praegune kellaaeg 16.10.2026 16:46:17
xhop
17.03.2007 12:40:30
Format C ja kahtlane kaust [LAHENDATUD] |
Esimene küsimus:
Mul on arvutis 2 ketast. Kui ma teen windowsi kettale (master) formati ja installin uuesti windowse (xp) peale, kas siis säilivad kõik failid, mis olid teise ketta peal ?
Ja kas windows tuvastab ikka peale formatit teist ketast ära nii, et ma saaks kohe siis failid kätte mitte ei peaks formaatima hakkama ?
Teine küsimus:
Mu teise ketta peale tekkis imelik kaust: b2e0fdcedf3.
Sees on sellised kaustad/failid:
Volume in drive F is F
Volume Serial Number is 80E6-C2AD
Directory of F:\b2e0fdcedf3
17.03.2007 10:32 <DIR> .
17.03.2007 10:32 <DIR> ..
17.03.2007 10:22 <DIR> common
17.03.2007 10:22 <DIR> sp1
17.03.2007 10:22 <DIR> sp2
0 File(s) 0 bytes
Directory of F:\b2e0fdcedf3\common
17.03.2007 10:22 <DIR> .
17.03.2007 10:22 <DIR> ..
27.02.2002 16:58 4ÿ092 eula.txt
21.09.2002 12:44 10ÿ752 spcustom.dll
06.09.2002 15:54 4ÿ608 spmsg.dll
21.09.2002 12:44 46ÿ080 spuninst.exe
21.09.2002 12:44 273ÿ408 update.exe
5 File(s) 338ÿ940 bytes
Directory of F:\b2e0fdcedf3\sp1
15.11.2001 16:27 5ÿ149 empty.cat
19.09.2002 11:27 126ÿ464 shmedia.dll
17.03.2007 10:22 <DIR> symbols
17.03.2007 10:22 <DIR> update
2 File(s) 131ÿ613 bytes
Directory of F:\b2e0fdcedf3\sp1\symbols
17.03.2007 10:22 <DIR> dll
0 File(s) 0 bytes
Directory of F:\b2e0fdcedf3\sp1\symbols\dll
18.09.2002 17:17 205ÿ824 shmedia.pdb
1 File(s) 205ÿ824 bytes
Directory of F:\b2e0fdcedf3\sp1\update
19.09.2002 11:49 7ÿ658 q329390.cat
19.09.2002 11:26 34ÿ074 update.inf
19.09.2002 11:57 88 update.ver
3 File(s) 41ÿ820 bytes
Directory of F:\b2e0fdcedf3\sp2
30.09.2002 10:58 125ÿ440 shmedia.dll
1 File(s) 125ÿ440 bytes
Directory of F:\b2e0fdcedf3\sp2\symbols
0 File(s) 0 bytes
Directory of F:\b2e0fdcedf3\sp2\symbols\dll
24.09.2002 09:27 205ÿ824 shmedia.pdb
Directory of F:\b2e0fdcedf3\sp2\update
30.09.2002 11:36 7ÿ658 q329390.cat
30.09.2002 10:58 3ÿ499 update.inf
30.09.2002 10:58 88 update.ver
3 File(s) 11ÿ245 bytes
Total Files Listed:
16 File(s) 1ÿ060ÿ706 bytes
29 Dir(s) 97ÿ955ÿ766ÿ272 bytes free
Kustutada ei saa.. Aga samas ka viirust ei leia.
Edit:
Leidsin midagi imelikku..
Kas need peavadki nii olema ?
Pilt: http://img142.imageshack.us/my.php?image=kahtlanecb4.gif
Kiire!
viimati muutis xhop 17.03.2007 23:13:45, muudetud 1 kord |
tsihh
17.03.2007 14:34:28
Jah, kui ainult süsteemikettale formati teed, siis pääsed ligi oma failidele teisel kettal (kui just pole teisel kettal failid krüpteeritud)
Windows tekitab uuenduste käigus omale temp failide jaoks kataloogid otse juurikasse, hiljem peaks need ära kaduma sealt. Kui ei kao, siis peale restarti võib need tavaliselt ära kustutada (et päris kindel olla siis enne kustutamist võid ka lihtsalt ümber nimetada või teisaldada)
Seal pildil pole midagi imelikku, XP näitabki installeeritud uuendusi add/remove'i all
| Kommentaarid: 59 loe/lisa |
58 |
