hvk
04.02.2006 10:40:14
Trojan.Win32.Agent.on |
Kaspersky näitas sellist viirust: Trojan.Win32.Agent.on, aga see fail, mida ta viiruseks luges on logonui.exe
See logonui.exe peaks ju olema mingi microsofti enda fail??
Nii, et kas see on siis viirus ja peaks backupidest kustutama??
Siin pilt ka: http://images.koffer.ee/images/uploaded/viirus_1.jpg
viimati muutis hvk 04.02.2006 11:23:35, muudetud 1 kord |
| Kommentaarid: 41 loe/lisa |
38 |
airm
04.02.2006 11:08:31
Kui ta on backuppi juba tõstnud, siis kustuta.
_________________ M:vanavara - AT-toiteplokk *(viisakas korpus kaasa) |
| Kommentaarid: 56 loe/lisa |
50 |
hvk
04.02.2006 11:12:10
Aga see on ju mingi: Microsoft Logon User Interface
Kindel et on mõte kustutada??
38 |
airm
04.02.2006 11:19:24
Hoopis teine jutt on siin:
blank11-06-2004, 09:26 PM
What Is It?
DownloadWare - logonui.exe
What Does it Do?
DownloadWare is scum of nearly every variety! It's adware, downloader, toolbar, search hijacker AND a trojan all rolled into one. This is installed using ActiveX by a number of questionable sites. It will download and install a number of various applications from its advertisers which will further mess up your system. There is truly no reason why you'll ever want to leave this trash on your system. Remove it NOW!
Removal Instructions:
Our DownloadWare Removal guide can be found here (http://www.iamnotageek.com/a/393-p1.php).
50 |
hvk
04.02.2006 11:34:06
| Hmm nüüd ei tea mida teha, ma panin pildi ka sellest, mis kaspersky leidis.
38 |
airm
04.02.2006 12:14:45
Kustuta kibekähku ära.
50 |
hvk
04.02.2006 12:34:01
| OK läinud, tänan info eest.
38 |
