sõnum  |
G80
06.10.2008 06:27
Deneb does 4.3GHz on air
Liiga ilus jutt ikka, loodame, et tõsi siis võib AMD peale üle minna.
A while back we reported on a recent interview with AMD General Manager of AMD's Server and Workstation chip business, Pat Patla, where he claimed that Shanghai is much more than a mere die-shrink and that it is 20% faster than Barcelona clock per clock. We've been told by a second source that 20% may be a bit much, but that there is an IPC boost to expect, but closer to 15% than 20. In either case it's just a nice boost. This is applies for Deneb as well we've been told.
The source even indicates that since Nehalem isn't that much of a desktop upgrade, but server mostly, Deneb will become the gaming processor to get. We have no secondary confirmation at this time, but we wanted to forward the information. In fact, source also says that Deneb was able to do 4.3GHz under a Scythe Mine cooler, stable of course. It's very important to use the right motherboard though, you will need the SB750 southbridge to begin with.
Most people should be able to hit 3.6GHz with a decent cooler, source says. The most amazing is that the processor should still run fairly cool and consume less power than Intel equivalents. Comparing Intel's new processors to AMD's new, Intel is gaining on the server market, while AMD will be trying to get back the retail market. We will not have to wait long for it to happen either, mass production is well under way and launch is approaching.
http://www.nordichardware.com/news,8195.html
Shanghai reaching partners this month, 2.7GHz entry model
http://www.nordichardware.com/news,8197.html
| Kommentaarid: 238 loe/lisa |
193 |
06.10.2008 08:02
| varsti on õige aeg 790GX mobot otsima hakata
| Kommentaarid: 1006 loe/lisa |
727 |
CoiL
06.10.2008 11:43
Head uudised. Nehalem oma kallite platedega ei ole just eriti ahvatlev ja hea oleks kui AMD-lt oleks midagi hääd parema hinnaga võtta
| Kommentaarid: 95 loe/lisa |
83 |
G80
06.10.2008 12:28
| CorsairX kirjutas: |
Head uudised. Nehalem oma kallite platedega ei ole just eriti ahvatlev ja hea oleks kui AMD-lt oleks midagi hääd parema hinnaga võtta  |
Täpselt minu mõte, tahaks nüüd teste näha AMD vs Intel. 8)
193 |
A-Circus.
06.10.2008 15:26
Natuke kahtlen selles 4GHz's. Ise peaks heaks tulemuseks kui esimesed(steppingud) Denebid hea õhkjahutusega 3,6-3,8GHz stabiilsed on. Ei tasu unustada, et praegu teadaolevalt peaks kiireim Deneb tulema 3GHz ja tarbima 125W võimsust. Sellisel juhul on ligi +50% OC õhuga suhteliselt ulme.
Aga edukamaks kui Agenast peaks Deneb sellegipoolest saama. Loodetavasti tuleb midagi sarnast nagu R600>RV670 ning K11 siis RV770(700) .
| Kommentaarid: 40 loe/lisa |
38 |
11.10.2008 16:39
link :: Deneb 4Ghz Proof
vcore on suur aga noh, eks see ole mingi beta prose ka.
vähemalt pidi asi sellegipoolest jahe olema ja võtab suht vähe powerit.
727 |
G80
11.10.2008 16:52
Irw, 1,6V ja siis mingi 2,65 tonnine jahuti.
Aga ise ka loodan ,et denebist saab asja. 8)
193 |
WäntWõll
make.believe
11.10.2008 17:00
Päris korralik asi on tulemas justkui.
Pohl see voldu,takt on hea ja Intelil pole eriti hõista 4Ghz Quadiga.
FSB taob niimodi sisse et vahet pole palju sa volti keerad 4GHz jääb saamata ikka lihtsamate asjadega.
4GHz võib Inteli puhul rääkida 45nm põlvkonnast alates X3370 ja või Q9650 ,kuid hind rahulik 450
293 |
11.10.2008 18:17
eks see volt võib selleks suur olla, et coolaler ei oska klokkida
ja mobo ei tunne veel korralikult proset ära.
pluss see, et on klokitud HTT-d, lahtiste kordajatega prosega oleks asi kindlasti lihtsam.
samas räägitakse, et vaatamata sellele voldile võttis asi ikka vähem voolu kui samal kellal inteli 45nm quad.
727 |
AJ
| Kommentaarid: 37 loe/lisa |
36 |
Denke
727 |
matrix
04.11.2008 11:28
The Inquirer kirjutab Shangaist:
In the end, it is clear that AMD thinks it has a winner on its hands. It will be quite interesting to see how Shanghai stacks up, both later this month vs Penryn, and in early 2009 vs Nehalem.
http://www.theinquirer.net/gb/inquirer/news/2008/11/03/amd-shanghai-memo-leaks
_________________ Give a man a computer program and you give him a headache, but teach him to program computers and you give him the power to create headaches for others for the rest of his life... R. B. Forest |
| Kommentaarid: 7 loe/lisa |
aap14
07.11.2008 02:52
Kavas varsti soetada hd4870X2-hega komplekt.
Kuna Intelil tuleb varsti välja uus emaplaat uue socketiga, siis hakkasin kaaluma AMD proset.
Deneb läheb vist nende 790 emaplaatide peale kah kui ma ei eksi?
Ja Phenom X4 9950 BE jooksutab seda eespoolmainitud videokaarti sama hästi kui näiteks E8500?
Palun parandage kui ma eksin aga kas ei olegi mõttekas hetkel pigem osta AMD emaplaat ja prose, et tulevikus oleks võimalik upgrade Denebi peale teha?
Edit: CPU scaling radeon HD4870X2-hega http://www.legionhardware.com/document.php?id=770&p=6 Artikkel, kust infi võtsin siis
_________________ Slow is smooth and smooth is fast |
| Kommentaarid: 34 loe/lisa |
Ho Ho
07.11.2008 03:25
Eks see sõltub suuresti Denebi võimekusest. Samuti tasuks arvestada, et järgmisel aastal kolib ka AMD DDR3 peale üle, seega praegu seda ostes võid omale karuteene teha.
86 |
07.11.2008 07:16
| DDR3 pole nii kiire, et hinnavahet ära tasuks ja Deneb läheb kindlasti 790GX-i peale.
727 |
Ho Ho
07.11.2008 09:27
Kiire pole ta kindlasti, lihtsalt ostes praegu DDR2'ga mobo pole sellega mõne aja pärast suurt väga midagi teha, vahet pole kas tegu on AMD või Inteli omaga
86 |
CoiL
07.11.2008 11:03
Ho Ho, miks ei ole DDR2 moboga midagi teha? Loll jutt. DDR2-e kiirustest piisab veel 2a kindlasti imo.
83 |
Ho Ho
07.11.2008 11:08
Kiirusest kindlalt piisab kuid kas sa sinna ka uuemaid prosesid peale leiad?
86 |
CoiL
07.11.2008 11:12
| Ho Ho, Nehalemile mitte (selle hinnaga mis praegu nehalem on ja DDR3 mälud ei ostaks kindlasti). Tahad öelda, et deneb`le ei tule ddr2 mäludega mobosid? Usun küll et tuleb. Või on sul linki mis kinnitaks ,et ei tule kindlasti? Ei ole väga kursis ise AMD viimaste plaanidega prosede ja mobode osas.
83 |
07.11.2008 12:32
mismõttes ei tule kui deneb tavaline AM2+ prose on
mingi hetk hakkab DDR3 plaate ka tulema ja maybe tuleb neile mingi uus prose.
727 |
Le Inc
07.11.2008 16:34
| Integreeritud mälukontrolleriga prosel ju ei saa mälu tüüpi vahetada emaplaadipõhiselt!? See ju cpu sisse tehases keevitatud. Siis peab lihtalt uus rev. tulema mis DDR3 sööb.
| Kommentaarid: 55 loe/lisa |
53 |
07.11.2008 16:39
no? ega see ei tähenda, et AM2+ga kohe lõpparve teha võib
727 |
A-Circus.
07.11.2008 17:35
Ei viitsi küll allikaid hakata otsima aga need 2,8GHz ja 3GHZ Denebid pidiki ju AM2+ only olema. Järgmine aasta tulevad Denebid aga juba AM3 (kuigi ei mäleta kas AM3 versioonid ka AM2+ mobodesse istuma pidid).
Samas imeloomi neist uutest prosedest oodata ei tasu (jõudluse mõttes). AMD küll rääkis mingist 20% IPC kasvust Denebi puhul võrreldes 65nm Phenomitega prosedega, kuid ise küll ei tea ühtki juhust, millal shrinkimisega nii palju võimsuse lisa on saadud. Pigem ikka max 5-10%.
38 |
07.11.2008 17:52
am3 omad ei istu. nagu eelpool mainitud, teine mälukontroller.
_________________ - londiste
| Kommentaarid: 232 loe/lisa |
207 |
