praegune kellaaeg 25.10.2026 12:03:28
Osiris
14.03.2006 18:56:37
Mingi jama turvalisusega |
Tervitus..
Sirvisin oma koduserveri logisid - ja leidsin käsurealt selliseid käskusid mida ise pole sisestanud...?
Mõni näide:
set echo_style=both ; alias precmd 'echo $cwd:q >>/tmp/mc-root/mc.pipe.38808;kill -STOP $$'
cd "`echo '\0057'`"
cd "`echo '\0057var'`"
cd "`echo '\0057var\0057log'`"
cd "`echo '\0057var\0057log\0057httpd'`"
cd "`echo '\0057var\0057log\0057httpd\0057failid'`"
set echo_style=both ; alias precmd 'echo $cwd:q >>/tmp/mc-root/mc.pipe.38855;kill -STOP $$'
set echo_style=both ; alias precmd 'echo $cwd:q >>/tmp/mc-root/mc.pipe.38865;kill -STOP $$'
cd "`echo '\0057var\0057log\0057httpd\0057musa'`"
set echo_style=both ; alias precmd 'echo $cwd:q >>/tmp/mc-root/mc.pipe.663;kill -STOP $$'
cd "`echo '\0057'`"
cd "`echo '\0057var\0057log\0057httpd\0057fun'`"
set echo_style=both ; alias precmd 'echo $cwd:q >>/tmp/mc-root/mc.pipe.811;kill -STOP $$'
cd "`echo '\0057'`"
ehk mõni teab milles jama võib olla. ja kuidas seda asja kinni keerata?
Serveri opisüsteemiks on FreeBSD
103 |
jossi 1
| Kommentaarid: 15 loe/lisa |
15 |
Osiris
15.03.2006 09:02:22
Hea oleks kui keegi tõlgiks mida seal öeldud - vene keelt mitte ei jaga..
103 |
someOtherDude
15.03.2006 09:26:47
babelfishi kasutades:
1. Here there is a script, there will be rad if someone it says che it it makes... set_.echo_.style=.both; alias precmd ' echo >/tmp/mc-root/mc.pipe.25594;kill>-.STOP$$ '
2. It was caught in my console, although 4 similar it did not write...
3. this script generitsya by function void init_.subshell(.void) from subshell.c (see in it the line of # 475).
it is used so that the mc could obtain current directory from its of sub-Shell (if sub-Shell - TCSH).
nothing dangerous in itself it bears.
P.S.: RTFS
4. Senks worthy.gif , 4 simply not programer therefore RTFM in this case me will not help..
Niisis, nothing dangerous in itself it bears.
_________________ ebastabiilne
viimati muutis someOtherDude 15.03.2006 09:24:06, muudetud 1 kord |
15 |
