praegune kellaaeg 26.10.2026 00:26:04
Celeron
12.04.2007 00:01:00
Protsessori vahetus Toshiba laptopis |
Tere
Ehk on kellelgi teadmisi, kui raske on Toshiba Satellite 1200-S121 prose vahetamine.
Kas seda on üldse võimalik vahetada? Mõnedel juhtudel on ju prose emaplaadile tinutatud
Prose ise on selline:
Field Value
CPU Properties
CPU Type Mobile Intel Celeron-S, 1200 MHz (9 x 133)
CPU Alias Tualatin, A80530
CPU Stepping A1
Instruction Set x86, MMX, SSE
Original Clock 1200 MHz
L1 Code Cache 16 KB
L1 Data Cache 16 KB
L2 Cache 256 KB (On-Die, ATC, Full-Speed) |
Field Value
CPUID Properties
CPUID Manufacturer GenuineIntel
CPUID CPU Name Intel(R) Celeron(TM) CPU 1200MHz
CPUID Revision 000006B1h
IA Brand ID FBh (Intel Celeron-S)
Platform ID 05h / MC 20h (Mobile uPGA2)
IA CPU Serial Number Unknown
Microcode Update Revision 1D
HTT / CMP Units 0 / 0 |
Tänan
| Kommentaarid: 41 loe/lisa |
33 |
Mihkel.
| Kommentaarid: 92 loe/lisa |
Celeron
12.04.2007 00:09:40
MiXeR, tänan
Paistab, et s370 uuendamisel pole mõtet
33 |
