uus teema   vasta Raud »  Kõvad kettad »  S-ata kettast näitab win-is aga sisse minna ei saa märgi kõik teemad loetuks
marti252
sõnum 16.10.2005 17:24:19 S-ata kettast näitab win-is aga sisse minna ei saa vasta tsitaadiga
Probleem selles, et winis kadus mingi sys fail ära ja kui hakkab loadima win-i siis teeb reboodi. nüüd panin teisele arvutile taha kõvaketta, et seal vajalik inf kätte saada. Kuigi windosis näitab, et ketas on olemas, ei saa sinna sisse minna.
Mõlemad kettad on sata ja mõlematel on ntfs peal.
Pole varem kahte sata ketast arvutil proovinud.
Kas seal on midagi teistmoodi, kui panna udma ketas taha
Ette tänades
Leidsin netist surfates, et põhjus on et kettal on kadunud File System s.t. et RAW mitte NTFS
Lahendus
The format of my hard drive is shown as Raw in Disk Managment under Windows 2000, XP, or 2003.
Question
Why is my drive shown with a Raw format in Disk Management under Windows 2000, XP, or 2003?
Answer
Problem:
The hard drive is inaccessible and is shown with a "Raw" format in Disk Management under Windows 2000, XP, or 2003.
Cause:
This issue indicates that the partition table on the hard drive has become corrupt or damaged. While the data may still remain on the physical hard drive, it will not be accessible through normal operating system access methods. This issue can be caused by the following reasons:
* Viruses or spyware on the computer.
* If the computer does not support the hard drive capacity correctly.
* If the BIOS is not configured correctly for the hard drive
* If the hard drive is physically failing or there are media errors on the drive.
Resolution:
To ensure that the hard drive is working correctly and free from physical defects, please test the drive following the directions in Article ID 59. If no errors are detected by our diagnostics, the hard drive is physically working correctly. You will need to use a data recovery program or data recovery company to access and recover the data from the hard drive. Once data recovery has been performed, we recommend low-level formatting the hard drive with our diagnostics from the directions in Article ID 1211 before repartitioning and reformatting the drive for usage again.
Nüüd probleem selles, et mis moodi seda stuffi kätte saab'
Känksterrr
Känksterrr
sõnum 09.11.2005 21:43:10 vasta tsitaadiga
endal sarnane probleem ainult et et mul on 1 sata ketas.
Lammutasin hommikul arvuti käima ja ennäe imet iga kord kui peaks winni logima hakkama reboodib.
Proovisin sõbra arvutis (millel on primary slave IDE kaabliga ) Aga iga kord kui asi jõuab nii kaugele et see mu ketast näitama peaks teeb komp insta resa.
Ma arvan asi on viirustes ja spywares.
oleks ka tänulik kui keegi annaks selle StuFFi kätte.
-vodafone-
-vodafone-
sõnum 09.11.2005 22:07:39 vasta tsitaadiga
äkki saab knoppix´iga kätte? icon_rolleyes.gif proovida ju võiks
Kommentaarid: 246 loe/lisa Kasutajad arvavad:  :: 1 :: 3 :: 217
Känksterrr
Känksterrr
sõnum 12.11.2005 22:34:33 vasta tsitaadiga
Käisin maxtori kodukal ja leidsin sealt yhe proge "powermax" sellega sain oma kõvaketta ära formattida (quick) ja asi timmis.
Nickelby
sõnum 15.11.2005 23:07:42 vasta tsitaadiga
Kui data oluline on mingil viisil failisysteemi kaotanud/ formaaditud/kustutatud/partitsioone muutnud kettal, siis soovitaksin kasutada sellist programmi nagu Ontrack Easy Recovery. Oli vist versioon 6.0 Endal on sellega õnnestunud saada kätte info kettalt millel olid partitsioonid ymber muudetud ja ka formaaditud.. Toimib ilusasti windowsis, ainult et kui partitsioone ei ole ja raw modes töötab siis failinimesid ei tuvasta enam. faililaiendi aga küll. et kui tegemist filmide , muusika jne asjadega siis ei ole suuremat probleemi, aga kui näiteks mingite pisemate failidega mida alati kipub palju olema, siis natukene keerulisem. Data saad kätte raudselt, iseasi kas sellega enam midagi peale hakata on siis..Kahjuks tasuline icon_sad.gif
Ehk on mingeid samalaadseid tasuta programme kah, siinkohal google abiks. Lihtsalt programm peab olema suuteline lugema infot kettalt millel puudub igasugune failisysteem.
Have A nice Day!
Kommentaarid: 115 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 102
Känksterrr
Känksterrr
sõnum 20.11.2005 13:12:03 vasta tsitaadiga
Ise kasutan "Get data back for NTFS" Väga viis+ proge.
ka tasuline.
