praegune kellaaeg 16.10.2026 15:50:03
kickflip
11.08.2005 16:43:59
Süntesaator Yamaha PSR-1500(help) |
oman yamaha psr 1500...Kuidas sellele mingit updati v6i midagi sellist korraldada...olen kuulnud ,et midagi on v6imalik...tahaks uusi "sounde" ja"rütme"
c
13.08.2005 09:14:47
väike otsing netis andis sellise tulemuse:
USB TO DEVICE is also used for connecting the keyboard to the Internet using an optional USB-Ethernet or USB Wi-Fi adaptor. You'll need your computer to activate an account, but once that's done, you can browse through songs and styles and download music directly into your keyboard, play it, score it and learn it - no computer required.
sellelt lehelt siis: http://www1.yamaha.com.sg/256.html
niiet vaja netti see asi saada, sealt siis saab juba uusi sounde siis alla laadida.
| Kommentaarid: 4 loe/lisa |
