praegune kellaaeg 09.11.2026 15:28:53
Tamarillo
18.10.2007 16:41:29
Illegal disc?! |
Tahtsin siis teha uut plaati. Plaadiks on Phillips DVD-RW. Nero 7 ütleb, et wrong disc, kuigi olen nii + kui - plaate kirjutanud. Kirjutajaks Lite On SOHW 1633S.
Firmware update on tehtud
Milles jama?
Siin burn log!
Kodu
Kodu
1C82-0000-19E5-MAAX-4004-2511-****
Windows XP 5.1
IA32
WinAspi: -
NT-SPTI used
Nero Version: 7.9.6.0
Internal Version: 7, 9, 6, 0
(Nero Express)
Recorder: <LITE-ON DVDRW SOHW-1633S>Version: BS0Y - HA 1 TA 0 - 7.9.6.0
Adapter driver: <IDE> HA 1
Drive buffer : 2048kB
Bus Type : default (0) -> ATAPI, detected: ?
CD-ROM: <OE3711U MIO250I >Version: 1.0 - HA 1 TA 1 - 7.9.6.0
Adapter driver: <SCSI> HA 1
=== Scsi-Device-Map ===
CdRomPeripheral : LITE-ON DVDRW SOHW-1633S atapi Port 2 ID 0 DMA: On
DiskPeripheral : Maxtor 6Y080P0 atapi Port 3 ID 0 DMA: On
CdRomPeripheral : OE3711U MIO250I 1.0 atp0uzif Port 4 ID 0 DMA: Off
=== CDRom-Device-Map ===
LITE-ON DVDRW SOHW-1633S D: CdRom0
OE3711U MIO250I E: CdRom1
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 83886080 (0) Byte
BUFE : 0
Physical memory : 1023MB (1048048kB)
Free physical memory: 614MB (629596kB)
Memory in use : 39 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
18.10.2007
ISO compilation
17:39:05 #1 Text 0 File SCSIPTICommands.cpp, Line 424
LockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
17:39:05 #2 Text 0 File Isodoc.cpp, Line 6663
Iso document burn settings
Determine maximum speed : FALSE
Simulate : FALSE
Write : TRUE
Finalize CD : FALSE
Multisession : TRUE
Multisession type: : Start multisession
Burning mode : DAO
Mode : 1
ISO Level : 2 (Max. of 31 chars)
Character set : ISO 9660
Joliet : TRUE
Allow pathdepth more than 8 directories : TRUE
Allow more than 255 characters in path : TRUE
Write ISO9660 ;1 file extensions : TRUE
17:39:05 #3 ISO9660GEN -11 File Geniso.cpp, Line 3343
First writeable address = 0 (0x00000000)
17:39:05 #4 Text 0 File Burncd.cpp, Line 3508
Turn on Disc-At-Once, using DVD media
17:39:06 #5 Text 0 File DlgWaitCD.cpp, Line 307
Last possible write address on media: 2297887 (510:38.37, 4488MB)
Last address to be written: 2175151 (483:22.01, 4248MB)
17:39:06 #6 Text 0 File DlgWaitCD.cpp, Line 319
Write in overburning mode: NO (enabled: CD)
17:39:06 #7 Text 0 File DlgWaitCD.cpp, Line 2964
Recorder: LITE-ON DVDRW SOHW-1633S, Media type: DVD-RW
Disc Manufacturer: MBI01R - WG 20
Disc Application Code: 2, Disc Physical Code: 214
17:39:06 #8 Text 0 File DlgWaitCD.cpp, Line 493
>>> Protocol of DlgWaitCD activities: <<<
17:39:06 #9 Text 0 File ThreadedTransferInterface.cpp, Line 793
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 ()
2 indices, index0 (150) not provided
original disc pos #0 + 2175152 (2175152) = #2175152/483:22.2
relocatable, disc pos for caching/writing not required/ required
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 2175152 blocks [D: LITE-ON DVDRW SOHW-1633S]
17:39:06 #10 Text 0 File ThreadedTransferInterface.cpp, Line 995
Prepare [D: LITE-ON DVDRW SOHW-1633S] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc not fixated
Tracks 1 to 1: Idx 0 Idx 1 Next Trk
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 4454711296, ISRC ""
DAO layout:
___Start_|____Track_|_Idx_|_CtrlAdr_|_____Size_|______NWA_|_RecDep__________
0 | lead-in | 0 | 0x41 | 0 | 0 | 0x00
0 | 1 | 0 | 0x41 | 0 | 0 | 0x00
0 | 1 | 1 | 0x41 | 2175152 | 0 | 0x00
2175152 | lead-out | 1 | 0x41 | 0 | 0 | 0x00
17:39:06 #11 Text 0 File SCSIPTICommands.cpp, Line 215
SPTILockVolume - completed successfully for FSCTL_LOCK_VOLUME
17:39:06 #12 Text 0 File Burncd.cpp, Line 4294
Caching options: cache CDRom or Network-Yes, small files-Yes (<64KB)
17:39:06 #13 Phase 24 File dlgbrnst.cpp, Line 1762
Caching of files started
17:39:06 #14 Text 0 File Burncd.cpp, Line 4413
Cache writing successful.
17:39:06 #15 Phase 25 File dlgbrnst.cpp, Line 1762
Caching of files completed
17:39:06 #16 Phase 36 File dlgbrnst.cpp, Line 1762
Burn process started at 4x (5 540 KB/s)
17:39:06 #17 Text 0 File ThreadedTransferInterface.cpp, Line 2721
Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
17:39:06 #18 Text 0 File DVDMinusRW.cpp, Line 262
Perform 'Quick Format' (type 15h) to set disc in 'Restricted Overwrite Mode'.
17:39:06 #19 Phase 136 File dlgbrnst.cpp, Line 1762
Quick Format DVD-RW
17:39:08 #20 SPTI -1046 File SCSIPassThrough.cpp, Line 179
CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1046)
Sense Key: 0x02 (KEY_NOT_READY)
Sense Code: 0x30
Sense Qual: 0x05
CDB Data: 0x00 00 00 00 00 00 00 00 00 00 00 00
Sense Area: 0x71 00 02 00 00 00 00 0A 00 00 00 00 30 05
17:39:08 #21 CDR -1046 File ThreadedTransferInterface.cpp, Line 1752
Illegal disc
17:39:08 #22 TRANSFER -27 File ThreadedTransferInterface.cpp, Line 1752
Could not perform start of Disc-at-once
17:39:10 #23 Text 0 File ThreadedTransfer.cpp, Line 269
Pipe memory size 83836800
17:39:10 #24 Phase 38 File dlgbrnst.cpp, Line 1762
Burn process failed at 4x (5 540 KB/s)
17:39:10 #25 Text 0 File SCSIPTICommands.cpp, Line 261
SPTIDismountVolume - completed successfully for FSCTL_DISMOUNT_VOLUME
17:39:13 #26 Text 0 File Cdrdrv.cpp, Line 11185
DriveLocker: UnLockVolume completed
17:39:13 #27 Text 0 File SCSIPTICommands.cpp, Line 424
UnLockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
Existing drivers:
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
