uus teema   vasta Hinnavaatlus »  Kasulikud näpunäited »  Kuidas muuta recycle bin nime (õpetus) märgi kõik teemad loetuks
v2hja
v2hja
sõnum 17.08.2003 13:12:06 Kuidas muuta recycle bin nime (õpetus) vasta tsitaadiga
nt "outhouse"
To do this, we're going to use the Registry Editor. Always back up your data before you use RegEdit. If you mess up, you can screw yourself. Honestly. Proceed with care.
Open RegEdit by typing "regedit" (without quotes) in the Run menu.
Open the "HKEY_CLASSES_ROOT" folder.
Open the "CLSID" folder.
Look for the folder within the brackets that starts with {645FF and open it.
Here's the full code:
{645FF040-5081-101B-9F08-00AA002F954E}
This long garble is the Recycle Bin's global unique identifier. All system file folders have 'em.
Double-click Shellfolder.
On the right side, find Attributes. Right-click Attributes and click Modify.
Change the binary value data from default 40 01 00 20 to 70 01 00 20.
Click OK and exit RegEdit.
Now, your Recycle Bin still can't be renamed by right-clicking alone (unless you're using Windows 98 ), but when you right-click and choose Explore, you can now modify it from the File menu! Voila!
Oh, and you now also have the option to delete your Recycle Bin, which isn't as dramatic as it sounds. You can still find your files in C:Recycled, and you can empty your trash from Explorer if you wish.
edit: http://www.techtv.com/screensavers/downloadoftheday/story/0,24330,3492956,00.html
www.ninjatune.net
RIP Monkey Radio
viimati muutis v2hja 17.08.2003 13:15:58, muudetud 2 korda
Kommentaarid: 74 loe/lisa Kasutajad arvavad:  :: 0 :: 3 :: 60
Hiid
Hiid
sõnum 17.08.2003 13:14:11 vasta tsitaadiga
Miks sa vahepeal inglise keelele üle läksid?
Või Copysid selle kusagilt?
Sel juhul oleks ilus viide ka siia panna.
Hapud viinamarjad
Kommentaarid: 661 loe/lisa Kasutajad arvavad:  :: 3 :: 0 :: 511
veiks
sõnum 17.08.2003 13:23:51 vasta tsitaadiga
viide on ju olemas
Kommentaarid: 9 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 6
carramba
läburaator
läburaator
carramba
sõnum 17.08.2003 13:24:33 vasta tsitaadiga
veiks kirjutas:
viide on ju olemas
irwe
Lond
sõnum 18.08.2003 05:12:53 vasta tsitaadiga
Lihtsam oleks W98 run-regedit-F3-Recycle Bin-enter-F3(esimese korraga ei tule)-enter-muuda nimi milleks tahad-enter
tommionu
tubli telepoiss
tubli telepoiss
tommionu
sõnum 20.08.2003 20:07:47 vasta tsitaadiga
Lond kirjutas:
2k puhul see ei aita kindlasti kohe (järgi proovitud) ja XP suhtes ka ei ole kindel ...
TzigaLind
sõnum 23.08.2003 01:52:14 vasta tsitaadiga
Kui register on moditud siis peab exploreri enne restartima kui nime saab muuta.(Task Manager abiks kui rebuutida ei viitsi)
Piix!
Kommentaarid: 16 loe/lisa Kasutajad arvavad:  :: 0 :: 2 :: 14
