Pole nüüd kindel, kas see on õige teema.
Igatahes probleem selline, et installisin nvidia geforce experience´i, aga millegipärast ei leia ta mul enam CS GO-d ülesse. Samas LFD2 leiab ilusti, eile kui installisin programmi siis korra leidis GO ülesse, peale restarti enam ei leia. Proovisin ka ise muuta asukohta kust ta otsib, aga ei midagi. Programmi reinstallimine ka ei aidanud midagi.
The following sections list the important changes and the most common issues resolved since version 334.89. This list is only a subset of the total number of changes made in this driver version. The NVIDIA bug number is provided for reference. Windows Vista/Windows 7/Windows 8/Windows 8.1 Fixed Issues
[NVIDIA Inspector]: V-SYNC does not work if FPS Limiter is enabled. [1467316]
[3D Vision][G-SYNC capable displays]: With stereoscopic 3D enabled, screen issues occur when running some DirectX 11 applications in windowed mode on G-SYNC capable displays. [1451395]
[3D Vision]: The NVIDIA Control Panel->Set Up Stereoscopic 3d->View Compatibility with Games page does not show updated game ratings. [1452179]
[Surround]: In Surround mode, the process of moving windows or minimizing/maximizing windows is sluggish. [1449016]
[Surround][GeForce GTX TITAN]: Windows maximize across all three monitors in 2D Surround mode instead of one. [1421034]
[SLI][Diablo III Patch 2.0.1]: The game frame rate drops with SLI and the Reflections game setting enabled. [1469204]
[SLI][GeForce GTX 690][DOTA 2]: The game chat area flickers with SLI enabled. [1399587/1456817]
[SLI][Surround][GeForce GTX 660 Ti]: The Surround accessory monitor desktop color and player color settings get adjusted instead of monitors in the Surround configuration. [1396022]
Additional Details:
Installs new PhysX System Software 9.13.1220
Installs HD Audio v1.3.30.1
Installs GeForce Experience 1.8.2.1
Nvidia has announced that as of the Release 343 GeForce graphics drivers, they will be dropping support for a range of legacy cards, including the majority of the GeForce 8, 9, 100, 200 and 300 series, as well as the GeForce 405.
After Release 340, any subsequent Windows driver release starting with Release 343 will cease to support the products listed in this section.
The Release 340 drivers will continue to support these products until April 1, 2016, and the NVIDIA support team will continue to address driver issues for these products in driver branches up to and including Release 340. However, future driver enhancements and optimizations in driver releases after Release 340 will not support these products.
kesse naljanina adaptive power management jura välja mõtles??? mitu pikka aega vaevlesin absoluutselt mittetoimiva rocksmithi käes (graafikat sisuliselt mitte omav mäng). kaardivahetust ei mõõdeta enam mitte FPS vaid FPM. kiire kuugeldamine ka midagi ei andnud, peale õhe vihje, kus keegi oli mingit asja sättind application mingit asja mängule. siis vaatasin enda settingud üle ja tuleb ette mingi power management ja default väärtuseks loomulikult shit performance. õnneks sai selle prefer maximum performance peale sättida ja nüüd korras. enne kahtlustasin, et sai uus SSD sisse pandud ja sinna peale pagefile tehtud, aga selle eemaldamine ei muutnud absoluutselt mitte midagi.
Selline pull, et viimasel ajal on hakanud mõned mängud fps dropide all hakanud kannatama. Proovisin ka drivereid reinstallida, kui ei mõiganud. Tõenäoliselt on asi videos, sest rami on veel üle ja CPU usage pole ka nii kõrge. Samuti lasin alles suruõhuga arvuti puhtaks, temperatuurid on täitsa kenad. Ei tea kas peaks mingit vanemat video driverit proovima clean installiga? Kui mõni mäng jookseb, siis isegi windowsi aknaid ei suudeta sujuvalt liigutada. Videokaardiks on GTX 560M
Jõuluime on sündinud! Paar päeva tagasi avaldatud 347.09 lahendab lõpuks ära aastaid vana probleemi, kus videokaart saadab HDMI või DP kaudu monitorile ainult limiteeritud (16-235) ulatusega värvid/toonid. Nüüd saab paneelist käsitsi täisulatuse peale väänata. _________________ Press A to disagree.
<Too late!>
Avastasin eile enda jaoks selle GeForce experience-s saab mängude jaoks optimaalseid settinguid panna ja selle Nvidia DSR-ga resolutsiooni suuremaks panna kui su monitor võimaldab.Iseasi kas ta nüüd reaalselt tekitab ka nii kõrge reso nagu seal pakutakse,peale 1920X1080 on seal veel siis vähemalt minul võimalik panna mängud jooksma 2715X1527 ja 3840X2160 osadel mängudel pakub ka 2560X1440 lahendust. Proovisin eile Unity-ga seda 2715X1527 reso,high seaded ja Antialiasing FXAA ja ambient occlusion SSAO pilt läks ilusamaks küll ja lippas ka päris hästi Selles mõttes päris huvitav lahendus Nvidialt
panin ka uusima driveri oma GTX580 jaoks peale ära, eks näis mis saab. see DSR on äge vidin, aga annab parema effekti monitoridel, millel tolle rohkem ja DPI madalam. mul läksid mängud koledamaks 21.5 tollisel 1080p monitoril, tekstuurid pisut selgemad, aga üldiselt oli värk udusem kõvasti. profiilimonitor võttis 2560x1440p ilusti omaks _________________
Vaatasin praegu järgi ja ainult bf4 mängul laseb midagi üle 2500 reso panna Kahjuks proovida praegu ei saa, sest serverid maas. Kas fps muutub selle kõrgema resoga madalamaks ka?
Mul see geforce exerience laseb ainult bf4-l panna 2715x1527dsr. Muudel mängudel seda võimalust pole ja millegi pärast ei leia paari mängu üldse see proge üles.
Mul ei leia millegipärast origini ülesse,aga seal kus on preferences ehk settingud on võimalik käsitsi ka need mängud enda arvutist ülesse otsida.seal on mingi pluss märk millele klikkides saad ise otsida vms... ta annab sulle lingi mis mängud on toetatud ka...uuri ja tee proovi kui huvitab GTX970 peaks jõudu küll olema et suurematel resodel mänge vedada .. isegi kui peaks mingid efekte seaded veits vähemaks võtma on pilt ilus ikka ,Unity jooksis mul päris hästi 2715X1527 resol
Proovisin nüüd grid autosporti kõrgemal resol ja kõik menu tekst ja üldse mäng läks üliteravaks ja ilusaks. Enam ei taha 1920x1080 resol üldse seda mängu mängida, aga muidugi kõrgema resoga fps kukub väga kolinal Millegi pärast bf4-s läheb pilt kehvemaks kõrgema resoga. Kas nüüd ongi nii, et polegi vaja suurema resoga monitori osta, kui selline võimalus tehtud nvidia poolt?
