uus teema   vasta Raud »  Kõvad kettad »  Imelik ikaldus k6vakettaga... märgi kõik teemad loetuks
OFFF
OFFF
sõnum 28.01.2006 10:42:09 Imelik ikaldus k6vakettaga... vasta tsitaadiga
Selline setup siis
Jan 27 10:50:31 pestilence kernel: PDC20268: not 100%% native mode: will probe irqs later
Jan 27 10:50:31 pestilence kernel: PDC20268: ROM enabled at 0xe6000000
Jan 27 10:50:31 pestilence kernel: PDC20268: (U)DMA Burst Bit ENABLED Primary MASTER Mode Secondary MASTER Mode.
Jan 27 10:50:31 pestilence kernel:     ide2: BM-DMA at 0xbc00-0xbc07, BIOS settings: hde:pio, hdf:pio
Jan 27 10:50:31 pestilence kernel:     ide3: BM-DMA at 0xbc08-0xbc0f, BIOS settings: hdg:pio, hdh:pio
Jan 27 10:50:31 pestilence kernel: hde: Maxtor 6Y160P0, ATA DISK drive
Jan 27 10:50:31 pestilence kernel: hdg: Maxtor 6Y120L0, ATA DISK drive
Jan 27 10:50:31 pestilence kernel: ide2 at 0xac00-0xac07,0xb002 on irq 17
Jan 27 10:50:31 pestilence kernel: ide3 at 0xb400-0xb407,0xb802 on irq 17
Jan 27 10:50:31 pestilence kernel: hde: 268435455 sectors (137439 MB) w/7936KiB Cache, CHS=266305/16/63, UDMA(100)
Jan 27 10:50:31 pestilence kernel: hdg: 240121728 sectors (122942 MB) w/2048KiB Cache, CHS=238216/16/63, UDMA(100)
Aga /dev/hdg, vana t6bras, jukerdab!
Kui kylge monteerida ja kasutada yritada, siis teeb "click'o'death" sarnaseid kolinaid ja p22dib enamasti sihukese veaga...
Jan 28 04:20:54 pestilence kernel: hdg: lost interrupt
Jan 28 04:20:54 pestilence kernel: hdg: drive_cmd: status=0x7f { DriveReady DeviceFault SeekComplete DataRequest CorrectedErro
Jan 28 04:20:54 pestilence kernel: hdg: drive_cmd: error=0x7f { DriveStatusError UncorrectableError SectorIdNotFound TrackZero
Jan 28 04:20:54 pestilence smartd: /dev/hdg:Failed to read smart values
Jan 28 04:20:55 pestilence kernel: hdg: drive_cmd: status=0x7f { DriveReady DeviceFault SeekComplete DataRequest CorrectedErro
Jan 28 04:20:55 pestilence kernel: hdg: drive_cmd: error=0x7f { DriveStatusError UncorrectableError SectorIdNotFound TrackZero
Jan 28 04:20:55 pestilence smartd: /dev/hdg:Failed to read smart thresholds
Jan 28 04:20:55 pestilence smartd: Device: /dev/hdg, S.M.A.R.T. Attribute: 3 Changed -2
Jan 28 04:20:55 pestilence smartd: Device: /dev/hdg, S.M.A.R.T. Attribute: 5 Changed -3
Jan 28 04:20:55 pestilence smartd: Device: /dev/hdg, S.M.A.R.T. Attribute: 9 Changed -14
Jan 28 04:20:55 pestilence smartd: Device: /dev/hdg, S.M.A.R.T. Attribute: 197 Changed -2
Jan 28 04:20:55 pestilence smartd: Device: /dev/hdg, S.M.A.R.T. Attribute: 199 Changed -198
Jan 28 04:20:55 pestilence smartd: Device: /dev/hdg, S.M.A.R.T. Attribute: 201 Changed -1
Jan 28 04:50:31 pestilence -- MARK --
Jan 28 04:50:55 pestilence smartd: Device: /dev/hdg, S.M.A.R.T. Attribute: 3 Changed 2
Jan 28 04:50:55 pestilence smartd: Device: /dev/hdg, S.M.A.R.T. Attribute: 5 Changed 3
Jan 28 04:50:55 pestilence smartd: Device: /dev/hdg, S.M.A.R.T. Attribute: 9 Changed 14
Jan 28 04:50:55 pestilence smartd: Device: /dev/hdg, S.M.A.R.T. Attribute: 197 Changed 2
Jan 28 04:50:55 pestilence smartd: Device: /dev/hdg, S.M.A.R.T. Attribute: 199 Changed 198
Jan 28 04:50:55 pestilence smartd: Device: /dev/hdg, S.M.A.R.T. Attribute: 201 Changed 1
Jan 28 05:10:31 pestilence -- MARK --
Mille peale liinuks kiilub kinni nagu kivi ;(
K6iksenaljakam on see, et badblocks miskip2rast vigu ei leia ;(
No minum6istuseiv6ta... ahjaa, voolud ei tohiks kah notid olla, toiteplokk sai k6vem pandud, pealegi kui vool n6rgaks j22b antakse hoopis teistsugune viga.
Tahaks selle ketta ikkagi ellu saada ja miski v22rtusetu - näiteks 100 GB pr0ni hoidmiseks kasutada.
Soovitusi?
A.
Õnnelikul malakamaal ei nuteta! Parem käsi abistab. Sõidame!
Kommentaarid: 32 loe/lisa Kasutajad arvavad:  :: 1 :: 1 :: 29
v6sa
v6sa
sõnum 28.01.2006 10:51:27 vasta tsitaadiga
see on see DM9 seeria mille elektroonika kustub lõpuks iseenesest ära... kui saad elektroonika vahetatud mõne tervema vastu siis saad käima.. muidugi võid proovida seda elektroonikat peltieridega jahutada, võib ka aidata
Otsid kohta nokitsemiseks? Pole vajalikke tööriistu varnast võtta? Kodus lapsed ei lase rahus tööd teha? Tule kiika meie hackerspace'i k-space.ee
Kommentaarid: 109 loe/lisa Kasutajad arvavad:  :: 4 :: 0 :: 91
airm
sõnum 28.01.2006 10:53:14 vasta tsitaadiga
smarterrorid...
smartctl -a /dev/hdg näitab tervislikku olukorda.
Aga kui ta kokku jookseb, siis ju jama(katki).
smartctl -t long /dev/hdg "testib smart staatusi"
M:vanavara - AT-toiteplokk *(viisakas korpus kaasa)
Kommentaarid: 56 loe/lisa Kasutajad arvavad:  :: 2 :: 1 :: 50
OFFF
OFFF
sõnum 28.01.2006 10:59:41 vasta tsitaadiga
Smartctl n2itab ketta pealt mingit jagu badblocke ja mingit jagu reallokeeritud sektoreid.
Kui kettalt lugeda yritada, siis tulevad kah bahale sektorile omased veateated:
Jan 28 10:55:11 pestilence kernel: end_request: I/O error, dev 22:00 (hdg), sector 130877880
Jan 28 10:55:13 pestilence kernel: hdg: dma_intr: status=0x51 { DriveReady SeekComplete Error }
Minu mure on pigem selles, et miks need neetud "bahad sektoorod" ei j6ua badblocksi logisse, et saaks nad failisysteemi tegemisel ilusasti 2ra m2rkida.
Ahjaa... ketast jahutab Suur Lurr, mis sinna vaikselt peale puhub...
(194)Temperature             0x0032   253   253   000       50
V2ga r66mustav muidugi pole, aga 50 pole ka mingi temp. veel kettale.
A.
sõnum 28.01.2006 11:45:11 vasta tsitaadiga
Aga kas siis tootjal endal diagnostikaprogrammi siis olemas polegi või 8) Kui on, siis oleks Sa ammu teada saanud, kas see ketas kõlbab kettaheiteks või kapsatünni kaane peale raskuseks thumbs_up.gif
Igatahes kirje "I/O Error" peaks näitama üsnagi kutut ketast icon_wink.gif
OFFF
OFFF
sõnum 28.01.2006 12:53:03 vasta tsitaadiga
Eino tore, et on olemas tahanteadad, kes meile Linuxi kerneliteateid t6lkida oskavad. Muidu, n2e, oleks puhta valesti arvunud, et i/o errori t2hendust tuleks kerneli dokumentatsioonist lugeda, aga 6nneks on olemas tahanteada, et kes lollile 2ra seletas, et linuxi io error t2hendab "ysna kutu ketas". EI tea, mida ma küll ilma tahanteada v22rtusliku n6uandeta peale hakkaksin.
A.
RKsilver
sõnum 28.01.2006 13:46:17 vasta tsitaadiga
OFFF kirjutas:
Kommentaarid: 172 loe/lisa Kasutajad arvavad:  :: 2 :: 3 :: 140
Ho Ho
Ho Ho
sõnum 28.01.2006 13:54:38 vasta tsitaadiga
Huvitav, mul on mõni ketas selle piiri peal juba ~2a probleemideta töötanud icon_rolleyes.gif
RKsilver
sõnum 28.01.2006 14:08:17 vasta tsitaadiga
Ho Ho kirjutas:
Ho Ho
Ho Ho
sõnum 28.01.2006 14:19:42 vasta tsitaadiga
RKsilver
sõnum 28.01.2006 14:25:04 vasta tsitaadiga
Ho Ho kirjutas:
hmm tegelt ei ole temp naljalt üle 40 ei lähe aga kui defragmenti teha siis 45 juures ketas viliseb 8)
OFFF
OFFF
sõnum 28.01.2006 17:07:06 vasta tsitaadiga
Enivei - turkisn raiska natukene ja l6puks soostus ka badblocks mulle ilusasti "pahade plokkide" kaardi tegema.... tegin failisysteemi uuesti... porno ladustamiseks vast k6lbab... kuni lendab vastu taevast.
A.
8
sõnum 28.01.2006 18:34:46 vasta tsitaadiga
kutsa99 kirjutas:
OFFF kirjutas:
50 kraadine kettatemperatuur ei tohiks veel midagi halba teha. Enamus kettatootjaid lubab maksimaalseks ümbritseva keskkonna temperatuuriks 55 või 60 kraadi. Seega ketas ise võib veel 15...25 kraadi sellest kuumemaks minna, ehk teoreetiliselt 70 kuni 85 kraadini. Aga see kõik oleneb... paljugi temperatuurisensorist, et kus ta on ja kui õigesti ta mõõdab. Nii et 80 kraadini lasta siiski ei tasu icon_wink.gif
Kommentaarid: 37 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 37
v6sa
v6sa
sõnum 29.01.2006 00:21:40 vasta tsitaadiga
pane ketas külmkappi tunnikeseks ja siis kohe suska arvuti külge, kui siis töötab ilusti mõnda aega siis võid kindel olla et elektroonikas kala
8
sõnum 29.01.2006 02:06:37 vasta tsitaadiga
v6sa kirjutas:
Tänapäeva FDB mootoritega ketastele ei ole see külmkapitrikk eriti soovitav. Laagrite möks pidi vist paksuks minema ja ketas ei pruugi üldse startida siis. Juhul kui külmkapi all mõelda selle sügavkülma osa. Niisama külmkapis ei juhtu muidugi midagi, ketta lubatud töötemperatuur on ka alates mõnest plusskraadist. Vanade kuullaagermootoritega ketaste puhul oli aga sellest külmutamisest mõnikord abi küll. Lisaks tuleb aga olla ettevaatlik ka järsust temperatuurimuutusest elektroonikaplaadile ja ehk isegi ketta sisse tekkida võiva kondensaadi osas.
OFFF
OFFF
sõnum 29.01.2006 11:49:18 vasta tsitaadiga
Noh, minul tema nüüd j2lle k2ib... 22GB pr0ni lendas küll vastu taevast "p22stmise" k2igus, aga eks t6mmame netist uue...
Ikaldused ikkagi badblockidest tingitud olid...
woody lolliks minemise lahendasin kah 2ra - ma olin selle k2raka unustanud yhe mountpoindikylge - seal oli ReiserFS - reiser teeb "kernelipaanika" karmimate vigade korral.
Ainuke negatiivne asi, et peale hollivoodi toodangu ja porno ei julge sellele kettale enam midagi ladustada, seega peab hakkama emuula piinama ;(
A.
