praegune kellaaeg 13.09.2026 14:17:14
Vananematu
16.04.2006 17:25:59
Iron Warriors: T72 Tank Command [ tanki simulatsioon ] |
Koduleht
Mäng andmete järgi simulatsioon. Kamandad t72 tanki ja muudki veel . Features järgi tõotab ikka ülikõva asi olla. See tundub isegi parem kui kunagi see aasta väljatulev Steel Beasts 2.
The focus of the game is the control of the your own tank, but the ability to command a number of attached units (armour, vehicles and infantry up to platoon strength) is given through the use of a command and navigation map.
Eriomadused:
T-72 Iron Warriors! uses a powerful and stunning 3D environmental and physics engine to produce state of the art effects and realism. Below is a list of some of what awaits you inside!
* Three types of playable tanks modelled: T-34-85, T-55A and T-72B
* Control individual crew stations (Commander, gunner or driver)
* Wide variety of armoured vehicles included as well as infantry, artillery, engineering vehicles, helicopters and trucks
* 18 campaign missions, 2 training missions, 5 single player missions and 3 multiplayer (LAN) missions
* Command attached units (infantry and armour) up to a full tank platoon
* Mechanized infantry can be transported inside trucks and APCs and on tank hulls
* Detailed modelling of each vehicle's fire control systems, main and secondary weapons, ammunition types, engine management and transmissions, starting and driving procedures
* Realistic night vision combat capabilities realistically modelled low light level and infrared sights
* More than 70 types of buildings and installations that can be damaged or destroyed
* Over 40 types of plants, trees and grass sway in the breeze
* High-quality modelling of water surfaces and amphibious vehicle capabilities
* 5000+ polygons per vehicle including detailed bump mapping
* Scalable realism settings
* Powerful mission, map and structure editor available
* Local Area Network (LAN) multiplayer capable
Advanced Physics and Environmental Game Engine:
* Vast open spaces with draw distances of more than 2 km
* Topographic height differences on maps of up to 800 m
* Realistic passage of time transitions (day changes to night)
* Dynamic weather and environmental effects: smoke, fog, rain, rainbows, dust, wind effects
* Deformable terrain - shell holes and trenches dug out in real time
* Destroyable structures, vehicles and vegetation
* Clouds cast shadows
* Optical lens flares and sun glare effects
* Realistic ballistics wind effects, shell aerodynamics and flight characteristics, barrel wear and droop
* Shell impact angle calculations
* Detailed armour penetration results
* Post-penetration shell path and damage assessments
* High Explosive fragmentation dispersal calculations
* Realistic vehicle and structure collision detection and damage
* Individual internal and external vehicle system damage modelling including track damage, engine overheats, fuel leaks, turret jams, crew casualties, bailouts and more
Realismi kohta veel väheke tsiteeringut:
| The game provides scalable realism settings, giving you a lot of flexibility to adjust the game to your own liking and system capabilities. Newbies can set the realism to lower levels to allow them to get the hang of modern armoured combat while the armour grognards will want to tweak weapons performance to their realistic, and lethal, levels and enable all the nitty-gritty details like barrel wear, engine stalls, restricted internal viewing angles, full collision damage and even engine and transmission management and starter battery failures! |
rohkem pilte
info ja demo
| Kommentaarid: 31 loe/lisa |
28 |
Le Inc
16.04.2006 19:11:52
| T-72 on ju miskine muldvana tanki seeria!? T-90 peaks vist neist kõige värskem olema.
| Kommentaarid: 56 loe/lisa |
54 |
Tbit
17.04.2006 00:18:59
Igav & Odav
võtaks nii kahe sõnaga kokku, maitse asi muidugi.
|OSTAN|-> T43 pikk jahutus |
230 |
aht0
17.04.2006 08:19:02
T-55 ja T-72 ühes mängus.. saan aru.. aga mida teeb seal WWII aegne T34???
mis on huvitav:lubatakse purustatavat maapinda, ehitisi ja puid..muutuvaid keskkonnatingimusi jms.. kõike ühekorraga selliseid pelasid just palju pole kus saaks ka ümbritseva keskkonna kallal laamendada
| Kommentaarid: 82 loe/lisa |
71 |
Paganarh
17.04.2006 08:40:17
meenutab välimuselt ja olemuselt T72 balkans on fire mängu. uvitav kas samad jorsid on teinud
aht0, T34'd olid kasutusel erinevates madinates veel väääga pikka aega
| Kommentaarid: 15 loe/lisa |
