sõnum  |
stepzter
13.07.2005 16:05
| Graafikakaartide kiirus on tõusnud märgatavalt kiiremini, kui prosade oma. Seega, kui paar aastat tagasi koormas mäng 50% prosat ja videokaart oli täies ulatuses pudelikaelaks, siis nüüd videokaart ( või -kaardid) istub pool aega tööta ja prosa ägab 100% koormuse all.
| Kommentaarid: 25 loe/lisa |
25 |
13.07.2005 20:00
NVIDIA GeForce 7800GT Has 20 Pipes
VR-Zone has learned that the upcoming GeForce 7800 GT will be 20 pipes instead
of 24 pipes as intially reported. The vertex shader could probably stay at 8 and
ROP at 16. The core clock for 7800GT is 400MHz instead of 335MHz initially thought.
It will be interesting to see if the 4 hidden pipes can unlocked on the 7800 GT to
become GTX. The 7800GT is slated for launch on 11th Aug at Quakecon 2005 and
MRSP for this card is US$449. Also NVIDIA won't release their 7800 Standard yet
until their 6800 inventory are cleared.
http://www.techpowerup.com/?4153
NVIDIA's Secret Weapon : G71
At first we thought that G71 is for mid range segment to replace 6600 series but it turned
out otherwise. The secret weapon for NVIDIA against ATi's R520 is actually G71, the successor
to the current G70. VR-Zone has learned that G71 is based on a finer 90nm process technology
at TSMC like the R520. NVIDIA is likely to make a switch when the process technology is more
mature like towards end of the year. No doubt, the core frequency can be clocked higher on
finer process. However, we can't rule out the possibility of releasing 7800Ultra on the 90nm
G71 core when R520 launched since volume production are not expected for such a high-end
GPU. Of course it could be based on 110nm process initially as INQ has suggested. 32-pipes
or not, it is still unknown.
http://www.vr-zone.com/?i=2445&s=1
umm, nvidia ju kardab räigelt seda 90nm tehnoloogiat
| Kommentaarid: 1006 loe/lisa |
727 |
Elof
13.07.2005 20:05
Peaks aga matrosovlikut pea ees pimedusse hüppama ?
Ilmselt 90nm probleeme nii ATI'il kui nVidial
viimati muutis Elof 13.07.2005 20:06, muudetud 2 korda |
175 |
Ho Ho
13.07.2005 20:05
| umm, nvidia ju kardab räigelt seda 90nm tehnoloogiat |
Loomulikult et kardab, vaata kuidas läks tehnoloogia vahetusega NV30 seerial ning kuidas ATI r520'ga vaevles/vaevleb. Kui pole korralikku uurimustööd tehtud pole mõtet kiirustada, eriti siis kui praeguse tehnoloogiaga tehtud kaardid on hetkel saada olevast kiireimad ning konkurents puudub.
86 |
HDTanel
Overclocker
13.07.2005 20:16
Kas mitte pole nVidia kaardid suts aeglasemad 3DMark05-s, et kasutavad PS3 kui ATI kaardid PS2 tuge? Winter möliseb siin, et see ei mõjuta midagi. Ei tahaks nagu uskuda, et midagi ei mõjuta
_________________ Minu Youtube - HDTanel <- EESTIKEELSED VIDEO ÜLEVAATED!
Minu Facebook - HDTanel
Minu Twitch - HDTanelEST |
| Kommentaarid: 628 loe/lisa |
491 |
lamp
13.07.2005 20:25
| PlatoonSgtElias kirjutas: |
| Kas mitte pole nVidia kaardid suts aeglasemad 3DMark05-s, et kasutavad PS3 kui ATI kaardid PS2 tuge? Winter möliseb siin, et see ei mõjuta midagi. Ei tahaks nagu uskuda, et midagi ei mõjuta |
kas 3dmark05 kasutab ps3?
144 |
HDTanel
Overclocker
13.07.2005 20:56
Noh on ju valikud olemas ja by default on nvidial Pixel shader 3
Vertex Shader Profile 3_0
Pixel Shader Profile 3_0
491 |
13.07.2005 21:00
ja oled sa pildis vahet märganud? ma küll ei ole
727 |
Ho Ho
13.07.2005 21:03
Aga on keegi kiiruses vahet märganud?
Kusagilt peaks ju saama muuta kas kasutada sm3 või sm2
86 |
727 |
HDTanel
Overclocker
13.07.2005 21:09
by default lasevad kõik ikka... nii nagu ette nähtud. Lihtsalt tahan näha kas vahet ka on neil asjadel. Ei tasu ikka niisama ka naerma hakata kui proovinud ple.
491 |
margusser
167 |
HDTanel
Overclocker
14.07.2005 23:00
Kahtlane... kus link on?
viimati muutis HDTanel 14.07.2005 23:01, muudetud 1 kord |
491 |
14.07.2005 23:00
32 piibuga tehakse 50k kah ära vast
varsti 3dmark 05 ka seal 50k kandis ja prosed ikka venivad täiega
727 |
Ho Ho
14.07.2005 23:08
| varsti 3dmark 05 ka seal 50k kandis ja prosed ikka venivad täiega |
Vast siis kui dualcored on FX/PM efektiivsusega ~6GHz juures või siis kui Inteli Itanium2 ja Xeon lõpuks kokku saavad ~4-5GHz kandis, varem tõenäoliselt mitte. Prose on ikka väga jõhkraks piduriks selliste kaartide puhul nign praegu pole midagi näha kah et olukord märgatavalt paraneks.
86 |
Auron
15.07.2005 08:45
| Justnimelt.PS3'ga on lihtsam renderdada ja sellest peaks tulema ka kiirusekasv.
123 |
Boot
15.07.2005 15:30
| Ho Ho kirjutas: |
Vast siis kui dualcored on FX/PM efektiivsusega ~6GHz juures või siis kui Inteli Itanium2 ja Xeon lõpuks kokku saavad ~4-5GHz kandis, varem tõenäoliselt mitte. Prose on ikka väga jõhkraks piduriks selliste kaartide puhul nign praegu pole midagi näha kah et olukord märgatavalt paraneks. |
mängude puhul kindlasti aga 3dmarkis(uuemates) pole prose küll hetkel piduriks.
| Kommentaarid: 27 loe/lisa |
razor
15.07.2005 15:30
| 05'es just prose hetkel piduriks...
115 |
margusser
15.07.2005 15:31
Boot, 2005-s on ikka küll
_________________ Liigutan raha eest |
167 |
tonism
15.07.2005 15:41
| niipalju, kui mina olen aru saanud, ei ole SM2 ja SM3 mitte mingit pildi vahet. erinevus pidavat olema sellest, et SM3's saab asjad tunduvalt lihtsamini ära teha, tänu millele lüheneb ka käskude mälumise aeg. vähemalt kusagilt kunagi hakkas nii silma, aga võin ka eksida
razor
15.07.2005 16:55
| kui programm ei ole SM3 native siis ei saa ta mitte midagi juurde sellest...
115 |
15.07.2005 19:14
| razor kirjutas: |
| 05'es just prose hetkel piduriks... |
eks igalpool ole prose piduriks..
aga mis sa tahad öelda, et 2 x 32 piibuga kaarti @ SLI/CF oleks tulemus sama?
ui oleks, skoorid kasvaks väga normaalselt
727 |
razor
16.07.2005 12:30
| ainult GT3 pealt...
115 |
727 |
Scart
16.07.2005 19:03
| Winterwind kirjutas: |
igasugu toredat "infi"
seda 800mhz on air värki tahaks küll näha
eriti 110nm tehnoloogial  |
arvestades, et käivad jutud nvidia pullitegemisest ehk siis 7800GTX on sama, mis eelmise põlvkonna 6600 ning g71 on 90nm peal.... siis miks mitte (antud info oli nvzone'is aga eemaldati nvidia käsul)
| Kommentaarid: 113 loe/lisa |
95 |
