sõnum  |
aise
168 |
tjj
20.07.2006 17:22
Core 2 Duo processor's weak point - processing in 64bit mode?
The tests of new processors, based on the CORE microarchitecture, showed their overwhelming advantage in regards to the competitior's offerings. Working on the same clock speed, CPUs with a CORE microarchitecture overtake Athlon 64 X2 by a margin of appromaximately 20%, leaving no chances to AMD's production being a leader. The given conclusion has been made by a distinguishly big quantity of reviews, which have invaded the Internet for a week by now. However, regardless of the overall happiness of INTEL's fans, we will take the courage to pointout the fact, that in the future, such optimistic predictions will have to be reduced. The thing is, that the information about Conroe's lower performance in 64-bit mode has been unexpectedly confirmed.
Cutouts from an application optimisation manual for new Core 2 Duo processors, which were published by a japanese site called PCWatch, indicate, that when a 64-bit mode is enabled (64-bit Long Mode), which is supported in the new processors thanks to EM64T (Enhanced Memory 64 Technology), Core microarchitecture loses it's advantages. In other words, new INTEL's processors turn out to be better optimised for running 32-bit applications. Because of that, after the release of Windows Vista family and massive occurance of 64-bit software, Cure 2 Duo might not be getting such enthusiastic feedback already.
Firstly, INTEL reports, that in 64-bit mode Intel Core 2 Duo processors do not support a technology called Macrofusion. As our readers recall, this technology is pointed towards the increase of commands processing per clock and consists of a number of consistently connected (among themselves) x86 instructions, such as, in example, a comparision between the next undergoing conditional transition, is represented inside the processor by one microinstruction. In result, processors with a Core microarhitecture lose the ability to process five x86-64 instructions at the same time. By the experts analysation, the disablement of this technology can cause a decrease in performance with Core microarchitecture by a margain, reaching 10%.
Fak, rohkem ei saa.. Kasutage babelfish vms -
http://www.overclockers.ru/hardnews/22814.shtml
| Kommentaarid: 161 loe/lisa |
6 :: |
117 |
20.07.2006 17:28
jah sama kiired per takt aga kes oc-d tahab see ei pea eriti mõtlema ~4ghz conroe vs 3ghz amd ja polegi miskit muud öelda
| Kommentaarid: 1006 loe/lisa |
727 |
Ho Ho
86 |
tjj
20.07.2006 17:41
| Winterwind kirjutas: |
jah sama kiired per takt aga kes oc-d tahab see ei pea eriti mõtlema ~4ghz conroe vs 3ghz amd ei pane eriti mõtlema  |
Tõesti, jah, aga hind pole samuti kõige madalam, pealegi informatsiooni järgi, selle aasta jooksul mingeid muutusi ei tule.
E6600 @ 350 EUR.. ehm.
Üldiselt 4GHz pole nii lihtne Conroe-ga saavutada kah..
Ho Ho,
Tegelikult kõik pole nii lootustandvalt nagu steptzer ütles. Loe mis seal lingis on ja saad aru.
6 :: |
117 |
HDTanel
Overclocker
20.07.2006 17:45
tjj, kle sa ehk viitsid kunagi mu privadele ka vastata?
_________________ Minu Youtube - HDTanel <- EESTIKEELSED VIDEO ÜLEVAATED!
Minu Facebook - HDTanel
Minu Twitch - HDTanelEST |
| Kommentaarid: 628 loe/lisa |
491 |
Anti
20.07.2006 17:54
| keegi võlgu ei viitsi anda nats?`
| Kommentaarid: 309 loe/lisa |
237 |
heikis
20.07.2006 17:59
| velsa kirjutas: |
| keegi võlgu ei viitsi anda nats?` |
palju vaja ? mis intress?
| Kommentaarid: 327 loe/lisa |
279 |
Anti
20.07.2006 18:02
| heikis kirjutas: |
| velsa kirjutas: |
palju vaja ? mis intress? |
no anna palju rahakott lubab, intressidest ei taha väga teiste nähes rääkida
237 |
Sponge
20.07.2006 19:29
By Fuad Abazovic sellel mehel on ikka väga igab et peab koguaeg midagi välja imema [/b]
308 |
stepzter
21.07.2006 01:35
tjj, soovitan lugeda vähem sensatsioonihimulisi allikaid. Aceshardware selle teemaline thread oleks hea alustus. Core 2 64-bit probleemid on suhteliselt tühised.
Peale selle, olulisim probleem avaldub ainult kohtades, kus Core 2 ei ole enam võimeline 5 käsku korraga dekodeerima ning peab 4'ga leppima. AMD dekodeerimisvõime piirdub kolme käsuga, seega Core 2 on nendes situatsioonides suure tõenäosusega niikuinii juba oluliselt kiirem.
| Kommentaarid: 25 loe/lisa |
25 |
tjj
21.07.2006 08:11
stepzter,
Esiteks see on päris austatud ja korrektne allikas (soovitan sellega tutvuda kah), mis eksisteerib juba tunduvalt palju aega. Mitte midagi seal ei toimu sensatsiooni pärast.
Samuti ma ei saa öelda, et Conroe 64-bit probleemid on nii tühised. Vähemalt nii ei tundu.
"Peale selle, olulisim probleem avaldub ainult kohtades, kus Core 2 ei ole enam võimeline 5 käsku korraga dekodeerima ning peab 4'ga leppima."
Macrofusion tehnoloogia üldse ei tööta, kui 64-bit mode on aktiveeritud. Kas see ei tähenda, et praktiliselt kõikides 64-bit programides sellised probleemid peavad ilmuma? Põhimõtteliselt mitte probleemid, vaid eripärasused. Conroe's üleolek märgatavalt väheneb 64-bitis:
Eriti selline pilt ei näe nii hästi välja, arvestades seda, et Vista ja 64-bit software on juba lähedal.
Pealegi räägitakse, et teine probleem on seotud lisaregistritega (acehardware-is on sellest ka jutt), kui EM64T on aktiveeritud. Istruktsioonide pikkus suureneb (+1byte), mis raskendab koodi algoritmide lahtivõttu (mis on kasutusel esimesel dekodeerimise faasil) - kuigi see enam-vähem avaldab raskusi ainult programmerijatele.
6 :: |
117 |
mcaff
21.07.2006 09:16
Kas mida suurem seda paerm (tabel)
104 |
Revage
21.07.2006 09:47
Jaan, Kas need inteli plaadid mida dr.peep müüb on rev. 304 ?
| Kommentaarid: 78 loe/lisa |
6 :: |
10 :: |
52 |
HDTanel
Overclocker
21.07.2006 09:56
Hmm kas mõttekam poleks mitte oodata DFI Lanparty plaati? Augustis pidi tulema.
491 |
lamp
21.07.2006 10:11
| PlatoonSgtElias kirjutas: |
| Hmm kas mõttekam poleks mitte oodata DFI Lanparty plaati? Augustis pidi tulema. |
too infinity juba näitab ilmekalt ära, et dfi suudab endiselt intelile vaid saasta toota
samas kui peaks mingi parem mobo tulema läbi miski ime ja veel augustis, siis xs'i japsid ja hiinlased
oleks ammu kas uudiseid pasundanud või juba katki testinud.
btw sul pidi DFIs tuttav(naine) olema, mis tema kostab, äkki lanparty on oopis rd600 tsipsetiga?
144 |
HDTanel
Overclocker
21.07.2006 10:54
Mõlema chipsetiga pidi tulema.
Enivei mai tea... seda Deluxe plaati keegi hankida saaks mulle? Ma ei leia kusagilt.
HuhHuh:
Intel Pentium 4 D805 1850.-
ASUS P5W DH Deluxe 3150.-
2x1Gb Corsair TWIN2X2048-6400 800MHz 3400.-
700W Fortron 2200.-
Oh yeah ja siis veel Conroe peale ka raha 5000.- vaja
491 |
robin
21.07.2006 10:57
| mcaff kirjutas: |
Kas mida suurem seda paerm (tabel) |
mida väiksem, seda parem.
| Kommentaarid: 54 loe/lisa |
50 |
stepzter
21.07.2006 15:10
| tjj kirjutas: |
| Macrofusion tehnoloogia üldse ei tööta, kui 64-bit mode on aktiveeritud. Kas see ei tähenda, et praktiliselt kõikides 64-bit programides sellised probleemid peavad ilmuma? Põhimõtteliselt mitte probleemid, vaid eripärasused. |
Väga valdavas enamuses softis ei anna "macro-op fusion" (ehk võrdlus ja tingimuslike siirdekäskude eeldekodeerimisel ühitamine) eriti suurt effekti. Macro-op fusion mõjub jõudlusele kahes kohas: järjekorra välise täitmise plaanuri otsingu aken mahutab ~10% rohkem käske ja teatud tingimustel õnnestub 4 käsu asemel 5 dekodeerida. Esimene neist avaldab mõju siis kui juhuslikult õnnestub selle lisa 10% seest leida mõni käsk, mida saab teistest ette tõsta vabades täitmisüksustest täitmiseks (enamasuses koodis võrdlemisi ebatõenäoline). Teine avaldab põhiliselt mõju siirdekäskude ennustamise ebaõnnestumisele järgneval plaanuri puhvri 25% kiiremal täitmisel ja sellisel juhul kui protsessor suudab maksimaalset käskude täitmise kiirust hoida mitmeid takte üleval (keskmine on 3-5 korda madalam). Kõhutunde järgi pakuks, et enamuses softis jääb nende kogueffekt paari-kolme protsendi piiresse. Loomulikult esineb ka patoloogilisi juhtumeid, aga need on igal protsessoril olemas.
Eks tuleb mingeid põhjalikkumaid võrdlusi oodata. Siin esialgu mingis jaapani tekstiredaktoris hiiglasliku search-replace tegemisest natukene tuntum benchmark:
PS: 64bitine kood enamustel arhitektuuridel ongi aeglasem. Koodi suurus suureneb, andmestruktuuride suurused suurenevad jne. x86 on üks vähestest arhitektuuridest, kus 64biti peale minek on jõudluse paranemist toonud. Põhiliselt tänu sellele, et enne 64biti laiendusi oli x86 kasutatavate registrite arv täiesti kiviaegne 7.
25 |
Jaan
21.07.2006 17:10
| stepzter kirjutas: |
| ...PS: 64bitine kood enamustel arhitektuuridel ongi aeglasem. Koodi suurus suureneb, andmestruktuuride suurused suurenevad jne. x86 on üks vähestest arhitektuuridest, kus 64biti peale minek on jõudluse paranemist toonud. Põhiliselt tänu sellele, et enne 64biti laiendusi oli x86 kasutatavate registrite arv täiesti kiviaegne 7. |
vene ixbt.com on teinud teste 64bit windoosas:
http://www.digit-life.com/articles2/cpu/intel-core2-duo-x6800.html
kokkuvõtteks niipalju, et 64bit winni all olid tulemused tõesti kehvemad, lisaks sellele tuli huvitav asi ilmseks-
inbox cooleriga ja piisavalt soojas toas saab prose throtlima.
Tuletan meelde, et see cooler on mõeldud kuumade netburst prosedele, mille soojuseraldus on kuni 150W...
Siinkohas mainin omaltpoolt et need xbitlabsi voolutarve testid on imho valesti tehtud-
a64 tarbib 2x vähem idles ja x6800 tarbimine on sinna 100W kanti tegelikult.
Need on minu oletused, üritan järgmisel nädalal seda ise uurida.
| Kommentaarid: 141 loe/lisa |
122 |
| Kommentaarid: 370 loe/lisa |
311 |
Anti
21.07.2006 18:16
| Odavaim vb jah, aga mina võtaks ennem Asus P5V-VM DH/WIFI-AP. Sellel wifi ja ikkagi Asus, olgu OC võimalustega kuidas on.
237 |
HDTanel
Overclocker
21.07.2006 19:07
Irw, Skeptik... võta Jaaniga ühendust ja las testib korra AGP kaartide WR-id tulevad
491 |
libe
kvaliteetne mees
21.07.2006 21:20
selle peaks esialgu vist võtmagi
saab 6-7k hakkama
mälu kannatab natukene veel küll
päris 1000MHz ddr ei kannata
aga saan oma tööd küll kiiremini tehtud kui praeguse tbred 1700+
| Kommentaarid: 82 loe/lisa |
razor
22.07.2006 10:55
miks mitte, kui sinna peale visata BH5ed koos boosteriga 8)
01'es kindlasti kiirem, kui DDR2
115 |
