praegune kellaaeg 27.06.2026 03:41:34
matux
15.04.2007 16:38:00
New Folder tegemise bug... |
Vabandan, kui on juba sellest siin räägitud, aga leidsin netist ühe huvitava fakti...
Nimelt Windows-is ei saa panna uuele kaustale nimeks "con". Selle tegemisel muudab ta lihtsalt folderi tagasi
"New Folder-i" nimeliseks. Selline tühine asi, aga kuumaline siiski. Proovige järgi...
Lisalugemist:
"The bug has been tried and tested in both Windows XP Home and Professional. If you try to make a folder named "CON" (case insensitive), Windows XP renames it back to what it was. So creating a new folder with the name "CON" just renames it to "New Folder".
The bug seems like a variable that got treated as a string or vice-versa. Trying to create the folder from a cmd prompt failed with an error "The directory name is invalid.".
This also works when you try to create a file called "CON", or "CON.". ".CON" shows up the way it should.
If you create a folder named "CON" on a linux filesystem say, and open up a samba share of it, the "CON" directory shows up as being "CSHOFG~F". A "CON." file or folder shows up as "CRW2KU~B"! Very Strange!
Somebody at Microsoft willing to explain?"
| Kommentaarid: 39 loe/lisa |
36 |
wader
15.04.2007 16:49:45
CON on reserveeritud sõna, samamoodi nagu AUX, COM1, COM2, COM3, COM4, LPT1, LPT2, LPT3, PRN, NUL. Ajalugu dos'i ajast, kus CON tähendas konsooli.
Tegemist ei ole bugiga.
Edit: http://www.microsoft.com/technet/prodtechnol/winxppro/reskit/c13621675.mspx#EEIBG
| Kommentaarid: 4 loe/lisa |
Tbit
15.04.2007 19:24:21
ja nii ta on, kanged mehed igal pool kangetes ftp servudes tegid com1-lpt3-... jne
|OSTAN|-> T43 pikk jahutus |
230 |
JOKKER666
17.04.2007 12:34:00
| selle con iga sai kuidagi bluescreeni ka ette manada
| Kommentaarid: 47 loe/lisa |
42 |
artur-
17.04.2007 12:35:39
| JOKKER666 kirjutas: |
| selle con iga sai kuidagi bluescreeni ka ette manada |
Mui ma nüüd õigesti mäletan siis win98 runni kirjutada concon ja bsod peaks ette tulema. 98SE ei töödand aga tava 98ga vist küll.
Kellel 98 on proovigu järgi.
| Kommentaarid: 82 loe/lisa |
72 |
