sõnum  |
Andrus Luht
itimees.ee
| Kommentaarid: 376 loe/lisa |
318 |
Scart
19.06.2008 20:13
Mobiilse seadmega on vahetevahel huvitavad "leviaugud". Signaalitugevus on suurepärane aga mitte mingit info liikumist ei ole ja seda juhtub isegi siis, kui kõrval sarvik rahumeeli tööd edasi teha rügab ja ei tee teist nägugi. Tarkvara ega seadme enda restart ei aita, tuleb oodata 10-15 minutit ja siis on korras.
10 minutit on kõik super, siis kaob 2 minutit kogu liiklus mutiauku ja on surnud jne.
No nii ei saa ju rallit sõita!
Pinging www.ee [194.204.33.19] with 32 bytes of data:
Reply from 194.204.33.19: bytes=32 time=83ms TTL=58
Reply from 194.204.33.19: bytes=32 time=71ms TTL=58
Reply from 194.204.33.19: bytes=32 time=143ms TTL=58
Request timed out.
Request timed out.
Reply from 194.204.33.19: bytes=32 time=76ms TTL=58
Reply from 194.204.33.19: bytes=32 time=62ms TTL=58
Reply from 194.204.33.19: bytes=32 time=82ms TTL=58
Reply from 194.204.33.19: bytes=32 time=84ms TTL=58
Reply from 194.204.33.19: bytes=32 time=79ms TTL=58
Reply from 194.204.33.19: bytes=32 time=77ms TTL=58
Reply from 194.204.33.19: bytes=32 time=67ms TTL=58
Reply from 194.204.33.19: bytes=32 time=89ms TTL=58
Reply from 194.204.33.19: bytes=32 time=91ms TTL=58
Reply from 194.204.33.19: bytes=32 time=57ms TTL=58
Reply from 194.204.33.19: bytes=32 time=75ms TTL=58
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Reply from 194.204.33.19: bytes=32 time=70ms TTL=58
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Reply from 194.204.33.19: bytes=32 time=291ms TTL=58
Request timed out.
Request timed out.
Request timed out.
Ping statistics for 194.204.33.19:
Packets: Sent = 55, Received = 27, Lost = 28 (50% loss),
Approximate round trip times in milli-seconds:
Minimum = 57ms, Maximum = 291ms, Average = 86ms
Ja nüüd suri üldse maha, niipalju siis oli õnne minu õuele
| Kommentaarid: 113 loe/lisa |
95 |
karel150
20.06.2008 06:57
| Kas kellelgi on veel probleeme cnu-680 toimima saamisega vistaga. On delli läpakas ja sellel vista peal kuid kõue sisse logides jõuan kasutaja kinnitamiseni ning ütleb et lahti ühendatud. xp-ga toimib kõik kenasti. Ideid?
Scart
20.06.2008 09:49
| karel150 kirjutas: |
| Kas kellelgi on veel probleeme cnu-680 toimima saamisega vistaga. On delli läpakas ja sellel vista peal kuid kõue sisse logides jõuan kasutaja kinnitamiseni ning ütleb et lahti ühendatud. xp-ga toimib kõik kenasti. Ideid? |
Mul on Vista Ultimaatum 64 ja peale selle totaka "looking for service" bugi otseselt muid selliseid asju pole kohanud.
Küll aga tuleb vist järeldada, et soft ise on kergelt bugine. Jääb nagu mulje, et iga 2-3 tunni tagant jookseb asi natuke end lolliks ning nõuab mitte millegi tegemist minutit viis. Näiteks sain öösel paugutada kolm roundi battlefieldis, siis pildus pingi lange ja tekkis ka pingikadu. Nii oli mõni minut ja peale seda töötas jälle täiesti korralikult. Ühel korral kukkus nett maha, signaal oli väga hea aga nett tagasi ei tulnud. Ei aidanud softis endas uus connect, ei aidanud softi restart. Pidin võtma seadme füüsiliselt USBist välja ja tagasi panema ning siis hakkas tööle.
Muidu on kõik aga täiesti super, see uus seade on väga kõva upgrade sarvikult tulles.
95 |
haldz
20.06.2008 11:09
| Scart kirjutas: |
Muidu on kõik aga täiesti super, see uus seade on väga kõva upgrade sarvikult tulles. |
Mis vana sarvikuga siis tegid
| Kommentaarid: 153 loe/lisa |
138 |
Scart
20.06.2008 11:14
| haldo kirjutas: |
Mis vana sarvikuga siis tegid  |
Kah töös. Mul on kodus 3 interneeduse sõltlast + mina ning nett on ju sarvkuga täiesti korralik, ping on lihtsalt natuke kõrge. Ma olen täiesti nõus maksma 300 krooni kuus selle eest, et saan mulle meeldival ajal kännu otsas Battlefieldi toksida.
95 |
Ivoshiee
20.06.2008 11:30
| Scart kirjutas: |
| haldo kirjutas: |
Kah töös. Mul on kodus 3 interneeduse sõltlast + mina ning nett on ju sarvkuga täiesti korralik, ping on lihtsalt natuke kõrge. Ma olen täiesti nõus maksma 300 krooni kuus selle eest, et saan mulle meeldival ajal kännu otsas Battlefieldi toksida. |
Ehk maksad 2*300.- oma ühenduste eest?
_________________ Folding@home
FAH foorum |
Scart
20.06.2008 12:03
| Ivoshiee kirjutas: |
Ehk maksad 2*300.- oma ühenduste eest? |
No maksangi ju. Sarvik on 300.- ja USB luts on 300.-. Sellepärast mainisingi, et taon hea meelega 300 jaaku, kui saan selle eest sama neti nagu linnas
95 |
haldz
20.06.2008 13:27
| Scart kirjutas: |
No maksangi ju. Sarvik on 300.- ja USB luts on 300.-. Sellepärast mainisingi, et taon hea meelega 300 jaaku, kui saan selle eest sama neti nagu linnas  |
uus koduseade võiks ka tulla aga jah sellega rahul isegi,, nagunii linnas 12mb nett
138 |
xjan
20.06.2008 13:31
Haldo - uus koduseade --- revA + wifi purki küsi Tuning.ee-st. Neid nüüd stabiilselt saada, paigaldame üldjuhul neid siiski vaid sõidukitesse ja TV neid oma müügikanalites ei müü. Kindlasti annab siiski kokkuleppele saada kui su majal rattaid all ei ole
Scart
23.06.2008 09:21
Vägisi jääb mulje, et kas raud või soft on törts toores ikkagi. Keset natuke raskemat kasutamist jääb softi signaalitugevuse aken oma refreshimisega hätta ning nett kukub maha. Ise ta üles ei tule, seade tuleb masinast eemaldada ja soft restartida, misjärel nii 5 minutit on on/ei ole ja hakkab normaalselt tööle.
Keset kasutamist sajab samuti lihtsalt maha. Panen kaks lehte sisse laadima, need lendavad pauguga ekraanile, viis sekundit hiljem panen kolmanda lehe ja netti lihtsalt pole: "looking for xxxxx" (mis =, et üldse pole väljapääsu maailma) ja ping lihtsalt teatab rahumeeli 20 sekundit seda, et "could not reach."
Ei mõista.
Nüüd ei tööta üldse mitte midagi. Ping ei saa üldse masinast välja, midagi ei tööta ja signaalitugevuseks on 1,22Mi. Ei mõista vol2. Justkui oleks too kuradi 15 sekundi connectioni droppimine tagasi, ainult, et nüüd on see aeg 5 sekundit.
Leht avaneb, loen 2 posti läbi ja vajutan backi: "looking for hinnavaatlus.ee", mis nagu üsna selgelt ütleb, et igasugune nett on maas. Sealt edasi kas keerutab barankat 10 sekundit ja leht tuleb ette või "page not found".
95 |
haldz
23.06.2008 10:00
| Scart kirjutas: |
Ei mõista.
Leht avaneb, loen 2 posti läbi ja vajutan backi: "looking for hinnavaatlus.ee", mis nagu üsna selgelt ütleb, et igasugune nett on maas. Sealt edasi kas keerutab barankat 10 sekundit ja leht tuleb ette või "page not found". |
start-> run-> cmd
ping -t neti.ee
Testi asja
138 |
loox
23.06.2008 10:06
| Mingit erilist vajadust ei ole seda vigast softi kasutada. Tavaline Windowsi dialup ühendus toimib ka (venelased kusagil foorumis soovitasid). Ahjaa, enne seda tuleb vale-cdromi pealt Launcher.exe käima tõmmata, see lülitab asja modemiks.
Scart
23.06.2008 10:22
| haldo kirjutas: |
start-> run-> cmd
ping -t neti.ee
Testi asja  |
Ühendust see üleval ei hoia, proovitud.
Loox - katsetan
EDIT: kommenteerida veel midagi eriti ei saa, aga dial-upi ühendusega võeti laksti nett üles ja hetkel töötab
95 |
23.06.2008 11:05
Scart: Asi on lihtne - igasugused eri ühenduste loomised kasutavad erinevaid AT-Commande. Ja tänase ilmaga võib täiesti lugeda see, et ei püsi ühenduse püsti tõmbamine täiskiirusel ja siis "kiiruse allakerimine". Ning veaparandus ei suuda efektiivselt vigu parandada.
Kuid see-eest püsib variant, kus ühendus aeglaselt püsti tõmmatakse ja siis kiirust järjest ülespoole keritakse ja veaparandus toimib.
211 |
Scart
23.06.2008 11:40
| tahanteada kirjutas: |
Kuid see-eest püsib variant, kus ühendus aeglaselt püsti tõmmatakse ja siis kiirust järjest ülespoole keritakse ja veaparandus toimib. |
Vale. Peale Vista enda dial-upi süsteemi peale kolimist töötab kõik nagu siidi ja ühendus ei kao muti kaevatud auku. Prooviks lasin uuesti KÕU enda softi üles ja 5 minutiga oli asi ribadeks.
95 |
Duckhead
23.06.2008 12:55
Scart, kas jutt käib portatiivsest seadmest?
_________________ ÄRA KOORMA PENSIONIKASSAT, SURE ÕIGEAEGSELT!!! |
| Kommentaarid: 74 loe/lisa |
68 |
Scart
23.06.2008 13:12
| Duckhead kirjutas: |
| Scart, kas jutt käib portatiivsest seadmest? |
Ikka jah. USBi käiv uus seade, mis nüüd suve alguses müüki tuli.
95 |
23.06.2008 14:30
Scart: Ära siis valesti loe KÕU-tarkvara tõmbab Sul kiirel kiirusel ühenduse püsti ja siis see ei püsi. Windowsi enda Dial-Up kasutab enda sisse (aeglasema käsuga) kodeeringut ja sellega tõmmatakse ühendus püsti aeglasemal kiirusel.
See on näha ka muude Dial-Up ühenduste korral. Tegin Sinu rõõmuks Mobiilinterneti Dial-Upiga selle katse läbi. Ilusti on näha, et telefoni enda Dial-Upiga on ühenduse AT-Command High. Käivitades aga Windowsi enda Dial-Up kaudu on ühenduse loomise AT-Command Low.
Olen muidugi mastile lähedal - seetõttu töötavad nii High kui Low. Kui ma läppariga metsa läheks, siis selle ilmaga ma telefoni Dial-Uppi kasutada selle High käsu pärast ei saaks. Tuleks kasutada Win-i enda Dial-Uppi, millel on vastav Command Low.
211 |
arvutisõber
23.06.2008 14:49
Muide mul on nõnda, et antenni asukohta tuleb suhteliselt tihti muuta... Et näiteks panen arvuti käima, loon ühenduse ja signaal on 614.4K kandis, siis liigutan antenni ja natuke katsetan ning enamasti õnnestub saada signaali tugevus vähemalt 1.228M kanti (hetkel pendeldab 1.536M ja 1.843M vahel).
_________________ ... |
| Kommentaarid: 55 loe/lisa |
53 |
Scart
23.06.2008 19:26
Scart: Ära siis valesti loe KÕU-tarkvara tõmbab Sul kiirel kiirusel ühenduse püsti ja siis see ei püsi. Windowsi enda Dial-Up kasutab enda sisse (aeglasema käsuga) kodeeringut ja sellega tõmmatakse ühendus püsti aeglasemal kiirusel. |
No kuule! Hetkel on täpselt sama kiirus nii KÕU enda softi kui ka Windowsi dial-upiga. 60-70 kilo alla ja ping on 50-60.
Vahe on selles, et Vista dial-up pole kordagi hangunud ega kinni jooksnud ja rokib maja.
95 |
23.06.2008 21:12
Scart: V2ike kysimus: Kas RAS1000-det m2letad. Mismoodi k2itus, kui Dial-Up toimus fikseeritud kiirusel 19 kilobitti. Kas ei saanud yldse yhendust pysti v6i to'o'tas m6ned minutid suurte erroritega.
Luues aga yhenduse fikseeritud kiirusel a 9,6-16,8 kilo, oli yhendus igapidi OK. Ei mingeid katkestusi ega mahaviskamisi.
Sama kehtib ka igasugu raadioyhenduste korral, et kui suuremal kiirusel, kui eeter v6imaldab, siis visatakse su yhendus maha.
Postitatud mobile device
211 |
RCC
23.06.2008 22:36
a sa tuviposti mäletad? kuidas käitus kui üritasid mitut tuvi korraga saata, no ei saanud a ükshaaval saatsid siis jõudsid ikka kohale
_________________ O: servers//hdd. Oh netiaeg oh netiaeg, millal sina hajaasustuspiirkonda tuled?!? |
| Kommentaarid: 182 loe/lisa |
8 :: |
145 |
lokuta
23.06.2008 22:53
minu meelest oli kiirem pudelipost
| Kommentaarid: 91 loe/lisa |
79 |
mks
24.06.2008 13:48
wtf... Kõu on mõnus... downspeed on häirivalt aeglane, aga upspeed üllatab
| Kommentaarid: 11 loe/lisa |
9 |
