praegune kellaaeg 10.10.2026 12:49:39
mikkc9n
31.08.2007 13:52:49
Viirus arvutis mida avg ei leia. |
Olen teinud full scani avg freega, ei leia midagi. Mõnikord idle olekus leiab mingeid viirusi Temporary Internet Files folderi alt, olen seda mitu korda tühjendanud kuid tekivad sinna mingid failid. Ja veel viskab ta mulle ette sellise kurja kastikese: http://picasaweb.google.com/mikk.noorkoiv/Paha/photo#5104815193023046802
Aidake lahti saada sellest.
Lord Ami
31.08.2007 14:02:50
Tee veel sellega TEMP kaustad tühjaks:
http://www.atribune.org/ccount/click.php?id=1
Vali alt Select all ja Emty selected pärast seda.
Võiksid proovida mõnda teist viirusetõrjet, nt Avast!
www.avast.com
Ka tasuline versioon saadaval.
Viirusetõrjet ja TEMP kaustade kustutamist võiksid tegelikult teha safe modes.
| Kommentaarid: 57 loe/lisa |
52 |
Muhkel
01.09.2007 07:59:56
Internetis on tihti ka kasulikke asju
Üks esimesi ettejuhtunud linke:
http://www.pcreview.co.uk/forums/thread-2710908-1.php
I solved it as follows:
Set hidden files to be visible in Windows Explorer
Go to "documents and settings/username" ie your own user name folder
using Windows Explorer
Cancel the annoying Live ID popup box
You will see a hidden folder called NetHood
Inside that folder resides an item called "My web sites on MSN"
Delete that item
And hey presto your problem is gone.
I would suggest that whats happening is that explorer is attempting to
access the MSN site to populate this list of web sites. So deleting
this shortcut to MSN cures the problem.
Looks like a clear case of the antichrist taking over my PC!!
Hope that works for you
Mike Rose
| Kommentaarid: 39 loe/lisa |
