xaxa2
20.01.2005 09:13:56
Electronic Voice Phenomenon (E.V.P) |
"Electronic Voice Phenomenon (EVP) is the appearance of intelligible voices on recording medium that has no known physical explanation. Many of the voices are thought to originate from deceased people. This is the primary reason that people first began experimenting with EVP. Others study EVP to better understand how and why it works, and to improve EVP experimental techniques.
The recording equipment need not be expensive or elaborate to work with EVP. As in any field of interest, some people are better at recording EVP than others. With patience, perseverance and good listening techniques, you should be able to record and hear EVP messages."
Kas keegi proovinud? Suht spooky (kuid reaalne) värk tundub. Seda peaks saama isegi tavalise mikri ning arvutiga salvestada.
Btw, samateemaline film "White Noise" tuli alles 7. jaanuaril välja, peaosas Michael Keaton.(inf. http://www.imdb.com/title/tt0375210/ trailer: http://www.apple.com/trailers/universal/white_noise/ )
Rohkem inffi veel EVP kohta http://www.aaevp.com || Filmi enda lehel (flash leht) on ka väga hea tutoorial EVP salvestamiseks kodus: http://www.whitenoisemovie.com/
Kes julgeb, proovigu järele, ise pole veel raatsinud :p
_________________ dns Project -> http://www.dns-project.com
viimati muutis xaxa2 22.01.2005 09:49:25, muudetud 2 korda |
keytron
20.01.2005 16:14:32
damn, see on küll mega spooky
| Kommentaarid: 58 loe/lisa |
54 |
k2iguvahetaja
20.01.2005 16:31:47
| Ma ei saand mitte mõhkugi aru. Kvikktaimi ka pole. Seletage mulle ka.
| Kommentaarid: 45 loe/lisa |
38 |
xaxa2
20.01.2005 17:28:27
hm, noh EVP on põhimõtteliselt "teispoolsuse" häälte salvestamine helikandjale. Seal http://www.whitenoisemovie.com flash lehel ju seletab ilusti ära mis see on ja kuidas seda teha..
viimati muutis xaxa2 22.01.2005 09:49:50, muudetud 2 korda |
JOKKER666
21.01.2005 00:33:59
kellel on vaikne nurk proovige
aga spooky on küll
| Kommentaarid: 47 loe/lisa |
42 |
UB
21.01.2005 01:05:00
| Peaks ära proovima jah...
39 |
313 |
Oraff
21.01.2005 01:32:11
lähipäevil lähen surnukuuri... seal lindistan(vaikust?) aga proovin!
EDIT: vilm pidi hea olema
| Kommentaarid: 94 loe/lisa |
86 |
21.01.2005 03:01:45
| (S.i.C.) kirjutas: |
| EDIT: vilm pidi hea olema |
kahtlen.. IMDb punktid on küll madalad
313 |
UB
21.01.2005 05:05:30
Näha tahaks sellegipoolest. Ei usalda lihtsalt teiste arvamust.
Häirib see, et aaevp lehel on kõik puha raha eest. Kui keegi leiab enne mind lingi kus on asjast tasuta rohkem juttu, siis andku teada.
Asi on küll naljakate juhtumite all, kuid enam nii naljakas ei tundugi. Eriti öösel kell 5
http://www.electronic-voice-phenomena.net/ ülevaade ja foorum, ainult liikmeks peab regama, raha ei küsita. Esimene lindistus tehti juba 1959 aastal ja mina sain sellest alles nüüd teada
39 |
Scart
101 |
xaxa2
21.01.2005 13:33:27
Hehe, mina ise olen seda filmi näinud. Minuarust oli film vägagi hea, hindaks 8p/10p-st. Ma pakun et enamusele, kes filmile madala hinnangu andsid, ei meeldinud selle lõpp. Nimelt "häppy-end" puudus. Mulle vähemalt meeldis see film väga, päris scary :p
Kui keegi midagi lindistada saab vms, võiks lingi siia kah panna :p
BTW:
Filmi enda lehel ( http://whitenoisemovie.com ) on ju hea tutoorial olemas EVP salvestamiseks ning lehe allpool on ka link "Message Board" kus on suur EVP teemaline foorum.
viimati muutis xaxa2 22.01.2005 09:50:06, muudetud 1 kord |
21.01.2005 14:42:38
xaxa2, see see kõige parem ongi mu arust filmi juures, et pole happy end-i
313 |
xaxa2
21.01.2005 15:11:56
| Skeptik kirjutas: |
xaxa2, see see kõige parem ongi mu arust filmi juures, et pole happy end-i  |
justnimelt :p
viimati muutis xaxa2 22.01.2005 09:50:19, muudetud 1 kord |
Dominus
21.01.2005 23:31:01
eiei...liiga hull...eriti see film vist ...
ysna huvitav...aga mitte öösel
76 |
circles
25.01.2005 01:12:46
ee.. suht spooky oli praegu peale Wolfensteinis katakombides mängimist seda lugeda.
_________________ Võtke õuna! |
| Kommentaarid: 30 loe/lisa |
28 |
xaxa2
arsestar
27.01.2005 14:33:19
| kui kellelgi on videokaamera, siis ma tean yht eriti kahtlast kohta kus pilti tehes energia kogumid peale jäävad. Endal on seal kahtlane tunne tekkinud, et nagu veel keegi oleks kohal aga ei ole, vähemalt samal tasandil (siiamaani ainult pilte teinud energia kogumitest). Aga keegi kellel video kaamera on siis võiks yhendust võtta, ise asun tlnas.
| Kommentaarid: 17 loe/lisa |
14 |
xaxa2
27.01.2005 17:30:32
võiksid kindlasti sellest kohast kirjutada (asukoht?) Btw, äkki oleks võimalik need pildid huvipärast netti lasta?
_________________ dns Project -> http://www.dns-project.com |
sethtanel
27.01.2005 18:41:24
kaamera on ja on ka täis manuaal juhtimist lubav digi.
aga tean ka sellist asja et kuskil tallinnas on koht kus viibides mitmeid tunde hakkab inimene aurat nägema, mõnele inimesele jääb see igaveseks mõnel kaob võime kuu jooksul. / aura on justkui inimese ümber hõljuv värviline udu/ ja inimese viimasel päeval on see värv must.
siin on natuke juttu ka aurast ja mõned pildid.
http://www.hot.ee/aurafoto/kysimused.htm
aga kõige tähtsam
kus on see koht tallinnas või selle lähedal, kust sellise ande endale saaks. teab ehk keegi?
minu tekst oli puhas tõde, et keegi ei hakkaks arvama ja nalja kahtlustama siis panin selle rea kah.
_________________ Rendi mõistlikult. www.realrent.ee |
| Kommentaarid: 174 loe/lisa |
153 |
Dominus
27.01.2005 18:45:20
yeah right... kui ma seda näinud ple siis BS (just my humble opinion) sry for OT
76 |
