One
18.10.2007 18:50:48
PC Mark Vantage skoorid ja arutelu |
link :: Download(File size: 665MB)
Key Benefits of PCMark Vantage:
Unparalleled ease-of-use: Single Click Benchmarking
Unified Benchmarking for desktop, laptop PCs and workstations
Newly developed to natively support 32 and 64-bit Microsoft Windows Vista
System Information tool that displays advanced system configuration information
Advanced Online Results Browser functionality with Result Analyzer |
Ehk siis välja on lastud uus PC Mark.
Siia teemasse ootaks siis erinevate arvutite skoore/tulemusi.
Ära tuleks märkida kindlasti arvuti konf ning paha ei teeks ka väike skriinshot.
System Requirements
Processor
Modern processor with SSE2 support
Intel Pentium 4 at 3.0GHz or equivalent AMD processor
Multi-core processors recommended
Graphics Card
Shader Model 2.0 compliant graphics card.
Shader Model 3.0 compliant graphics card for the GPU image manipulation test
256MB of graphics memory for the GPU gaming test recommended
Hard Disk
1.7GB of hard disk space
NTFS File System
System Memory
1024MB
Operating System
Microsoft Windows Vista® Ultimate / Home Premium / Home Basic / Enterprise / Business
Other
Windows Media Player 11
Latest DirectX Update for Windows Vista
Microsoft Internet Explorer 7 |
728 |
Lorien
19.10.2007 00:48:31
Noniih, mul siis au avada skooriderida. 3919 pcmarks.
Konf siis lühidalt järgmine:
Q6600 @2,64Ghz
2GB A-data 1000mhz+ overclock extreme mälu
asus 8800GTS 640MB
2x250GB HDD 7200rpm.
_________________ Live and let die.
| Kommentaarid: 9 loe/lisa |
symmi
19.10.2007 00:50:30
| Väga huvitav, homme kindlasti proovin ära. Kas ta teeb ka mignit dx10 testi?
| Kommentaarid: 27 loe/lisa |
25 |
WäntWõll
make.believe
19.10.2007 02:08:14
Ootan ja ootan võtit juba miski 20minutit
Aga põhi porno on see et selle trial võtmega saab lasta ainult ühe run-i
Mis edasi saab,lased maha ja teed registri tühjaks või kasutada mitmeid emaile ühe jooksu võtme saamiseks
| To qualify for a trial key, you will be required to enter a valid email address to which the registration key will be emailed to. Each email address will be allotted one (1) registration key, which will be usable for a single benchmark run. Note that you will require a functioning internet connection to be able to run the PCMark Vantage Basic Edition Trial. |
Nii Gmaili sai kohe key ja ikka õnnestub rohkem kui ühe korra seda testi jooksutada
Tulemus siis 100% pure Ati masinaga ja graafika DX9 X1950XTX
Link 3276
300 |
HDTanel
Overclocker
19.10.2007 19:22:19
Oot saab siis või ei saa? Sul kirjutatud nagu, et ühe korra tõesti saab lasta vaid.
_________________ Krüpto
Minu Youtube - HDTanel
Minu Instagram - HDTanel |
496 |
WäntWõll
make.believe
19.10.2007 19:44:02
PlatoonSgtElias,
| ot: |
Mille eest sulle sis AM õnnistati |
300 |
Draco
20.10.2007 14:41:22
Score = 3024
AMD Ahtlon 64 X2 3800+ @ 5000+ (2.0ghz @ 2.6ghz)
Ati Radeon X1950 Pro 512MB AGP stock
2x1 GB Kingston HyperX CL2.5 @ 216mhz
74GB WD Raptor 10 000rpm
_________________ Purgatory Judgement |
| Kommentaarid: 12 loe/lisa |
12 |
HDTanel
Overclocker
20.10.2007 14:43:18
| dreamx kirjutas: |
PlatoonSgtElias,
| ot: |
Okei, eks proovin kui vista peale läheb.
Sa ei taha teada
Winterwind võib öelda  |
496 |
mcaff
20.10.2007 22:59:21
4211
Setup:
Intel Core 2 Duo E6600 @3250MHz, Gigabyte P35C DS3R, 2x1GB A-Data PC2-6400 @450MHz cl5-5-5-15, XFX 8800GTS 320 MB @ 600/900MHz, Seagate Barracuda 7200.10 250 GB 16MB SATA2
Krt 1t ootasin enne kui hot´i tuli see key aga ennem regasin gmaile ära ja tuli key kohe
104 |
Lorien
21.10.2007 16:37:43
Mcaff, suht uskumatu skoor sul, võrreldes sellega, et mul on quad-core prose ja sain sellega mingi 300 p vähem Selles mõttes huvitav, et see test pidi just ju ka nelja-tuumalisi prosesid ära kasutama igati....
mcaff
21.10.2007 17:16:02
| Lorien kirjutas: |
Mcaff, suht uskumatu skoor sul, võrreldes sellega, et mul on quad-core prose ja sain sellega mingi 300 p vähem Selles mõttes huvitav, et see test pidi just ju ka nelja-tuumalisi prosesid ära kasutama igati.... |
Mul pill clockitud võibolla selle pärast aga mis mind närvi ajab on see, et ma ei sa hwboti seda tulemust üles upida...see koht kus pitl tuleb lisada on mingi fucking pla pla kiri eest
104 |
ak.90
22.10.2007 11:46:28
Eks proovib ka ära selle
188 |
symmi
28.10.2007 12:09:54
| krt mul ei näidanutki tulemust ajas mingit soga seal futuremargi lehel
25 |
M8T0
31.10.2007 10:36:57
nofak. miks on vaja kõik vista-only teha.
raipenahad. mingi aasta pärast oleks paras aeg . ei taha seda käkki veel peale panna. korra oli ja xp peale kiiresti kiiresti tagasi.
| Kommentaarid: 87 loe/lisa |
Flavius
14.08.2010 22:30:50
Lenovo ThinkPad T400
Protsessor: Intel C2D P8600 2.4GHz
Videokaart: Intel 4500MHD
Mälu: 2x2GB 1066MHz CL7
SSD: Crucial C300 64GB
OS: Windows 7 64bit
PCMark Vantage: 4849p
HDD: 25294p
Core i5 750 @ 3200MHz
2x2GB 1600MHz CL7
HD5850 @ 775/1125
Crucial C300 128GB
Windows 7 64bit
PCMark Vantage: 14866p
HDD: 26357p
118 |
Kristoferr
| Kommentaarid: 266 loe/lisa |
217 |
