Cromaclear
23.10.2007 13:23:22
Nba live 08 |
http://www.easports.com/nbalive08/
PS2 | PS3 | PSP | X360 | WII | PC
Nba lasi siis järiekordse NBA oma seerias välja.
Release Date: Oct 30, 2007
Release Region: North America
Release Date: Oct 26, 2007
Release Region: Europe
Release Date: Oct 25, 2007
Release Region: Australia
Konsoolide release oli varem, ehk on loota siis tavalist konsooli pealt pc peale käkerdist?
Providing an unrivaled level of authenticity, NBA LIVE 08
introduces hot spots, using real NBA shot data to illuminate the
locations on the floor where your players are most effective
Couple this with all-new signature go-to moves that capture the
essence of the NBA's best, and you can now play the game on a
console like you see it from the stands
All-new quickstrike ball-handling: Whether you're pushing the
ball upcourt or backing down a defender inside, quicker, more
responsive ball-handling moves allow you to break down opponents
and take complete control of your game
Own the paint: Put the ball in the hands of your big men and go
head-to-head in the lane. With all-new moves and counters,
including pump fakes, drop-steps, and spins, post play has never
been better
Hot and cold: Use the actual NBA shot tracking data to know who
to feed and who to defend. An all-new on-screen overlay shows
you exactly where a player is most dangerous
Go-to moves: Every player has a go-to move that they
consistently go to when the game is on the line. Now the
signature go-to moves of the NBA's best players have been
realistically re-created to help you score when it counts. That
patented step back jumper? A fadeaway with the big leg kick? If
it's in the game, it's in the game
New look and feel: 5-on-5 gameplay has never looked so good. The
game features enhanced player spacing and behavior logic in the
half-court, upgraded passing and rebounding mechanics, and an
all-new two player interaction engine
All-new shooting mechanics: From deep three-point shots well
beyond the arc to 10-foot jump shots in the paint, every shot
attempt has been redesigned to provide more fluid, realistic
results. Dunks and lay-ups are now assigned to the same button
command making highlight reel plays even easier to perform
The NBA goes live: Player faces, team uniforms, and authentic
arenas jump to life behind the power of next-generation game
graphics. Whether you're working on your game in the revamped
practice gym, or playing in front of a packed house, feel what
it's like to be an NBA superstar
Like butter: Running at a smooth 60 frames per second, NBA LIVE
08 is as close as you can get to the court, without dropping a
dime for courtside seats
Samas asi on juba torrenti ja warez saitidel üleval. Paari tunni pärast annan enda hinnangu mängust
_________________ BF3 platoon : http://battlelog.battlefield.com/bf3/platoon/2832655240976803519/
BF3 nick : KrisRhazta |
| Kommentaarid: 26 loe/lisa |
23 |
MONX33
25.10.2007 17:04:39
Seda jama ärge küll ostke mõttetu mäng eriti see PC expansion pack eelmisest aastast ja mäng on ka enam vähem sama nagu eelmine aasta oma ainult see aasta on mängus üks bug mis peale 1q või teist viskab mängust välja
Kui tahate tõelist kossu mängida siis hankige NBA 2k8
ups
25.10.2007 17:19:12
nba 2k8 ei ole ega tule PC-le, seega kellel konsooli pole peab ikkagi live-ga leppima.
olen vaid mõned playoffid ja fiba cupi teinud ning suht siiber arvuti vastu mängimast. all-star levelil on juba cpu tabavus haiglaselt täpne ning korvi all olgu 1 või 3 meest vastu, aga 80% juhtudel paneb tasemega ründemängija donki ära ja takistada mitte kuidagi ei õnnestu
kui keegi viitsib võrgus teha, andku märku!
_________________ Tasuta arvete koostamise süsteem: arvepesa.ee |
jako07
25.10.2007 20:09:43
Minuarust eriti jura mäng ja 2007 variant on isegi parem. 2 väidet tõestamiseks: Superstari pole enam Dunk & Lay-up sama nupu all
<<< minu arvamus, võibolla kellelegi meeldib.
| Kommentaarid: 19 loe/lisa |
19 |
rem4605
25.10.2007 20:47:57
| MONX33 kirjutas: |
Kui tahate tõelist kossu mängida siis hankige NBA 2k8  |
See bug tuleb sul sellest, et pira verisooni kasutad.
Orig. kindlasti puudub see või on tehtud juba fix.
Mulle endale meeldib muidu mäng.
Tundub reaalsem kui 07.
10-st punktist annaksin 7p.
| Kommentaarid: 21 loe/lisa |
17 |
01.11.2007 20:31:25
ei saa kahti Trust GM-1520 Dual Stick Gamepadi tööle.. keegi teab, milles põhjus võib olla?
_________________ thezone.myminicity.komm |
| Kommentaarid: 9 loe/lisa |
Cromaclear
23 |
JyrxEST
04.12.2007 15:51:56
Korviall mingi suht võimatu kaitset võtta ju...
Ja kuidas PC Logitech Rumblepad II puldiga HotSpot'te saab vaadata ??
Porno Parm
mugavuspagulane
04.12.2007 18:19:42
| JyrxEST kirjutas: |
kaitset mängitakse euroopas mitte NBAs
| Kommentaarid: 66 loe/lisa |
6 :: |
47 |
JyrxEST
05.12.2007 09:36:16
| Karm Laks kirjutas: |
| JyrxEST kirjutas: |
kaitset mängitakse euroopas mitte NBAs  |
Eurooplased mängivad kolmese taga, ameerikased mängivad korviall
Ikka suht mõttetu kuidagi kui Tim Duncan kolmesekundialas kaitsmas aga ikka mingi mängujuht tuleb ja mängib nagu pottsepp saviga
MONX33
05.12.2007 11:46:28
| JyrxEST kirjutas: |
| JyrxEST kirjutas: |
Ikka suht mõttetu kuidagi kui Tim Duncan kolmesekundialas kaitsmas aga ikka mingi mängujuht tuleb ja mängib nagu pottsepp saviga |
Vajutad kas paremat või vasakut kangi alla siis peaks see hot spot nähtavale ilmuma
JyrxEST
05.12.2007 14:09:15
| ahah, mõlemad analoogid tuleb korraga alla vajutada
MONX33
05.12.2007 14:11:47
| JyrxEST kirjutas: |
| ahah, mõlemad analoogid tuleb korraga alla vajutada |
Ei ainult üks vaata kas on parem kang või vasakpoolne, täpselt ise ei mäleta kuna mul pole seda mängu juba kuu aega olnud
JyrxEST
05.12.2007 17:33:53
ajahh aint vasakpoolne,
thx abi eest
rauninho
17.12.2007 11:25:03
Proovisin ka NBA08 ära, ei midagi huvitavat minu jaoks. Tundus, et NBA2003 oli isegi parem.  Aga kossufännidele ikka meeldib, ise rohkem jalkavend.
_________________ HV positiivne!  |
| Kommentaarid: 75 loe/lisa |
68 |
Cromaclear
30.12.2007 03:19:27
| rauninho kirjutas: |
Proovisin ka NBA08 ära, ei midagi huvitavat minu jaoks. Tundus, et NBA2003 oli isegi parem.  Aga kossufännidele ikka meeldib, ise rohkem jalkavend. |
Mängi Xboxil või Ps3 seda ja sa ei taha kunagi enam arvutil mängida : D
23 |
henri200
30.12.2007 11:21:53
Cromaclear, next-gen konsoolidel on NBA 2k seeria metsiklt parem
| Kommentaarid: 62 loe/lisa |
59 |
