uus teema   vasta Tarkvara »  Arvutimängude foorum »  Hard Truck: Apocalyptic Wars märgi kõik teemad loetuks
EvilKatarn
diivanilill
EvilKatarn
sõnum 25.05.2005 14:09:09 Hard Truck: Apocalyptic Wars vasta tsitaadiga
link :: Kodukas
Hard Truck: Apocalyptic Wars – a third person action-driving game.
The plot puts you in a post-apocalyptic world.
You enter the reality of the year 223 since Great Cataclysm. The world we knew was erased as the result of a mysterious accident. In less than one hour the most part of the world population disappeared. Those who survived try to adapt to new conditions. There are new cities and settlements with trading alliances and mobsters. The vital transport hubs are controlled by gangsters and pillagers. Hence, armored heavy truck drivers have become the only resisting force against the “shadow” elements.
You are to drive through dangerous regions of the new Earth with its mysterious places and hostile habitants. Your ultimate goal is to reveal the guarded secrets of the lost civilization. Your heavy truck is the only hope. You will need it to travel, earn your lining and fight your way through the perilous areas. It’s crucial that you continuously upgrade your truck. Your ability to equip smartly your “iron buddy” will make or break the success of your journey. So, go to towns and villages, trade with them, help them and you are sure to raise the cash required for powerful weapon and new gadgets.
The action and the RPG elements are closely intertwined to create a stunning game experience:
the action part embraces the driving, chilling combats with the use of wide range of destructive weapons;
the RPG part allows you equipping your truck to flee your enemies from battle field.
Tundub olema päris lahe asi UG tuunimise vahele. Peaks plaanide järgi sellel aastal välja tulema. Kah venelaste tehud.
Kommentaarid: 110 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 81
One
sõnum 25.05.2005 14:28:47 vasta tsitaadiga
EvilKatarn
diivanilill
EvilKatarn
sõnum 25.05.2005 14:32:17 vasta tsitaadiga
nagu juba tutvususes kirjas on: The plot puts you... icon_lol.gif
Paganarh
Paganarh
sõnum 27.07.2006 12:05:29 vasta tsitaadiga
Tegelikult on siis tegemist Hard Truck: Apocalypse (vb hetkel kui amddude teema lõi, oli nimi teine).
Ise ma passisin sellele mängule peale kuna mängutegijad hõikasid välja lause "it's Fallout on wheels!" ja see pani mind kõvasti kõrvu liigutama... AGA (nagu ikka) läks asi siiski teistmoodi. Õnneks mängutegijad olid piisavalt ausad et vabandasid rahva ees, et jah, nagu ikka meil emakesel Venemaal- hoteli kak lutshe no vyshlo kak vsegda.
Siiski, mis neil õnnestus tekitada? Suht vastukäiva mängu- Gamespot andis 4.4 punkti (sealsamas andis 130 inimest keskmiseks hindeks 6.9) ning vene saidid nagu näiteks ag.ru andis tervenisti 75% (ja need tüübid on tuntud oma hindamise jõhkruse üle, ei anna armu ka kaasmaalaste mängudele). Aga hindamised hindamisteks, see kõik on täiesti iga inimese oma maitsevärk kuidas ja kas talle see mäng meeldib.
Minule näiteks meeldis. Miks? Esiteks see on post-apo icon_biggrin.gif (ma olen täiesti haige selliste mängude peale). Kuigi see maailmalõpp mis mängus toimus ei olnud standardne tuumapauk vaid tõsisemat sorti õhumürgitus mis 95% faunast ja homo'st maha niitis. Keegi keenius avastas et hei, paneme maskid pähe ja siis me ei sure mürgi kätte (ning mängutegijad ei pea nägusid animeerima). Kuidas inimesed toituvad, seda öeldud pole kuigi hirmsasti tahaks teada. See on esimene suur viga HTA juures- kogu plot on kuidagimoodi kokku klopsitud. Võetud on hunnik huvitavaid ideid, need sisse visatud ja nii jäetudki. Ilma seletusteta, ilma taustata. Kujutan juba ette kuda dev'id istusid mornis vaikuses täissuitsetatud toas viinapudeli taga, iga poole tunni tagant ühel neist nägu selgines ja hüüatas "eureka! Teeme nii et ühes riigis on kõik noored inimesed hullud! Vahepeal ründavad sind, vahepeal on sõbrad! Meie kangelane peab päästma vanad ja väetid!" kõik aplodeerivad, asi pannakse mängu sisse...ja? Miks nad hullud on? Misvärk on? Kas neid ei saaks äkki kuidagi päästa iseendi käest? Eip.
Aga mängu protsess ise on täitsa kaasakiskuv. Alustad mingi vana veoautoromuga millele on mingisugune PKS taoline trumliga kula peale keevitatud ja hakkadki siis pihta. Tahad teed missioone või vead kraami laiali, äkki hoopis lähed bandiitidele jahti pidama? Kuigi nendele ei pea vast spetsiaalselt jahti pidama minema- neid on ikka hordide kaupa. Mõnes kohas (peamiselt ristmikel) tuleb neid lõputult- parem on sealt sajaga läbi vuristada, muidu on õige pea rakett summutis.
Kogu auto upgrademise teema on lihtne ja arusaadav, on 5 eri autotüüpi ja neile on omakorda igalühele ca 5 erinevat kereuuendust (eraldi kabiinile-mootoriosale ja eraldi tagaosa jaoks). Peab ütlema et autod on väga hingega tehtud- nad näevad välja hullult stiilsed ja tõesti väga post-apo'd icon_smile.gif Väga meeldiv on leida oma vanale heale Ural'ile uus kereuuendus mis lubab panna katusele mingi eriti suure relva, näiteks neljatorulise õhutõrjekahuri.
Mängu protsess ise on suhteliselt pikk (oleneb kui palju sa sidequeste ja kaubandust teed) ja vahest frustreeriv. Mõnes alas tuleb liialt palju vihaseid vastaseid pidevalt vastu ja mingi hetk ma avastasin et polegi enam raha masina parandamiseks- pidi kiirelt kolistama tagasi eelmistesse "riikidesse" ning seal näiteks kartulaid vedama et raha teha. Muideks, vastased upgradevad relvastust vastavalt sinule- niiet kui sa mingi koletisliku elephant-klass plasmakahuri külge poogid siis pahalased võlgu ei jää. Sestap ma mängisin enamuse mängust läbi vanade heade kuulipritside toel.
Assatuss kui pikk tekst tuli. Põmst siis summa summaarum: kui teid ei häiri kohutav voiceacting, vahest liialt kuntslikult pikaks venitatud missioonid (mis on enamjaolt suht üheülbalised) ja meeldib suurte madmax stiilis veokitega ringi leekida, niites vastaseid raipu vasakule ja paremale siis see mäng võiks meeldida küll.
Mulle läks peale. Meeldiv ajaviide.
Nüüd jääb lisapakki ootama mis tuleb välja sügise paiku ja mille tegevus toimub vanas heas USA's
MMX-Power
MMX-Power
sõnum 27.07.2006 12:16:52 vasta tsitaadiga
olen olnud hard trucki fänn esimesest osast alates. tänud, et kaevasid selle teema ülesse. nüüd lähen uurin natukene ja siis otse poodidesse otsima icon_razz.gif thumbs_up.gif
Minu Blogi
Kommentaarid: 37 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 33
Paganarh
Paganarh
sõnum 27.07.2006 19:41:52 vasta tsitaadiga
ahja. mängu lõpp imeb... kohutavalt, isegi ütleks et jubedalt. ma ei mäletagi nõmedamat lõppu mõnel mängul kuigi habe juba maani.
et siis jah- see kes mängima hakkab, ärgu väga lõpu peale erutugu icon_biggrin.gif
Cooler(-10)
sõnum 28.07.2006 15:06:23 vasta tsitaadiga
miskipärast tuleb 3dmark01 meelde icon_rolleyes.gif selle mängu scriine vaadates
Kommentaarid: 15 loe/lisa Kasutajad arvavad:  :: 2 :: 5 :: 5
Tuletegija
Tuletegija
sõnum 29.08.2006 10:58:57 vasta tsitaadiga
Ise ka nüüd seda asja viimased paar päeva pelanud. esimene mulje oli küll stiilis WTF aga kui asi edasi arenes läks päris lõbusaks juba.
vihjeid neile kes mängida tahavad ja ei viitsi palju mõelda..
1. relvastust osta pole mõtet, seda jagavad bandiidid või ükskõik kes muu kelle sa piki taevast saadad, suht lahkelt.
2. veokitega on nii et esimesest rümast suht kähku lahti saada tuleks. ja kui ural käes siis seda ei ole enne vahaetada mõtet kui miskit toekamat leiab. belaz kui selline on suht mõttetu, mis peale seda tuleb, veel ei tea icon_biggrin.gif
3. vahepeal tasub niisama looduses ringi kruisida kuna vahest on mingit manti niisama maha vedelema unustatud ja sealt suht toredaid asju leida võib
4. kui vähegi võimalik siis soovitaks vältida igasuguste rohelise markeeringuga veokite rammimist kuna tavaliselt järgneb sellele see et sa avastad et sa ei saa minutitki rahu ilma et keegi sind teise ilma saata tahaks icon_biggrin.gif sama kehtib ka halli markeeringuga rahva kohta. punased on sinuga nagunii sõjajalal icon_biggrin.gif
väidetavalt pidavat olema ka võimalusi ühe või teise fraktsiooniga suhteid parandada aga ise miskit sarnast ei näinud.
kokkuvõttes aga suht lahe mäng ja isikliku arvamuse alusel teenimatult allahinnatud gamespoti poolt.
Rolling Thunder
Kommentaarid: 28 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 26
Timberg
ööKARU
Timberg
sõnum 02.09.2006 10:51:01 vasta tsitaadiga
Kauaks see mäng peaeluda võib? Kunagi sai Fallouti mängitud sadu tunde, aga enamus uued mängud jätavad täiesti külmaks. Ühesõnaga.. peale mõnda tundi ammendavad ennast.
Tuletegija
Tuletegija
sõnum 03.09.2006 12:53:55 vasta tsitaadiga
mingiks paariks päevaks on ikka tegemist.
kusjuures meeldiva üllatusena avastasin seda et sellel asjal story vähemalt 2 erinevat on
ala kui koher alguses kui sa esimesse linna jõudma akkad seda tibi perse ei saada ja ringsõidu ära teed on oopis teine story sealt edasi
Rolling Thunder
Timberg
ööKARU
Timberg
sõnum 03.09.2006 12:57:40 vasta tsitaadiga
Tuletegija kirjutas:
ala kui koher alguses kui sa esimesse linna jõudma akkad seda tibi <b>piix</b> ei saada ja ringsõidu ära teed on oopis teine story sealt edasi
MIsket storyst eraldiseisvat mängu/ liikumis ja tegutsemisvabadust ka leidub?
sõnum 03.09.2006 19:44:26 vasta tsitaadiga
on... sa ei pea ühtegi missiooni tegema, kui ei soovi
Paganarh
Paganarh
sõnum 03.09.2006 20:26:32 vasta tsitaadiga
anoh, see tüütab ära suht imho. koos stoorigagi on ringisõitmist rohkem kui paagi eest
Dominus
Dominus
sõnum 26.09.2006 16:41:22 vasta tsitaadiga
Paganarh, su see pikem jutt eespool oli thumbs_up.gif päev läks kohe rõõmsamaks ning tekkis väike isugi mängu vastu :]
Kommentaarid: 104 loe/lisa Kasutajad arvavad:  :: 4 :: 1 :: 76
Paganarh
Paganarh
sõnum 03.10.2006 13:00:02 vasta tsitaadiga
tänan,tänan icon_smile.gif HTA lisapaketile on ka nüüd kodukas olemas. Asja pealkirjaks "Rise of Clans". Tegevus toimub, nagu enne mainitud sai, USAs (mida uuesti koloniseerima hakatakse). Lubatud on kõvasti uut contenti, hunnik relvi ja autosid. Pimedamat ööd (see on tõesti probla originaalis) ja spetsiifilist area damaazhi - ehk siis saab vastasel tukke, kumme ja iluvõresi otsast ära lasta (originaalil oli vaid 2 areat - auto kabiin ning kaubaosa)
Dominus
Dominus
sõnum 03.10.2006 16:13:25 vasta tsitaadiga
Asdaf
sõnum 04.10.2006 10:51:05 vasta tsitaadiga
Kus seda müüakse ?
Back to Nvidia .
indumen
indumen
sõnum 06.12.2006 01:22:48 vasta tsitaadiga
hull vana teema nagu ma aru saan aga siiski ehk on mõni abimees võtta siit icon_biggrin.gif
hell sain siis sinna kõrbesse ära ja kohe esimesel missioonil probleem nimelt linnast ei antud seda OIL trucki ja pelasin mängu ainult quicksavede toel seega põhisave mingi alguses :S ja kõik quicksaved said tehdud pärast seda kui missioon juba käsile võetud
küsimus kas missiooni kuidagi uuest alustada ei saa või siis vahele jätta cheate ka käima ei saanud et seda vajalikku autot saada :S
ükskord me võidame niikuinii
Kommentaarid: 211 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 183
Paganarh
Paganarh
sõnum 06.12.2006 10:12:54 vasta tsitaadiga
See asi parandati patchiga ära aga mäletan et kui esimest korda läbi mängisin siis oli sama probleem.
Loodan et sul on mingi save olemas enne seda kui sa sinna linna sisse sõidad ja missiooni võtad. Ma loadisin mitu korda ning võtsin missiooni uuesti, klõpsisin mitu korda veel dialoogi ja mingi hetk sõitsingi oil truckiga välja. (Nival foorumitest leiad ka selle kohta paar teemat)
btw, ostsin venekeelse versiooni ka ära. kes iganes oskab veel idanaabrite keelt siis soovitan sama teha, hoopis teine asi on mängida kuna voiceacting ei ime nii kõvasti icon_smile.gif
Surnu
sõnum 06.12.2006 10:26:48 vasta tsitaadiga
Paganarh kirjutas:
seal oli probleemiks see et see dialoog tuligi ära vaadata/kuulata (mida muidugi tihti kärsitusest ei viitsita teha), muidu oil truck välja ei sõitnud, aga noh üldiselt tasub jah nivali foorumist vigade kohta otsida, seal nii mõned kahjuks olid/on.
Kommentaarid: 35 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 35
indumen
indumen
sõnum 06.12.2006 20:39:36 vasta tsitaadiga
save pole jah selles ongi kõige suurem ebaõnn sugulane jõudis just eile samasse kohta peab vist temalt laenama icon_biggrin.gif
