praegune kellaaeg 12.11.2026 08:49:20
Brigadir
26.08.2007 18:41:32
probleem kettaga ( smartmontools , smartctl ) |
Viimasel ajal on hakanud ketas leebelt üteldes imelikult käituma -- vahel teeb "kolksu" häält ja kõik kettalt lugevad/kirjutavad protsessid hanguvad mõneks minutiks ning vahel teeb mitu korda järjest nii. Tegin smartctl'ga kettale testi ning lisan siia juurde. Kuigi SMART väidab - "No Errors Logged" ,siis ma siiski tean miski on mäda. vbl keegi kogenum oskab avitada.
smartctl version 5.36 [i686-pc-linux-gnu] Copyright (C) 2002-6 Bruce Allen
Home page is http://smartmontools.sourceforge.net/
=== START OF INFORMATION SECTION ===
Device Model: WDC WD3200KS-00PFB0
Serial Number: WD-WCAPD3432113
Firmware Version: 21.00M21
User Capacity: 320,072,933,376 bytes
Device is: Not in smartctl database [for details use: -P showall]
ATA Version is: 7
ATA Standard is: Exact ATA specification draft version not indicated
Local Time is: Sun Aug 26 13:00:57 2007 UTC
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status: (0x82) Offline data collection activity
was completed without error.
Auto Offline Data Collection: Enabled.
Self-test execution status: ( 121) The previous self-test completed having
the read element of the test failed.
Total time to complete Offline
data collection: (9600) seconds.
capabilities: (0x7b) SMART execute Offline immediate.
Auto Offline data collection on/off support.
Suspend Offline collection upon new
command.
Offline surface scan supported.
Self-test supported.
Conveyance Self-test supported.
Selective Self-test supported.
SMART capabilities: (0x0003) Saves SMART data before entering
power-saving mode.
Supports SMART auto save timer.
Error logging capability: (0x01) Error logging supported.
General Purpose Logging supported.
Short self-test routine
recommended polling time: ( 2) minutes.
Extended self-test routine
recommended polling time: ( 111) minutes.
Conveyance self-test routine
recommended polling time: ( 6) minutes.
SMART Attributes Data Structure revision number: 16
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE
1 Raw_Read_Error_Rate 0x000f 200 200 051 Pre-fail Always - 0
3 Spin_Up_Time 0x0003 222 181 021 Pre-fail Always - 3858
4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 303
5 Reallocated_Sector_Ct 0x0033 200 200 140 Pre-fail Always - 0
7 Seek_Error_Rate 0x000f 200 200 051 Pre-fail Always - 0
9 Power_On_Hours 0x0032 098 098 000 Old_age Always - 1857
10 Spin_Retry_Count 0x0013 100 100 051 Pre-fail Always - 0
11 Calibration_Retry_Count 0x0013 100 100 051 Pre-fail Always - 0
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 302
194 Temperature_Celsius 0x0022 109 001 000 Old_age Always - 41
196 Reallocated_Event_Count 0x0032 200 200 000 Old_age Always - 0
197 Current_Pending_Sector 0x0012 200 200 000 Old_age Always - 4
198 Offline_Uncorrectable 0x0010 200 200 000 Old_age Offline - 5
199 UDMA_CRC_Error_Count 0x003e 200 200 000 Old_age Always - 0
200 Multi_Zone_Error_Rate 0x0009 200 200 051 Pre-fail Offline - 1
SMART Error Log Version: 1
No Errors Logged
SMART Self-test log structure revision number 1
Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error
# 1 Extended offline Completed: read failure 90% 1855 342362691
SMART Selective self-test log data structure revision number 1
SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Selective self-test flags (0x0):
After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.
kuser Desktop # smartctl -q errorsonly -H -l selftest -d ata /dev/sda
# 1 Conveyance offline Completed: read failure 90% 1859 342362691
# 2 Short offline Completed: read failure 90% 1859 342362691
# 3 Short offline Completed: read failure 90% 1859 342362691
# 4 Extended offline Completed: read failure 90% 1855 342362691
_________________ Vähem möla, pikem samm! |
toivos
26.08.2007 19:25:23
Parameeter 197 näitab, et sul on Bad Sektorid.
_________________ Taastan datat katkistelt ketastelt ja katkistelt Flash(USB) mäludelt. Nüüd ka katkistelt SSD ketastelt. |
| Kommentaarid: 70 loe/lisa |
66 |
XYZ
27.08.2007 12:09:40
| "The previous self-test completed having the read element of the test failed." ---- on ka nagu üsna selgelt öeldud
| Kommentaarid: 81 loe/lisa |
12 :: |
56 |
