sõnum  |
Gap
| Kommentaarid: 17 loe/lisa |
omgwtf
16.07.2009 15:07
Päris omapärane asi vist lisatud
Igatahes proovin kohe ära
It's a new entry in the application based 3D settings. You can choose between "adaptive" and "maximum performance".
Basically, "adaptive" seems to allow the card to run with the clock settings specified for low power 3D (at least, that's what it is called in RivaTuner), if the application doesn't use all the card's power.
"Maximum performance" forces the card to run at maximum clock speeds no matter how much power the app actually needs.
This sounds like a useful feature for older games and applications such as video players, which are recognized as 3D accelerated apps but actually only use a fraction of the card's horsepower. My TV app for example used to run at full 3D clocks (670/1500/1250 MHz), while with the new drivers the clocks stay at 400/800/300 MHz. |
137 |
16.07.2009 15:09
| omgwtf kirjutas: |
Ketserlus ma ütlen .Tomorrow jooksutab alati @ Max Perf .Alati
_________________ Müüa 32GB DDR4 mälu |
| Kommentaarid: 83 loe/lisa |
73 |
Auron
16.07.2009 17:10
| Hmm, aga kas peab tingimata valima või kuipanna see low app ja lasta tööle midagi nõudvamata siis overrideb automatselt? Iseenesest arvestades miuksed õgardid on praeguse aja high end kaardid siis automaatne downclock võiks olla küll nagu prosedelgi.
123 |
kaitsevaim
16.07.2009 17:29
no ma ei viitsind kõiki 76 lehte läbi vaadata, aga kas keegi on midagi sellist vaadanud nagu www.driverpacks.net. Forceware draivereid saab ka näiteks sellisest kohast, nagu www.filehippo.com. Seal kõik versioonid kah otsast lõpuni, vali millist tahad.
| Kommentaarid: 28 loe/lisa |
22 |
omgwtf
137 |
Mumbles
22.07.2009 14:15
Ja jälle on aeg oma draivereid uuendada.
NVIDIA GeForce v190.38 WHQL
http://www.nvidia.com/Download/index.aspx?lang=en-us
New in Release 190.38
Adds support for OpenGL 3.1
Adds support for CUDA 2.3 for improved performance in GPU Computing applications.
Includes several new control panel features and numerous bug fixes.
P.S. Väike erinevus juba installikas, peale installi või katkestamist, kustutatakse
ajutisest C:\NVIDIA.... kataloogist ka oma kola ära.
Õhtul kodus uurin, kas nad oma installikas ka ülejäänud korda teinud on,
et keemikut jälle mängima ei peaks
| Kommentaarid: 73 loe/lisa |
60 |
22.07.2009 16:24
| Mumbles kirjutas: |
et keemikut jälle mängima ei peaks  |
Igatahes 190.38 BETA jõudlus oli küll kehv.Crysis Wars FPS kukkus lampi ämbrisse ja rohi hakkas virvendama.Miskipärast ei usu eriti,et WHQL märk nüüd need probleemid parandab .Jään edasi 186.18 WHQL peale
73 |
Gap
22.07.2009 22:58
| Mumbles kirjutas: |
no aga anna teada kuidas läks siis teab tegutseda mingit keemikut vast mängida pole vaja, lihtsalt kui midagi muudetakse ilma teadmata teed ju ikka nii nagu oled harjunud tegema .... lihtsalt nüüd ka tean et see krdi Physx tuleb sealt välja võtta ja kui nad on driveritele ikka kõik failid kaasa pannud siis läheb kõik ilusti.
tundub endale ka et see 190.38 BETA jõdlus midagi väärt ei ole
WäntWõll
make.believe
23.07.2009 13:45
Kas eegi mäletab mis olid või on jõudluse poolest parimad G92 seeria kaartidele
293 |
23.07.2009 14:09
| wanawoll kirjutas: |
Kas eegi mäletab mis olid või on jõudluse poolest parimad G92 seeria kaartidele  |
No G80 seeria driverijõudluse poolest nö "tipp" oli imo kuskil 179 seeria kandis seega G92 oma peaks kuskil 182 kandis olema kuigi ega need nii vanad veel pole.Üldiselt võta 186.18 WHQL.Minul on see heast küljest ennast näidanud.Uus 190.38 polevat eriti hea ja betaga oli mul mitmeid probleeme(kahtlen,et WHQL märk need parandas).
Muidu see suht vana ja 7 seeriaga aga pre-180 seeria kohta ehk midagi näitab: http://www.alcomsplace.com/ut3_bench_forceware_drivers.htm#table
73 |
WäntWõll
make.believe
23.07.2009 14:25
tomorrow, sänks proovin ära
293 |
omgwtf
29.07.2009 13:02
GeForce ForceWare 190.40
Vista W7 64Bit- http://downloads.guru3d.com/GeForce-ForceWare-190.40-Win-7-|-Vista-%2864-bit%29-download-2336.html
Vista W7 32bit- http://downloads.guru3d.com/GeForce-ForceWare-190.40-Win-7-|-Vista-%2832-bit%29-download-2335.html
Xp 32bit- http://downloads.guru3d.com/GeForce-ForceWare-190.40-XP-%2832-bit%29-download-2334.html
Mingi vennike lasi Crysise benchi(ei tea ainult mis kaardiga )
190.38 WHQL
WiC : 45/14/110
# Total Frames: 2440, Total Time: 51,02s
# Average Framerate: 47,83
# Max. Framerate: 84,08 (Frame:0, 0,01s)
# Min. Framerate: 34,87 (Frame:1868, 39,17s
RE5 = 98.1
190.40
WiC : 49/9/111
* Total Frames: 3182, Total Time: 51,01s
* Average Framerate: 62,38
* Max. Framerate: 88,76 (Frame:495, 6,71s)
* Min. Framerate: 47,31 (Frame:2456, 39,14s)
RE5 = 97.5
Ei tea kui tõene Eks vaatab pärast ehk proovin ää.. Kuigi paljud halavad,et suht bugised need hetkel
Mingi arutelu moodu asi http://forums.guru3d.com/showthread.php?t=301163
137 |
Killerwave
31 |
Gap
04.08.2009 15:02
on keegi jõudnud proovida ka neid viimaseid et kuidas on ? need eelmised 190.38 ja 190.40 mulle ei meeldinud millegipärast oli nii mõnes mängus kohutav lag ja Fallout3 millegipärast jõnksutas kohutavalt ja GTA IV mõnes kohas pilt vilkus mõnusalt ei tea milles asi, aga panin 186.18 peale tagasi ja asi on korras .... need praegused Nvidia driverid lähevad kuidagi allmäge praegu ...ehk tuleb varsti paremaid
sry aga misasi see OpenGL on ja kas ta annab mängudes midagi juurde või milleks see vajalik on ? ehk keegi oskab mulle seletada eesti keeles mis asi see on ?
73 |
Evil
Hull
10.08.2009 21:53
Mul 190.38 peal ja XP-ga armastab segast peksta, aeg ajalt graafilised vead peale loadimist ja crysis on kinni jooksnud. Maybe vajan uut windowsit. Teisi drivereid proovima.
| Kommentaarid: 214 loe/lisa |
180 |
10.08.2009 23:34
| Evil kirjutas: |
Mul 190.38 peal ja XP-ga armastab segast peksta, aeg ajalt graafilised vead peale loadimist ja crysis on kinni jooksnud. Maybe vajan uut windowsit. Teisi drivereid proovima.  |
186.18 WHQL
73 |
HDTanel
Overclocker
11.08.2009 13:01
tomorrow, just, need 190 betad on kahtlased praegu.
edit: lol, mul 190.38 vista64-l peal
_________________ Minu Youtube - HDTanel <- EESTIKEELSED VIDEO ÜLEVAATED!
Minu Facebook - HDTanel
Minu Twitch - HDTanelEST |
| Kommentaarid: 628 loe/lisa |
491 |
Evil14
11.08.2009 15:49
Ei tea millal küll midagi korralikku 19x seeriast oodata on Alati uuendan tuhinaga drivud ära et ohh midagi uut ja korralikumat kui eelmised, aga võta näpust, kaka saab hoopis.
| Kommentaarid: 205 loe/lisa |
183 |
11.08.2009 15:50
| Evil14 kirjutas: |
Ei tea millal küll midagi korralikku 19x seeriast oodata on Alati uuendan tuhinaga drivud ära et ohh midagi uut ja korralikumat kui eelmised, aga võta näpust, kaka saab hoopis. |
Ma ise ootan järgmise 190 seeria WHQL-i ära.Eks siis näis kuigi ega ma eriti ei looda
73 |
miq1988
11.08.2009 15:56
| tomorrow kirjutas: |
186.18 WHQL  |
Sellele asendust ?
fallout 3 kuidagi nagu jõnkaks ja võrreldes mingite XXX.XX vanade mudelitega üks netimäng ka nagu ei ole nii sujuv kui enne.
| Kommentaarid: 10 loe/lisa |
10 |
Evil14
11.08.2009 15:59
| 190.38 WHQL, mis mul moendil peal, küll eriti ei rõõmusta. But lets hope and wait.
183 |
Cb4
12.08.2009 08:50
Ma istun vabsee 182.50 peal Rivatuner ei toeta kahjuks uuemaid
_________________ Ma ei ole agressiivne juht, olen lihtsalt võistlushimuline.
Did i ever tell you the definition of "Insanity"? |
94 |
12.08.2009 11:47
| Cb4 kirjutas: |
Ma istun vabsee 182.50 peal Rivatuner ei toeta kahjuks uuemaid  |
*Pane Rivatuner käima
*Vali Power User
*Rivatuner/System(vajuta + et laiendada)
*ForceDriverVersion siseta toetamata driveri number.nt 186.18 sisesta 18618 kujul
*Pane Rivatuner kinni ja käima uuesti.Nüüd näitab akna ülemises otsas Driver Emulation Mode
*Nüüd saad kaarti klokkida
Loodetavasti on abiks
Pilt kah:
73 |
