psydeblo
11.03.2006 15:33:55
The Computer Knowledge Test |
link :: testime oma teadmisi
mina:
You are definitely above average when it comes to computer knowledge, and are an asset to your friends and family when they are in need of computer related help. However, there is still much to learn, so don't get too big of a head.
My test tracked 1 variable How you compared to other people your age and gender:
You scored higher than 37% on compsmarts
edit: ja veel seda et ei mingit googeldamist
viimati muutis psydeblo 11.03.2006 15:49:17, muudetud 1 kord |
| Kommentaarid: 149 loe/lisa |
136 |
Ho Ho
11.03.2006 15:42:03
You spend way too much time tinkering with computers and it's no guess why you're even visiting OKCupid. You already knew you were going to score high, and are probably bitter about constantly being bugged by friends and family to fix their boxes.
You scored higher than 68% on compsmarts
Ilma google ning muude abivahenditeta
Huvitav millega ma puusse panin?
87 |
uhmer
11.03.2006 15:50:58
You scored higher than 44% on compsmarts
| Kommentaarid: 37 loe/lisa |
crypto
11.03.2006 16:13:06
You scored higher than 49% on compsmarts
njah, neid progemise värke nii väga ei teadnukdi, panin sisetunde järgi
_________________ 61. Logistikapataljoni võitleja |
| Kommentaarid: 42 loe/lisa |
37 |
wader
11.03.2006 16:19:10
smirk,
You scored higher than 94% on compsmarts
Mõttetu test.
| Kommentaarid: 4 loe/lisa |
soovija
11.03.2006 16:26:23
You scored higher than 67% on compsmarts
85 |
taavi
11.03.2006 18:20:45
osad küsimused olid ikka üliveidrad.
Computer Guru
Congratulations computer h4x0r! You scored 24!
You scored higher than 98% on compsmarts |
| Kommentaarid: 70 loe/lisa |
61 |
2III7
11.03.2006 18:47:54
24% on compsmarts
| Kommentaarid: 170 loe/lisa |
152 |
Death
11.03.2006 19:00:31
väga veidrad olid osad kysimused... KVMi kysimuys näiteks... Ilma googeldamata sain 19 punlti - tekst sama mis HoHol ja 89%.
_________________ "To be or not to be?" is a question of when, not if. |
| Kommentaarid: 39 loe/lisa |
36 |
Ho Ho
11.03.2006 20:03:33
Huvitav, tegin testi uuesti. Oma arvates kasutasin samu vastuseid mis ennegi, tulemus 19 ning samuti 89%.
Ju siis varem vastanud olid üle keskmise targad
87 |
soovija
11.03.2006 20:04:53
| soovija kirjutas: |
You scored higher than 67% on compsmarts |
Ei kasutanud mingit google-it ja tulemusega rahul
85 |
friik1
11.03.2006 20:12:20
free online dating free online dating
You scored higher than 90% on compsmarts |
lambist ja ilma googleta - viga tuli vist ln ja ls koha pealt... mingi linuxi käsk, aga linux on võõras, maby midagi veel
171 |
-sSs-
11.03.2006 20:18:12
You scored higher than 56% on compsmarts
pole viga minuarust
| Kommentaarid: 60 loe/lisa |
59 |
One
11.03.2006 20:18:41
Computer Competent
Congratulations computer h4x0r! You scored 4!
However, there is still much to learn, so don't get too big of a head. |
täispeaga
728 |
-mrt-
11.03.2006 20:23:22
Sain kah 49%, arenemisruumi on
_________________ A good discussion is like a miniskirt; Short enough to pertain interest and long enough to cover the subject. |
| Kommentaarid: 11 loe/lisa |
suurpealik
11.03.2006 20:27:48
You scored higher than 81% on compsmarts
Pole vist kõige hullem... 18 punkti. Palju neid küsimusi kokku oli?
Aga mida tähendab HSF? Heatsink/Fan?
_________________ Apple business solution partner. |
| Kommentaarid: 227 loe/lisa |
195 |
riaak
11.03.2006 20:44:00
68%
_________________ ¯\_(ツ)_/¯ |
105 |
Juhan88
11.03.2006 20:46:33
Irw...hea küsimus viimane:
Do you have stairs in your house?
Yes
No
I am protected
The duck flies at midnight
Ma panin viimase..
You scored higher than 32% on compsmarts
_________________ Fotoblogi |
| Kommentaarid: 62 loe/lisa |
48 |
Mihkel.
11.03.2006 21:23:17
36%, pole paha minu kohta ma usun. Kuigi vähe.
| Kommentaarid: 92 loe/lisa |
neros
11.03.2006 22:13:30
83%... arvasin kah umbes sellist... aga misasi see HSF siis ikkagi on?
(ps: no google)
_________________ GitHub
.NET Core & Azure baasil lahendused ja arhitektuur - kontakt. |
| Kommentaarid: 48 loe/lisa |
40 |
crypto
11.03.2006 22:36:30
Imo, HSF ongi HeatSink/Fan, ennegi seda kuulnud kusagil
typo
viimati muutis crypto 11.03.2006 22:48:31, muudetud 1 kord |
37 |
emty
11.03.2006 22:46:34
You scored higher than 41% on compsmarts
_________________ ei tea, kas netisõltuvuse vastu ka miskiseid plaastreid on?...
m/v: challenger, sportage |
| Kommentaarid: 459 loe/lisa |
381 |
Slazenger
11.03.2006 22:55:32
Computer Competent
Congratulations computer h4x0r! You scored 9!
| Kommentaarid: 74 loe/lisa |
69 |
Clone^
11.03.2006 23:09:33
Computer Guru
Congratulations computer h4x0r! You scored 18!
| Kommentaarid: 13 loe/lisa |
keytron
12.03.2006 00:19:12
Congratulations computer h4x0r! You scored 11!
putsi
| Kommentaarid: 58 loe/lisa |
54 |
tiith
maxnorm
12.03.2006 00:27:54
| 9% sain
| Kommentaarid: 21 loe/lisa |
19 |
thunderz
12.03.2006 03:00:22
jama küll, ainult 66% sain, aga programeerimisest ega linuxist ei tea ka tuhkagi, kui aus olla.
sel juhul vist isegi hästi (muidugi ilma googeldamata jne)
| Kommentaarid: 47 loe/lisa |
46 |
iceincube
12.03.2006 05:50:09
37 |
FuN
12.03.2006 08:33:49
You scored higher than 33% on compsmarts
Päris loll või miss
| Kommentaarid: 32 loe/lisa |
24 |
tsihh
12.03.2006 11:10:40
You scored 18!
You scored higher than 75% on compsmarts
| Kommentaarid: 59 loe/lisa |
58 |
weedstone
12.03.2006 11:38:26
125 |
JoeKing
12.03.2006 11:42:38
You scored higher than 72% on compsmarts
_________________ Sic itur ad astra... |
| Kommentaarid: 238 loe/lisa |
209 |
v6sa
12.03.2006 11:55:23
87% norrmaalne
_________________ Otsid kohta nokitsemiseks? Pole vajalikke tööriistu varnast võtta? Kodus lapsed ei lase rahus tööd teha? Tule kiika meie hackerspace'i k-space.ee |
91 |
Smith
12.03.2006 12:29:12
92%
Mõni küsimus küll veidravõitu, mis kuradi "The duck flies at midnight"? Ega keegi ei tea kas sellel mingi mõte ka on?
_________________ Only the Central Computer knows the truth |
145 |
weedstone
12.03.2006 12:48:02
| Smith kirjutas: |
92%
Mõni küsimus küll veidravõitu, mis kuradi "The duck flies at midnight"? Ega keegi ei tea kas sellel mingi mõte ka on? |
Ma ple sellist seal üldse märgand, või siis lihtsalt ei mäleta :S
125 |
-KaUR-
12.03.2006 13:05:05
Congratulations computer h4x0r! You scored 20!
You scored higher than 95% on compsmarts
| Kommentaarid: 35 loe/lisa |
31 |
crypto
12.03.2006 13:52:51
| weedstone kirjutas: |
| Smith kirjutas: |
92%
Ma ple sellist seal üldse märgand, või siis lihtsalt ei mäleta :S |
See oli selle viimase küsimuse üks vastusevariant
37 |
FurioN
12.03.2006 14:32:25
You scored higher than 63% on compsmarts
võibolla oleks rohkem % saanud, kui seal sünniaasta 1992 valikus oleks olnud.
viimati muutis FurioN 12.03.2006 19:02:45, muudetud 2 korda |
| Kommentaarid: 26 loe/lisa |
24 |
Herr Kurm
12.03.2006 16:57:12
mnjaa
_________________ -logod, firmaidentiteet, küljendamine, flash-
-portfolio- |
| Kommentaarid: 25 loe/lisa |
19 |
Adebisi
12.03.2006 16:59:07
| You scored higher than 91% on compsmarts
55 |
trigger
12.03.2006 17:15:35
Computer Guru
Congratulations computer h4x0r! You scored 15!
You scored higher than 69% on compsmarts
rohkem küsimusi võinuks olla, suht pealiskaudne IMO
_________________ Suunan elektrone aastast 2003 |
| Kommentaarid: 24 loe/lisa |
23 |
Aix
12.03.2006 18:38:03
Computer Competent
Congratulations computer h4x0r! You scored 14!
You scored higher than 82% on compsmarts
| Kommentaarid: 418 loe/lisa |
348 |
T6nnn
12.03.2006 19:17:12
| aix17 kirjutas: |
Computer Competent
You scored higher than 82% on compsmarts |
täpselt sama palju sain
| Kommentaarid: 20 loe/lisa |
20 |
aX
12.03.2006 19:33:53
You scored higher than 54% on compsmarts
84 |
GertR
12.03.2006 19:48:45
You spend way too much ... yadayadayada
My test tracked 1 variable How you compared to other people your age and gender: You scored higher than 69% on compsmarts
punktiir
| Kommentaarid: 49 loe/lisa |
38 |
v6sa
12.03.2006 23:26:13
Standard test -> 80%
Full test -> 95%
viimati muutis v6sa 12.03.2006 23:39:10, muudetud 1 kord |
91 |
raxz
12.03.2006 23:33:35
Kõik peast.
| Kommentaarid: 46 loe/lisa |
45 |
Ho Ho
12.03.2006 23:53:20
Loomulikult ilma google ning muude abivahenditega, isegi pin'e ei käinud üle lugemas. Keskmiselt 9.3s küsimuse peale
Kõige lühemas testis sain 90%. Kahju et ei saa teada mis küsimustega puusse panin
87 |
friik1
12.03.2006 23:54:42
saab küll kui full reporti lõppu vaatad
ise panin full testis 85% aga ei viitsinud screeni teha.
171 |
