15.01.2006 22:18:15
Überkeyboard - klaviatuur 1337-meestele! |
link :: Überkeyboard koduleht
Ajas ikka muigama küll selline asi
| 100% blank keyboard. Only For The Best. If you are an elite programmer who can write sophisticated code under tight deadlines, someone who makes impossible projects possible; or a Silver Web Surfer your colleagues turn to when they need IT advice: this keyboard is for you. Shouldn't your keyboard reflect your status as one of the elite? We think so! |
klaveri autor ise:
| Daniel Guermeur, born-to-be a programmer, and founder of Metadot Corporation, an open source software company, has invented Das Keyboard. Why? He still doesn't remember. He just did it. |
ostjad pajatavad:
"At first I was intrigued, but when I started using it two things happened: it was a joy to type and my colleagues looked at me like I was a superhero! I would not go back to a normal keyboard now."
-- Philippe H. |
Saab isegi Eestisse tellida:
http://www.verkkokauppa.com/popups/prodinfo.php?id=10227
_________________ "a rental car, three cheeseburgers and a head start."
viimati muutis SKG 15.01.2006 22:22:29, muudetud 1 kord |
313 |
Tbit
15.01.2006 22:18:51
imo seal pildil küll 100% blank pole asi , aga nuh, ünergeex only ikkagi
|OSTAN|-> T43 pikk jahutus |
230 |
wicked
| Kommentaarid: 68 loe/lisa |
63 |
15.01.2006 22:28:08
HV otsinguga "Überkeyboard" = 0 tulemust enne selle teema tegemist
eks kustutage ära kui kõik näinud on
viimati muutis SKG 15.01.2006 22:28:35, muudetud 1 kord |
313 |
Ho Ho
15.01.2006 22:28:18
Nagu ma seal teises teemas juba paar korda maininud olen siis minu valget värvi paari aastane noname klaver on poolel teel umbes samasuguse välimuse poole
Pea pooltel tähtedel ning nooltel on kirjad juba maas, mõni aasta veel ning saan ka teistelt kirjad maha.
87 |
silver010
15.01.2006 22:48:34
ilma kirjeteta nupud oleks päris lahedad tegeltei tea kas äkki kusagil lausa müüakse tava mõõdus 'blank' mustasid nuppe?
| Kommentaarid: 45 loe/lisa |
42 |
daddario
15.01.2006 23:16:41
Tee ise - ~800st kõrbekaari (ca 30.-), purk musta spraid (ca 60.-) ja lakki (ca pole õrna aimugi).
_________________ daddario@debianx:~$ |
| Kommentaarid: 4 loe/lisa |
Riivo
16.01.2006 15:57:15
| need märgid paremal kolme led'i juurdes võiks ka siis ära kaotada
221 |
j2nx
16.01.2006 16:35:27
Muidugi lihtne teha.
Lihvid nuppudelt kirjed maha. Katad kasvõi UV valguse käes helenduva värviga
Teine teema oleks lasta mudigui katta kroomvärviga. Mitte ise värvida, vaid lasta kohe katta, kiht on sama tugev, kui auto lakialune värv vms.
Blank Case-mod oleks iseenesest lahe.
Kast oleks lihtsalt risttahukas, lahe.
M!nA
18.01.2006 11:14:57
margusseril oli vahepeal huvitav klaviatuur......
olid küll nupud ja tähed aga kõik olid valedes kohtades
ühte nuppu ikka annab puhtaks nühkida rsk
_________________ TEL.:56477545 |
110 |
Riivo
18.01.2006 15:26:14
| M!nA kirjutas: |
ühte nuppu ikka annab puhtaks nühkida piix  |
lahusteid kasutades ei ole see üldse raske
221 |
Laurikre
18.01.2006 15:32:23
M!nA, Minu logitechi klaver peale 2 a igapäevast kastust hakkab küll juba tähtesid kaotama.
Kena selline libe taust jääb alla . Meenub ,et kunagi oli sellinekaredam
Laurikre:.
_________________ Need: Windows, .Net, Sharepoint, Exchange, Dynamics, Visual Studio, XNA, Expression, Silverlight, SQL and many other skills? Talk to me
Rohkem IT uudiseid iga päev BattleIT lehelt |
131 |
Renka
18.01.2006 19:58:30
| Laurikre kirjutas: |
| M!nA, Minu logitechi klaver peale 2 a igapäevast kastust hakkab küll juba tähtesid kaotama. |
Mul Microsoft Natural keyboard ... see vanem (ja mõnusam) mudel ja nuppudel on tähed ideaalselt peal ... kasutatud on umbes 10 aastat (täpset aastat ei mäletagi aga no millal see P100 ajastu oli ... siis esimese masinaga sai see muretsetud). Tühjalt seisnud pole kunagi ... kogu aeg miskise aktiivselt kasutatava masina taga.
61 |
Le Inc
18.01.2006 23:10:51
| ... ja kui plank klaver ära väsitab saad ju alati klepsud tähtedega juurde osta. Vanematel läpparitel, millel puuduvad eesti keelsed nupud kasutatakse neid üsna tihti.
| Kommentaarid: 56 loe/lisa |
54 |
FuN
20.01.2006 20:15:30
ei näe ikkagi asja mõtet ...
hind on ju sama, parem võta must isolaar teipi ja kleebi seed nuppude peale ...
ei aga m6te iseenesest on hea ju kui sa ka müüb
| Kommentaarid: 32 loe/lisa |
24 |
