praegune kellaaeg 16.11.2026 01:26:01
leon34
13.08.2005 18:41:02
Juhtmevaba kodu ADSL ruuteri soft |
The Siemens Santis50, the Ericsson HN294dp and the Dynalink RTA300W devices provides a web management interface and the classic telnet CLI for administration purposes. By default these services are available only from the local network, but can be optionally activated also on the WAN interface. Sending trigger packets to the management port (280/http-mgmt), the device "freezes" the web interface, allowing unauthenticated connection to the telnet CLI.
http://www.i-totalsecurity.net/secalert2.php
OFFF
14.08.2005 13:49:01
Default conffiga 6nneks piirdub asi LAN'iga. Kui kellelgi on seda purki ka"epa"rast v6iks nüüd uurida, kas "va"ljaspoolt" kahh asi toimib. Kui nii, siis on asi kuri ja tuleks Elioni (ja"rjekordselt, vastukajata ;( ) teavitada.
A.
[edit] See oleks "elioni purkide turva" teemasse tegelikult paremini sobinud, selle jura asemele, mis sinna hetkel l6ppu on sokutatud[/edit]
_________________ Õnnelikul malakamaal ei nuteta! Parem käsi abistab. Sõidame! |
| Kommentaarid: 32 loe/lisa |
29 |
