praegune kellaaeg 24.10.2026 09:18:45
Deep Fury
24.01.2003 10:53:03
Sygate Pro 5.0 firewalli augud |
Noh, osadel tulemüüritegijatel ikka jätkubseda va "andekust" ;(
Issue : Full access to open udp ports with Sygate Pro 5.0
Vendor status : vendor was contacted but got no response
from them
Description:
Sygate Pro is a personal firewall very easy to configure.No rules
are installed in a default configuration.A default installation pretends
to be enough to block all accesses to your ports.
By default , traffic from udp source port 137 or 138 is allowed by
the firewall , so to bypass it you just have to set your source port
to 137 or 138.Doing this all packets addressed to an open udp port
will be forwarded by the firewall
Attack :
nmap -vv -P0 -sU 192.168.0.1 -g 137
Recommendation :
Set a rule to block all incoming udp traffic with source
port 137 and 138
Regards,
David Fernandez Madrid,
Madrid,Spain
Robot
Bännitud
