praegune kellaaeg 26.10.2026 20:58:21
prigo
27.11.2005 16:44:56
Palun abi. |
Tervist,nimelt oleks vaja mul abi,sest oc jääb muidu poolikuks.Ma saan panna fsb 220kanti ja siis on minu 3,0prescott@3,3,kuid ega ma sealt edasi ei saa ka.Bioses ei saa nimelt cpule volti juurde anda,ma ise arvan et jääb juba voolu taha,üle 3,4ei taha ta kohe mitte kuidagi minna,kuna volti ei saa juurde anda.Ise mõtlesin et võiks uue biose peale panna,kuid pole leidnud sobivat ja ega ei oska ka.Kas keegi saaks aidata?!Oleks vaja biost,kus saab cpu´le volti juurde anda.Aitähh.
Field Value
Motherboard Properties
Motherboard ID 02/13/2004-I865P/PE-6A79AD4DC-00
Motherboard Name DFI PS82-BC/BL / PS83-BC/BL
Front Side Bus Properties
Bus Type Intel NetBurst
Bus Width 64-bit
Real Clock 200 MHz (QDR)
Effective Clock 800 MHz
Bandwidth 6400 MB/s
Memory Bus Properties
Bus Type DDR SDRAM
Bus Width 64-bit
Real Clock 200 MHz (DDR)
Effective Clock 400 MHz
Bandwidth 3200 MB/s
Chipset Bus Properties
Bus Type Intel Hub Interface
Bus Width 8-bit
Real Clock 67 MHz (QDR)
Effective Clock 267 MHz
Bandwidth 267 MB/s
Motherboard Manufacturer
Company Name DFI Corporation
Product Information http://sj.dfi.com.tw/Product/xx_product_by_category_us.jsp?PAGE_TYPE=US&CATEGORY_TYPE=MB&ARCHIVED_FLAG=N&INDEX_TYPE=MB
BIOS Download http://sj.dfi.com.tw/Support/Download/download_us.jsp?CATEGORY_TYPE=MB&INDEX_TYPE=MB
Field Value
CPU Properties
CPU Type Intel Pentium 4 530, 3000 MHz (15 x 200)
CPU Alias Prescott
CPU Stepping D0
Instruction Set x86, MMX, SSE, SSE2, SSE3
Original Clock 3000 MHz
Min / Max CPU Multiplier 14x / 15x
Engineering Sample No
L1 Trace Cache 12K Instructions
L1 Data Cache 16 KB
L2 Cache 1 MB (On-Die, ECC, ATC, Full-Speed)
Multi CPU
Motherboard ID OEM00000 PROD00000000
CPU #0 Intel(R) Pentium(R) 4 CPU 3.00GHz, 3000 MHz
CPU #1 Intel(R) Pentium(R) 4 CPU 3.00GHz, 3000 MHz
CPU Physical Info
Package Type 478 Pin uPGA
Package Size 3.50 cm x 3.50 cm
Transistors 125 million
Process Technology 7M, 90 nm, CMOS, Cu, Low-K Inter-Layer, High-K Gate, Strained Si
Die Size 112 mm2
Core Voltage 1.4 V
I/O Voltage 1.4 V
Typical Power 89 - 103 W (depending on clock speed)
Maximum Power 109 - 127 W (depending on clock speed)
Field Value
BIOS Properties
BIOS Type Award
Award BIOS Type Phoenix - AwardBIOS v6.00PG
Award BIOS Message (83iid213) EVALUATION ROM - NOT FOR SALE
System BIOS Date 02/13/04
Video BIOS Date 04/04/23
BIOS Manufacturer
Company Name Phoenix Technologies Ltd.
Product Information http://www.phoenix.com/en/products/default.htm
BIOS Upgrades http://www.esupport.com/biosagent/index.cfm?refererid=40
Problems & Suggestions
Suggestion Are you looking for a BIOS Upgrade? Contact eSupport Today!
Field Value
North Bridge Intel Springdale i865PE
Field Value
South Bridge Intel 82801EB ICH5
Aitähh abi eest!
Kas keegi ei oska aidata
| Kommentaarid: 17 loe/lisa |
15 |
