline probleem on, on masinas nod32.. kaspersky baasidest ma seda ei leidnud eraldi väljatooduna. icon_rolleyes.gif
Kommentaarid: 1159 loe/lisa Kasutajad arvavad:  :: 4 :: 0 :: 725
sõnum 16.10.2007 07:21:12 vasta tsitaadiga
http://forums.techguy.org/malware-removal-hijackthis-logs/598873-solved-win32-adware-virtumonde-removal.html
siit hakkas ka midagi silma, g00gle is ur friend.
sõnum 16.10.2007 07:26:37 vasta tsitaadiga
http://www.lavasoft.com/support/securitycenter/virtumonde_remover.php lavasoftil ja symantec il on ka selle vastu rohi olemas. nod32 hest tulnud vastus juhib natuke valedele jälgedele.
parem link ja selles ka removal tool ja instructions. http://www.lavasoftsupport.com/index.php?showtopic=4031
kui midagi muutub, tahaks tagasisidet.
-IFFI-
-IFFI-
sõnum 16.10.2007 11:35:21 vasta tsitaadiga
Tänud abi eest nuid ole kõik korras ja kena, vähemasti siiani. Kärutasin masina üle VundoFix ja SuperaAntiSpyware-ga. Viimase programmi logi asub SIIN
Lord Ami
Lord Ami
sõnum 16.10.2007 16:08:23 vasta tsitaadiga
-IFFI- kirjutas:
Tore:)
http://superantispyware.com/definitions.html
Kui siit vaadata, siis SAS meeskond lisab palju vundo variante baasidesse:)
