taipohh
02.02.2005 05:07:45
Desktop.html |
puhastamise hoos kustutasin sellise faili nagu desktop.HTML
(sest mingi asja hakkas desktopil kuvama (adware) ja mõtlesin,et kustutamine aitab,
aga oh hullu
nüüd asi sihukene,Start nuppu ei näe,desktopi alumine äär on ainult normaalne st.reageerib taustamuutusele jne.
ülejäänud osa on kahtlane, ja parem hiireklõps toob kahtlase menu
View source ja encoding,print,refresh ja properties <--vajutades tuleb mingi imelik certificate bla bla ette.
view source annab sihukest asja.
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
***** This file is automatically generated by Microsoft Windows *****
--------><HTML><HEAD>
<META http-equiv=Content-Type content="text/html; charset=windows-1257"></HEAD>
<BODY
style="BORDER-RIGHT: medium none; BORDER-TOP: medium none; BORDER-LEFT: medium none; BORDER-BOTTOM: medium none"
bottomMargin=0 bgColor=#000000 leftMargin=0 background="" topMargin=0
rightMargin=0><IFRAME id=0
style="BACKGROUND: none transparent scroll repeat 0% 0%; LEFT: 0px; WIDTH: 800px; POSITION: absolute; TOP: 1px; HEIGHT: 571px"
name=DeskMovrW marginWidth=0 marginHeight=0
src="file:///C:/WINDOWS/desktop.html" frameBorder=0 scrolling=no
subscribed_url="C:\WINDOWS\desktop.html" resizeable=""> </IFRAME>
<OBJECT id=ActiveDesktopMover
style="LEFT: 0px; WIDTH: 0px; POSITION: absolute; TOP: 0px; HEIGHT: 0px; container: positioned; zIndex: 5"
classid=clsid:72267F6A-A6F9-11D0-BC94-00C04FB67863><PARAM NAME="Interval" VALUE="500"><PARAM NAME="SizerID" VALUE="ActiveDesktopMover"><PARAM NAME="Enabled" VALUE="True"><PARAM NAME="TargetName" VALUE="DeskMovr"><PARAM NAME="WindowOnly" VALUE="False"></OBJECT>
<OBJECT id=ActiveDesktopMoverW
style="LEFT: 0px; WIDTH: 0px; POSITION: absolute; TOP: 0px; HEIGHT: 0px; container: positioned"
classid=clsid:72267F6A-A6F9-11D0-BC94-00C04FB67863><PARAM NAME="Interval" VALUE="500"><PARAM NAME="SizerID" VALUE="ActiveDesktopMoverW"><PARAM NAME="Enabled" VALUE="True"><PARAM NAME="TargetName" VALUE="DeskMovrW"><PARAM NAME="WindowOnly" VALUE="True"></OBJECT> </BODY></HTML>
mis ma tegema peaksin et desktop jälle normaalseks saada......
ma juba pool ööd üritan siin midagi teha!
EDIT: mingi Active X controlls jama loobib ka ette, näiteks ku runi kirjutan
services.msc ütleb et cannot display properly active x not allowed vms.
misasi se on ja kuidas ära kaotada!?
EDIT2: vahelpeal tahab ta ise desktopi normaalseks visata,aga tuleb jälle se,Active x jama!
_________________ Tapa sionist! |
airm
02.02.2005 09:54:52
| Tekita uus profile, äkki tehakse uus puhas desktop ka(kui see tähtis fail muidugi liiga tähtis polnud).
| Kommentaarid: 56 loe/lisa |
50 |
taipohh
02.02.2005 14:27:37
kui safe modega lähen siis on desktop normaalne, nii minu kasutajaga kui administraatori omaga, probleem veel selline et kaspersky leiab mingi
raterape1_3.dll et mingi keyloger ja se on memorys (winlogon) ja seda ei saa maha kuidagi
proovisin safemodes, ja neti välja lülitades. ikka, ja veel üks fail mis on infected aga maha ei lase kustutada on k4800elmehqa0.dll
pealegi on nüüd mu taskmanager igast imelikke processe täis mida enne ei old.
kui keegi oskab soovitada mingit head tõrjet/hävitajat peale S&D,AdwareSE,Webroot spysweeper,kaspersky....... kõigiga käisin mitmeid kordi üle, aga ikka mingi junn jääb kuhugi pesitsema!
Edit:kas keegi selle Active X controlside kohta siis oskab öelda?
sest pärast restarti paistab ta ütlevat desktopi kohta ka et cannot display properly! your current security settings probhit you using active X and .bla bla bla.....
| Kommentaarid: 765 loe/lisa |
571 |
aatom
20.05.2005 21:51:40
| mis siis selle lahendus oli? mul sama jama, et desktop.html arvutis sees...
6 :: |
57 |
weyx13
