Incikas
06.07.2006 17:03:21
tctool.exe |
Tervitus kõigile
Et sain oma masinasse siis tctool-i nimelise asjanduse,millest nagu lahti ei saa enam...Trust Cleaneri nimeline asjake...
Olen Google juhtnööride järgi tegutsenud,korraks nagu masin puhas,päeva pärast asjandus jälle külas
Ja loomulikult safe modes jne....
Kas on kellelgi siin midagi tarka äkki soovitada?
| Kommentaarid: 68 loe/lisa |
e-Thug
06.07.2006 17:16:52
Kui inglise keel probleemiks pole,siis http://www.bleepingcomputer.com/forums/topic54501.html
Print out these instructions as we will need to close every window that is open later in the fix.
Download FixTC.reg to your desktop by right clicking on the following link and then selecting Save Link As or Save File as, depending on your browser.
Confirm that the file FixTC.reg now resides on your desktop as we will need it later.
Click on the Start Menu
Click on the Control Panel option.
Double-click on the Add or Remove Programs icon.
Find the following entries and double-click on each of them. Follow the prompts to uninstall the programs, but do not allow it to reboot the computer if it asks. If after you uninstall a particular entry below it still remains, double-click on the entry again to remove it.
Trust Cleaner
TrustIn Bar
TrustIn Contextual Ads
Trustin Popups
TrustIn Search Assistant
Trust Cleaner Promo
When it has completed uninstalling you can close Add or Remove Programs and your Control Panel.
Next, please reboot your computer into Safe Mode by doing the following:
Restart your computer
After hearing your computer beep once during startup, but before the Windows icon appears, press F8.
Instead of Windows loading as normal, a menu should appear
Select the first option, to run Windows in Safe Mode.
When you are at the logon prompt, log in as the user account you were logged on as when you extracted the SmitRem files.
When your computer has started in safe mode and you see the desktop.
Go to your desktop and double click on the FixTC.reg file that you downloaded earlier. When it asks if you would like to merge the information, press the Yes button and then the OK button.
Delete the following files and folders (Do not be concerned if a folder or file does not exist):
C:\Program Files\TrustIn Popups
C:\Program Files\TrustIn Bar
C:\Program Files\TrustIn Contextual
C:\Program Files\TrustIn Search
%Temp%\wschtm35.dll
%Temp%\srsvc.exe
C:\WINDOWS\local.html
C:\WINDOWS\SYSTEM32\tisa.dll
C:\WINDOWS\SYSTEM32\lut.dat
C:\WINDOWS\SYSTEM32\tisa.cnf
C:\WINDOWS\SYSTEM32\ticads.exe
C:\WINDOWS\SYSTEM32\tctool.exe
C:\WINDOWS\SYSTEM32\ticont.dll
C:\WINDOWS\SYSTEM32\tpopup.ex
C:\WINDOWS\SYSTEM32\tconini.dat
C:\WINDOWS\SYSTEM32\lcch.dat
C:\WINDOWS\onlineshopping.ico
C:\WINDOWS\removeadware.ico
C:\WINDOWS\sexpersonals.ico
C:\WINDOWS\SYSTEM32\tu.exe
C:\WINDOWS\SYSTEM32\ttu.exe
C:\WINDOWS\se_spoof.dll
C:\WINDOWS\inetloader.dll
C:\WINDOWS\videoslots.ico
Close all open Windows.
Reboot your computer back to normal mode.
Download the ATF-Cleaner to your desktop from the following link:
http://www.atribune.org/ccount/click.php?id=1
When it is download to your desktop, double-click on the program to run it. Select the box labeled Select All and then press the Empty Select button. When it is done you can close the program.
Perform an onlinescan with Panda: Panda Online
Once you are on the Panda site click the Scan your PC button
A new window will open...click the Check Now button
Enter your Country
Enter your State/Province
Enter your e-mail address and click send
Select either Home User or Company
Click the big Scan Now button
If it wants to install an ActiveX component allow it
It will start downloading the files it requires for the scan (Note: It may take a few minutes)
When download is complete, click on Local Disks to start the scan
Your computer should now be free of the Trust Cleaner infection.
Ei tea,kas peabki nii pika protseduuri läbima.
E: või seda proovisid ka juba?
| Kommentaarid: 230 loe/lisa |
205 |
Incikas
06.07.2006 17:17:17
ehhh...oleks võinud ikka mu posti enne läbi lugeda-Googeldasin,ja tegutsesin nende juhtnööride järgi,isegi välja printisin omale selle jama 6-le lehele ...aga kasutegur 0
Ilma-asjata ma siia poleks postitanud ju,olen ikka ise enamasti hakkama saanud,nüüd hüva nõu vaja ...
Ho Ho
06.07.2006 17:20:04
Kui masin on vahepeal tõesti sellest puhas siis kontrolli tihendid üle. Kuskilt peab see proge ju tagasi sisse pääsema.
87 |
e-Thug
06.07.2006 17:21:03
mingi programmijupp on ka:
tctool.exe removal:
WARNING!!! File tctool.exe is related to spyware. This is serious violation of your privacy, your system is under security threat.
We advice you to scan your computer and eliminate possible threats.
download removal software Äkki on siis sellest abi
Ega meie ei tea ju ,millised sa kõik läbi proovinud oled, juhiseid on googlis ju mitmeid.
http://www.2-spyware.com/remove-trust-cleaner.html
205 |
Incikas
06.07.2006 21:04:36
| e-Thug kirjutas: |
tctool.exe removal:
http://www.2-spyware.com/remove-trust-cleaner.html |
üldiselt olen proovinud kiki neid juhiseid,mis antakse siis,kui kirjutad Googlesse tctool...ja see downloadi link on kah selline nagu ikka...-Spy Doctor,teeb skänni ära ja siis tahab,et ostetaks,muidu ei remuuvi miskit
Tihenditest on läbi ainult nähtavasti klaveri-tooli vaheline,et sellise pasa sisse tõi
Üldiselt tegin registrid värgid kah puhtaks,seni vaikus,eks homnepäev näitab
HacaX
07.07.2006 12:06:41
Räägiks äkki lähemalt mis moodi sa üldse tuvastad et ta sul jätkuvalt masinas on. On mingeid "kõrvalnähte" või põhinneb kogu diagnoos üheainsa skänneri näidul (mispeale pakuks et tegu võib olla valeidentifikatsiooniga või valetab proge sulleteadlikult näkku, üks SpyDoctori nimeline vidin mis paras saast on on SpywareWarriori listis isegi ära märgitud)?
| Kommentaarid: 24 loe/lisa |
22 |
Incikas
07.07.2006 20:59:20
no näitab ta ise,et masinas on...täna näiteks jälle viskas koguoma saasta deskile..(trustin popup jne....),kuigi eile tegin sama protseduuri läbi ,mis eelmainitud postitusteski läbi käis...
Ja Spydoctori vennikesed võivad omale Statoili stardika osta,teeb skänni ja siis osta mind ...ja peale selle ei leia kah veel midagi
Aga jah,probleem püsib,kõik nõuanded teretulnud
Ho Ho
07.07.2006 21:05:06
Ega sul mingit reaalaja kaitset ei ole arvutil peal?
87 |
Incikas
07.07.2006 21:18:16
st mida?
Ho Ho
07.07.2006 21:20:34
Pidevalt taustal töötavad pahalaste tõrjujad. Näiteks mingi viirusetõrje või anti-spyware programm.
87 |
Incikas
18.07.2006 21:21:24
viirusetõrje on avg,Spybot töötab kogu aeg kah...
ütleme nii,et probleem püsib....
kahjuks pole ka selle jama genereerijat leidnud,sest korduvalt olen oma masinast kustutanud tctool.exe
selleks korraks siis asi lahenenud,proovisin erinevate asjadega ja ka siit foorumi tuhlasin läbi ja...lahti sain raisast
