otsik
31.12.2006 00:55:24
Trojan PSW x.vir |
Eile õhtul downloadisin endale paar mitte vajalikku asja uisapäisa. Trojan viirus sees. Tegin AVG'ga scanni üle kuid mitte midagi ei leidnud.
Mida edasi teha?
_________________ fc.soccernet.ee |
Kommentaarid: 5 loe/lisa |
benon
31.12.2006 02:05:35
Mina kasutaks veel Spybot ja mõnd online scannerit. Nende abiga olen pea kõigist lahti saanud, kui keegi on juhtund sisse pugema. Kui päris lahti ei saa, siis heal juhul saab vähemalt nime teada ja siis Google abiga saab ikka lahti.
Siin targemad mehed õpetavad kindlasti täpsemalt
_________________ dumbuser! |
okas5
31.12.2006 02:08:29
Proovi kaspersky ja spysweeperiga. AVG võid omal teadküllkuhu pista
_________________ Võtan suurtes kogustes tagastamata laenu ja muid vidinaid. Kõik pakkumised PSi  |
Kommentaarid: 11 loe/lisa |
Mario.
31.12.2006 02:12:20
1. Download and save http://martijnc.be/tools/roguescanfix_setup.exe to your desktop; when complete, double-click the program to begin installation.
2. Choose desired language from the drop down menu. Press the Next until the Install button is available.
3. A window will appear. Leave a checkmark next to Launch RogueScanFix and press the Finish.
4. RogueScanFix will then launch; press the spacebar to start the removal process.
Note that RogueScanFix will download additional files during cleanup. Internet connection is necessary. If your firewall alerts you of this activity, allow the download to complete.
5. During the cleaning process, desktop will disappear. This is normal. Infections will then begin to uninstall.
6. When RogueScanFix is complete, a window will appear that the script execution has finished. It may uninstall related files and registry keys. Wait for the process to finish and you may need to reboot your computer.
Kommentaarid: 274 loe/lisa |
6 :: |
217 |
otsik
31.12.2006 02:16:54
Tänud aitamise eest praegu, kuid nüüd ta ütleb mulle, et see on "back door Trojan". Pole varem viirustega kokkupuutunud ning äkki sellepärast ei leiagi viiruse programm üles seda?
Mario.
31.12.2006 02:21:11
back door trojan - ehk mõeldud kasutama just teatud turvaauku jne et levida vms. Aga tegid õpetuse järgi?
6 :: |
217 |
benon
otsik
31.12.2006 03:12:45
Kuidas rebootimine käib, minu viga kui liiga arutu küsimus on?
Mario.
31.12.2006 04:08:02
reboot on restart
6 :: |
217 |
okas5
31.12.2006 15:15:07
otsik kirjutas: |
Kuidas rebootimine käib, minu viga kui liiga arutu küsimus on? |
Midagi nii naljakat pole juba ammu lugeda saanud kuskilt
Anti
05.01.2007 04:33:04
Päris koom jah
Kasutaja Otsiku puhul on tegemist minu vennaga. Nüüdseks asi korda aetud ja pahalased minema kupatatud
Kommentaarid: 314 loe/lisa |
240 |
lisa lemmikuks |
