uus teema   vasta Tarkvara »  Turvalisus »  Desktop.html märgi kõik teemad loetuks
taipohh
sõnum 02.02.2005 06:07:45 Desktop.html vasta tsitaadiga
puhastamise hoos kustutasin sellise faili nagu desktop.HTML
(sest mingi asja hakkas desktopil kuvama (adware) ja mõtlesin,et kustutamine aitab,
aga oh hullu
nüüd asi sihukene,Start nuppu ei näe,desktopi alumine äär on ainult normaalne st.reageerib taustamuutusele jne.
ülejäänud osa on kahtlane, ja parem hiireklõps toob kahtlase menu
View source ja encoding,print,refresh ja properties <--vajutades tuleb mingi imelik certificate bla bla ette.
view source annab sihukest asja.
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
***** This file is automatically generated by Microsoft Windows *****
--------><HTML><HEAD>
<META http-equiv=Content-Type content="text/html; charset=windows-1257"></HEAD>
<BODY
style="BORDER-RIGHT: medium none; BORDER-TOP: medium none; BORDER-LEFT: medium none; BORDER-BOTTOM: medium none"
bottomMargin=0 bgColor=#000000 leftMargin=0 background="" topMargin=0
rightMargin=0><IFRAME id=0
style="BACKGROUND: none transparent scroll repeat 0% 0%; LEFT: 0px; WIDTH: 800px; POSITION: absolute; TOP: 1px; HEIGHT: 571px"
name=DeskMovrW marginWidth=0 marginHeight=0
src="file:///C:/WINDOWS/desktop.html" frameBorder=0 scrolling=no
subscribed_url="C:\WINDOWS\desktop.html" resizeable=""> </IFRAME>
<OBJECT id=ActiveDesktopMover
style="LEFT: 0px; WIDTH: 0px; POSITION: absolute; TOP: 0px; HEIGHT: 0px; container: positioned; zIndex: 5"
classid=clsid:72267F6A-A6F9-11D0-BC94-00C04FB67863><PARAM NAME="Interval" VALUE="500"><PARAM NAME="SizerID" VALUE="ActiveDesktopMover"><PARAM NAME="Enabled" VALUE="True"><PARAM NAME="TargetName" VALUE="DeskMovr"><PARAM NAME="WindowOnly" VALUE="False"></OBJECT>
<OBJECT id=ActiveDesktopMoverW
style="LEFT: 0px; WIDTH: 0px; POSITION: absolute; TOP: 0px; HEIGHT: 0px; container: positioned"
classid=clsid:72267F6A-A6F9-11D0-BC94-00C04FB67863><PARAM NAME="Interval" VALUE="500"><PARAM NAME="SizerID" VALUE="ActiveDesktopMoverW"><PARAM NAME="Enabled" VALUE="True"><PARAM NAME="TargetName" VALUE="DeskMovrW"><PARAM NAME="WindowOnly" VALUE="True"></OBJECT>&nbsp; </BODY></HTML>
mis ma tegema peaksin et desktop jälle normaalseks saada......
ma juba pool ööd üritan siin midagi teha!
EDIT: mingi Active X controlls jama loobib ka ette, näiteks ku runi kirjutan
services.msc ütleb et cannot display properly active x not allowed vms.
EDIT2: vahelpeal tahab ta ise desktopi normaalseks visata,aga tuleb jälle se,Active x jama!
Tapa sionist!
Kommentaarid: 3 loe/lisa Kasutajad arvavad:  :: 2 :: 0 :: 1
airm
sõnum 02.02.2005 10:54:52 vasta tsitaadiga
Tekita uus profile, äkki tehakse uus puhas desktop ka(kui see tähtis fail muidugi liiga tähtis polnud).
Kommentaarid: 56 loe/lisa Kasutajad arvavad:  :: 2 :: 1 :: 50
taipohh
sõnum 02.02.2005 15:27:37 vasta tsitaadiga
kui safe modega lähen siis on desktop normaalne, nii minu kasutajaga kui administraatori omaga, probleem veel selline et kaspersky leiab mingi
raterape1_3.dll et mingi keyloger ja se on memorys (winlogon) ja seda ei saa maha kuidagi
proovisin safemodes, ja neti välja lülitades. ikka, ja veel üks fail mis on infected aga maha ei lase kustutada on k4800elmehqa0.dll
pealegi on nüüd mu taskmanager igast imelikke processe täis mida enne ei old.
kui keegi oskab soovitada mingit head tõrjet/hävitajat peale S&D,AdwareSE,Webroot spysweeper,kaspersky....... kõigiga käisin mitmeid kordi üle, aga ikka mingi junn jääb kuhugi pesitsema! icon_mad.gif
Edit:kas keegi selle Active X controlside kohta siis oskab öelda?
sest pärast restarti paistab ta ütlevat desktopi kohta ka et cannot display properly! your current security settings probhit you using active X and .bla bla bla.....
Tapa sionist!
sõnum 03.02.2005 17:12:00 vasta tsitaadiga
Seda Active X settingute värki sai vist IE'st kruttida. Täpsemalt vist Tools-Options-Security alt. Kui saad, siis lase IE settingud defaulti tagasi - Reset Web Settings.
M: Intel i5 4590 protsessorid
M: HP Elitedesk 800 G3 SFF
Kommentaarid: 757 loe/lisa Kasutajad arvavad:  :: 1 :: 1 :: 568
aatom
sõnum 20.05.2005 22:51:40 vasta tsitaadiga
mis siis selle lahendus oli? mul sama jama, et desktop.html arvutis sees...
Kommentaarid: 71 loe/lisa Kasutajad arvavad:  :: 6 :: 0 :: 57
weyx13
weyx13
sõnum 21.05.2005 03:20:59 vasta tsitaadiga
http://www.geekstogo.com/forum/downloadtrojan_and_desktophtml-t25726.html
kui aitab, siis tore. Probleem sarnane
Inimkond jaguneb üldjoontes kaheks:
ühed, kes jagavad meid kaheks ja teised, kes seda ei tee.
