praegune kellaaeg 29.10.2026 08:53:30
exo
19.09.2006 13:50:28
Probleem cmdservice'ga |
Kuidagi on sattunud arvutisse selline asi. cmdservice
Kuidas lahti saab?
Spybot leiab pidevalt asju, mida ta juba on kustutanud.
Max Powers
182 |
exo
19.09.2006 14:10:55
proovisin. Kahjuks see pakutud programm ei tee midagi kasuliku.
Kustutasin registri faile aga paljusid ei lubanud kustutada, kuigi kõik aknad olid kinni.
Proovisin ka neid pakutud faile otsida aga ei leidnud.
Sain abi:
1. Go Start>>Run and type cmd, click OK
2. A black DOS screen will apppear
3. Make sure you are at the C:\> prompt . If you are not, just type cd.. as many times as required until you get here: C:\>
4. Type exactly the following commands:
a. First sc stop cmdService and press Enter
b. Then sc delete cmdService, and press enter
19.09.2006 17:08:02
Oled sa seda Safe Mode'is proovinud?
| Kommentaarid: 763 loe/lisa |
571 |
