paranoid
20.01.2005 01:40:48
ASUS A8N-SLI mobo |
Sobrasin netti ja leidsin sellise imelise asja:
Beestingus(Dr.Peep) A8N-SLI 2090 EEK.
http://www.doctorpeep.ee/index.php?lang=est&main_id=99&id=218760
ja reviewd:
http://www.gamepc.com/labs/view_content.asp?id=a8nsli&page=1&cookie%5Ftest=1
http://www.behardware.com/articles/536/page1.html
Väga kuum kandidaat Upgradeimisel 8)
Supports AMD Socket 939 Athlon 64FX/Athlon 64
- NVIDIA nForce4 SLI
- PCI Express Architecture
- SATA 3Gb/s
- NV RAID
- AI NET2
- NV Firewall
- AI NOS
- AI Audio (8-channel Audio)
The A8N-SLI motherboard is an extreme gaming platform with dual-graphics card and dual-channel memory designs and supports the powerful K8 939 CPU. Play DOOM3 the way it is meant to be played and shatter all records on 3D Mark05. This powerful solution also features top specifications such as SATA 3Gb/s, RAID, 1394, 10 USB connections and 8-channel audio. If top-of-the-line graphics capability is want you need, then the A8N-SLI is your board.
A8N-SLI supports AMD 939-pin Athlon 64 FX/ Athlon 64 processors with 1MB/512KB L2 cache which is based on 64-bit architecture. It features 2000/1600 MT/s HyperTransport Bus and dual-channel un-buffered DDR400 memory support.
NVIDIA nForce4 SLI MCP
NVIDIA® SLItechnology revolutionizes PC performance by combining multiple PCI Express GPUs in a single and scalable system! Gamers and hardcore enthusiasts know that dual GPUs mean increased, supercharged 3D graphics and performance.
PCI Express is the latest I/O interconnect technology that will replace the existing PCI. With a bus bandwidth 4 times higher than that of AGP 8X interface, PCI Express x16 bus performs much better in applications such as 3D gaming. The PCI Express x1 interface creates new usages on desktop PCs e.g., TV tuner, 1394b, and high-speed RAID systems.
SATA 3Gb/s
A8N-SLI supports next-generation SATA hard drives based on the new SATA 3Gb/s storage specification. Furthermore, the chipset has two dedicated SATA controllers delivering more scalable performance and doubles the bus bandwidth for fast hard drive data retrieval and saves.
NV RAID
The nFORCE4 chipset incorporated four Serial ATA and two parallel connectors with high performance RAID functions in RAID 0, RAID 1, RAID 0+1 and JBOD.
AI NET2
Diagnose LAN connection before entering OS! Network problems are often caused by bad cable connection. AI NET2 remotely detects cable connection the second you turn on the system, and any faulty connections are reported back up to 100 meters at 1 meter accuracy.
NV Firewall
NV ActiveArmor enhances network security while delivers the highest system performance by offloading CPU-intensive packet filtering tasks in hardware. NV Firewall provides professional-grade traffic inspection capabilities, instanton protection, advanced management features and is easy to use and setup via a user friendly wizard.
AI NOS
Boost performance when you need it the most!
Applications such as 3D games and video editing demand a huge chunk of system resource.
Inject "nitrous oxide" into your CPU! The patented AI NOS(Non-delay Overclocking System) technology intelligently detects system load and automatically boosts performance for the most demanding tasks. Unlike other dynamic overclocking techniques, AI NOSreacts much faster to satisfy your unending need for speeds.
A8N-SLI has eight channels of audio output with Coaxial and optical S/PDIF connector designed to maximize your auditory experience. AI Audio also provides "Jack Sensing" and "UAJ" functions. "Jack Sensing" automatically detects and notifies user of any inappropriate connection. "UAJ" function enables both input and output functions each jacks, thus eliminates the confusion of Line-in, Line-out and Mic jacks once and for all!
ASUS Q-Fan
ASUS Q-Fan technology intelligently adjusts both CPU fan and chassis fan speeds according to system loading to ensure quiet, cool and efficient operation.
IEEE 1394 interface
IEEE 1394 interface provides high speed digital interface for audio/video appliances such as digital television, digital video camcorders, storage peripherals & other PC portable devices.
Max. 10 USB 2.0 ports supports
USB 2.0 is the latest connectivity standard for next generation components and peripherals.
Backwards compatible with current USB 1.1 peripherals, USB 2.0 delivers transfer speeds up to 40 times faster at 480Mb/s, for easy connectivity and ultra-fast data transfers.
Multi-language BIOS
The multi-language BIOS allows you to select the language of your choice from the available options. The localized BIOS setup menu helps you configure your system easier and faster.
ASUS CrashFree BIOS2
The CrashFree BIOS2 feature now includes the BIOS auto-recovery function in a support CD.
Users can reboot their system through the support CD when a bootable disk is not available,
and go through the simple BIOS auto-recovery process.
ASUS motherboards now enable users to enjoy this protection feature without the need to pay for an optional ROM.
S/PDIF-out on Back I/O Port
This motherboard provides convenient connectivity to external home theater audio systems via an optical or coaxial S/PDIF-out (SONY-PHILIPS Digital Interface) jack. It allows to transfer digital audio without converting to analog format and keeps the best signal quality.
_________________ Powered by: AMD, Gigabyte,ATI, Chieftech, A-DATA, Intel, NEC
viimati muutis paranoid 23.03.2005 18:46:45, muudetud 8 korda |
| Kommentaarid: 22 loe/lisa |
20 |
Wiltz
20.01.2005 01:43:22
jah, eestis seda plaati tõenäoliselt veel üsna pikka aega saada ei ole! aga homme, ülehomme lähen vaatan äkki saan soomest ühe
9 :: |
226 |
paranoid
20.01.2005 01:46:25
Beestingust tellides saaks Soomest.
neil ju kontor seal...
_________________ Powered by: AMD, Gigabyte,ATI, Chieftech, A-DATA, Intel, NEC |
20 |
Wiltz
20.01.2005 03:02:44
jah, eks tee proovi
muide, seda tohutut hunnikut tesksti siia copi peistida ei olnud minumeelest küll suurt mõtet, ma arvan, et igaüks juba teab, mis väärt omadused sel plaadil on!
9 :: |
226 |
vxpsv
20.01.2005 04:58:06
ise oman seda mobo ytlen ni palju sellle mobo kohta et yks paras k2kk ole
markites v6ib küll tulemusi saada
pole veel siiamaani aru saanud kuidas m2lu 500mhz peal jooksma saada 8)
parem ootaks selle DFI mobo 2ra endale juba tellisin selle
http://www.jimmspc-store.fi/index_fi.htm
| Kommentaarid: 4 loe/lisa |
Alpine
20.01.2005 06:00:53
Oot oot mis asja kas nimodi saab et 1PCI-E video sees ainult? Võib peab olema see dual slot video?
| Kommentaarid: 121 loe/lisa |
90 |
Arvo Cobrietti
20.01.2005 09:22:57
| palju sellel mobol volte panna saab? asusele tavapäraselt vist mitte eriti.
| Kommentaarid: 39 loe/lisa |
37 |
k2iguvahetaja
20.01.2005 15:06:07
| Prosele - 1.65v vist, mälule -3v. Mul a8n-sli deluxx tellitud, 28ndal jõuab.
| Kommentaarid: 45 loe/lisa |
38 |
Arvo Cobrietti
20.01.2005 15:21:26
kui see tõele vastab, siis TCCD jaoks normaalne. vcore võiks rohkem olla.
37 |
Auron
20.01.2005 17:03:27
| Alpine kirjutas: |
Oot oot mis asja kas nimodi saab et 1PCI-E video sees ainult? Võib peab olema see dual slot video? |
Saab ka ühe kaardiga.
133 |
paranoid
20.01.2005 17:45:02
| Wiltz kirjutas: |
jah, eks tee proovi
muide, seda tohutut hunnikut tesksti siia copi peistida ei olnud minumeelest küll suurt mõtet, ma arvan, et igaüks juba teab, mis väärt omadused sel plaadil on!  |
kas pole lihtsam kui ülevaade kohe olemas...
Mitte ei pea ise otsima.
20 |
20.01.2005 17:52:24
| paranoid kirjutas: |
| Wiltz kirjutas: |
jah, eks tee proovi
Mitte ei pea ise otsima. |
pand siis lingina vms...
313 |
tnz
20.01.2005 19:10:35
Genneti väitel pidi tulema mingi 27-29 jaanuar neid.
Hädasti oleks üht sellist vaja : P
20.01.2005 20:23:44
| Arvo Cobrietti kirjutas: |
kui see tõele vastab, siis TCCD jaoks normaalne. vcore võiks rohkem olla. |
mnjaa... vcore võiks tõesti olla rohkem, kuid äkki tuleb Wincheseri uus rev. veel "vähem pinget" taluv, nii et ei pruugigi rohkemast kasu olla... vähemalt mul polnud Winchesteriga enam... 1,65-1,75V vahemikus küll pingest tolku...
201 |
Ghost
25.01.2005 22:36:52
keegi teab ehk, kust seda enne järgmist nädalat saada?
ma juba miski kuu aega oodanud. oeh
| Kommentaarid: 18 loe/lisa |
17 |
paranoid
25.01.2005 22:53:49
proovi Beestingusse astuda, äkki neil mõni on...
20 |
Ghost
25.01.2005 23:42:52
| no ei ole
17 |
k2iguvahetaja
26.01.2005 16:43:37
| ATF-is on?
38 |
Ghost
26.01.2005 18:38:21
| veebruaris
17 |
k2iguvahetaja
26.01.2005 21:44:33
| A mis kammajaa on selle SLi-ga, probleemne pidi olema...
38 |
Ghost
26.01.2005 23:54:15
eh, ei tea..pole kuulnud midagi halba selle kohta küll.
peale selle, et nVidia paneb mingi SLI maksu peale süsteemi ehitajatele, kes SLI süsteemi kasutavad
17 |
razor
27.01.2005 12:46:10
| Ghost kirjutas: |
peale selle, et nVidia paneb mingi SLI maksu peale süsteemi ehitajatele, kes SLI süsteemi kasutavad  |
see pigem komplekteerijatele mitte tavakasutajatele ja seegi siiamaani ainult spekulatsioon
120 |
k2iguvahetaja
27.01.2005 15:26:58
  Eriti irw. SLi maks.
38 |
paranoid
27.01.2005 18:24:11
| k2iguvahetaja kirjutas: |
  Eriti irw. SLi maks. |
Mis pohjendusega?
Vaja kuidagi mottetult raha riisuda???
20 |
Ghost
28.01.2005 12:00:01
nii, kuna mul enda oma käes, siis ütlen nüüd ka teile: K saluunis on deluxe versiooni laos!
prose mul puudu ainult nüüd :s
17 |
paranoid
28.01.2005 14:11:14
| Ghost kirjutas: |
prose mul puudu ainult nüüd :s |
parast kriba elamused!!!
20 |
Ghost
28.01.2005 16:19:49
ojah, tegelt oli seal neil 3 seda proset, mis ma tahtsin (3000+), aga nende kohta öeldi "need on tootmisele kinni pandud, tulge esmaspäeval"
no aitäh küll, aga kui raske on seda tootmisele esmaspäeval saata tänase asemel.
oeh
17 |
k2iguvahetaja
28.01.2005 17:21:16
Ma tellin tna k-st prose ja mobo ära. Kui garantiisse vaja sii on
38 |
28.01.2005 20:16:38
seal peaks vist isegi laos olema
201 |
angel
28.01.2005 21:09:58
endal sama plaati vaja (varste juba kuu aega ootan seda) aga ei tea kas sealt K-st riskib osta. Seal pidevalt garantiiga probleeme
Keegi juhuslikult ei tea, ehk mõni teine pood kah seda pakub juba?
Oleks A8N-SLI või sellest Delux versioonist huvitatud
157 |
k2iguvahetaja
28.01.2005 21:17:33
Mul doctorpeebust tellitud, noh katkestasin. Seal on kohalejõudmise ajaks 14. veebruar.
Tegelt k ei tooda ju plaate, kui saad töötava siis ilmselt enam asja sinna pole, tegu siiski Asusega mitte DFI-ga. Kui vigase saad siis 14 päeva on tagastamisvõimalus vms.
38 |
Ghost
28.01.2005 22:26:40
| angel kirjutas: |
endal sama plaati vaja (varste juba kuu aega ootan seda) aga ei tea kas sealt K-st riksib osta. Seal pidevalt garantiiga probleeme
Keegi juhuslikult ei tea ehk mõni teine pood kah seda pakub juba?
Oleks A8N-SLI või sellest Delux verioonist huvitatud |
no mina sain kinnise avamata karbi. Ma ei usu, et see erineb nendest, mis teised pakuvad.
Ja kätte saab kohe (esimesed kiired)
17 |
28.01.2005 22:34:17
Kui vigase saad siis 14 päeva on tagastamisvõimalus vms.  |
enam pole seda seadust
201 |
angel
28.01.2005 22:40:31
| Ghost kirjutas: |
| angel kirjutas: |
Ja kätte saab kohe (esimesed kiired) |
Aga ega keegi juhuslikult ei oma infi kus kohast K neid sisse toob ?
hm eisemsed kiired... peab siis kell 10.00 k ukse taha kraapima minema
157 |
k2iguvahetaja
30.01.2005 11:51:29
| K-s pole vist hetkel ei mobot ega ka proset (a64 3000+), kust mujalt neid saada oleks võimalik?
38 |
angel
30.01.2005 12:45:51
| K-s pole vist hetkel ei mobot ega ka proset (a64 3000+), kust mujalt neid saada oleks võimalik? |
Kas mitte ordi ei paku seda proset ?
157 |
M!nA
30.01.2005 12:55:42
vot sellise võtaks küll ligi.........hind ka suht talutav
ei tea kas on võimalik sellel platel jooksutada ka ainult ühte PCIe kaarti
_________________ TEL.:56477545 |
110 |
angel
30.01.2005 13:03:40
| M!nA kirjutas: |
ei tea kas on võimalik sellel platel jooksutada ka ainult ühte PCIe kaarti  |
Jah on kül võimalik .Seega kui tulevikus võimu juurde tahta võid vabalt nt 6600 GT ühe juurde osta (aga peab olema täpselt sama kaart kuna muidu on võimalus et asi ei tööta lihtsalt)
157 |
Ghost
30.01.2005 14:00:51
ordis on 3000+ vähe kirvehinnaga..
ja mitte ainult ei ole võimalus, et ei tööta SLI erinevatega, vaid täiesti kindlalt ei tööta.
17 |
angel
30.01.2005 14:04:33
| Ghost kirjutas: |
ja mitte ainult ei ole võimalus, et ei tööta SLI erinevatega, vaid täiesti kindlalt ei tööta. |
Silmas pidasin SLI puhul et nt Club-3d kaardi karbil on kirjas et kaardid peavad SLI jaoks olema identsed s.t sama toote koodiga.
Kui ordis ilusti küsida oskad siis saab hea hinnaga
157 |
tnz
30.01.2005 17:24:12
Loll küsimus, aga kas asi töötab ikka ühe PCIX videoga ka?
Ning kas Deluxil ja tavalisel on suur vahe?
Ghost
17 |
paranoid
30.01.2005 17:53:34
Deluxe on dual Gbit LANiga
20 |
angel
30.01.2005 17:55:52
| Deluxe on dual Gbit LANiga |
kas sa võiks selle täpsemalt lahti seletada, mis kasu sellest võiks saada ning mis oleks asja täpsem otstarve.
157 |
paranoid
30.01.2005 18:08:58
| angel kirjutas: |
kas sa võiks selle täpsemalt lahti seletada, mis kasu sellest võiks saada ning mis oleks asja täpsem otstarve. |
MIS MÕTTES
20 |
angel
30.01.2005 18:45:57
| angel kirjutas: |
MIS MÕTTES  |
no olen loll ja vot ei tea LAN jms stuffist eriti midagi. (lan= local area network seda isegi tean )
ärge pange tähele kuna ajud juba soojad selle emaplaati ootamisest
157 |
Denke
30.01.2005 19:15:59
| angel kirjutas: |
Saad näiteks netti jagada
Jaan
31.01.2005 16:24:30
Tulin just mustamäe tee k-arvuti-st, kus oli se plate letis, ja müüja väitis, et ca 10tk neid veel laos.
3200+ peaks kah seal olema.
124 |
k2iguvahetaja
31.01.2005 16:30:03
| Ma enam ei tahagi seda. Ma saan vist MSI K8N-SLi platinumi. Prose ostan vist ordist, a kui keegi teab kust odavamalt saab andke teada.
38 |
Auron
31.01.2005 17:17:42
Noh millal siis 2x6800GT'de ja ultratega skoore oodata on?
133 |
