Green_Day
22.12.2004 18:14:23
Ilus katse krediitkaardi andmeid kätte saada |
Hoiatus! Nimetatud leheküljelt (peale nn logimist) üritatakse arvutisse trooja hobune sokutada. (hoiatus lisatud Raiku poolt)
Tuli selline kiri aadressilt: accountmodification@www.ebay-it.com
You have been sent this notice because the records of eBay database indicate you are a current or former eBay account holder. eBay is conducting a periodic update of the database record. To ensure your account's security, it is important that you provide us accurate information. Please take a moment to verify the information we have on file. This notice provides instructions on how to confirm your eBay account.
2. What should I do now?
We sincerely ask you, as a eBay account holder, to login to your account and give us the necessary information. Complete the necessary verification tasks within 5 days, or your account might get temporarily suspended. Proceed with the link below.
Click here to confirm your account
We apologize for your inconvenience.
Copyright c 1995-2004 eBay Inc. All Rights Reserved. Designated trademarks and brands are the property of their respective owners. Use of this Web site constitutes acceptance of the eBay User Agreement and Privacy Policy.
Kirjas viide: http://www.cmnnet.com.br/webmail/.ebay/Login.htm
Kontrolliks "logisin" sisse suvalise mitteolemasoleva kasutajanimega. Mingit wrong username vms ei öelnud... Suunati kohe krediitkaardi andmete sisestamise kohta.
Kommentaarid: 7 loe/lisa |
Raiku
23.12.2004 10:22:43
Lisaks ka veel pisikese täpsustuse, et nimetatud leheküljelt (peale nn logimist) üritatakse arvutisse ka trooja hobune sokutada.
_________________ Честных психов можно не лечить... |
Kommentaarid: 58 loe/lisa |
45 |
.Scorps.
23.12.2004 19:38:32
Mul Norton peal, aga karjuma ei hakanud. Loodan, et midagi lahti pole...
_________________ Tere hommikust!  |
Kommentaarid: 265 loe/lisa |
221 |
DeathCommando
23.12.2004 19:52:58
ml f-secure ja ka karjuma ei hakand.. a vb mingi IE kaudu levivv trojan on(ise opera kasutaja)
_________________ Nothing's eternal...
Vajad mõnda PHP/SQL rakendust? või hoopis tervet webi?
Võta ühendust.. |
Kommentaarid: 15 loe/lisa |
.Scorps.
23.12.2004 21:47:18
Ma kasutasin IE-d. Kas nüüd on siis trooja sees? Jõuluraiku, ehk annaksid mingit infot ka, mis troojaga täpsemalt tegu oli? Millegipärast mulle tundub, et mu arvuti on peale seda muutunud lollimaks, kui enne, hakanud rohkem kinni jooksma jne...
Aga skännimised Nortoni, Ad-Aware ja Spybotiga ei näidanud midagi. Samamoodi ei näidanud midagi kahtlast ka Anti-Spy 1.6c, mis on midagi Task Manageri sarnast (mul pole isegi task manageri, kuna arvutis pesitseb viirus nimega win98se, mis tuleb põlema panna), aga hindab ka iga töötava programmi ohtlikkust. Kõige ohtlikum töötavatest progedest oli tema jaoks MSN Plus (potentially dangerous).
221 |
artur-
24.12.2004 03:41:39
.Scorps. kirjutas: |
Aga skännimised Nortoni, Ad-Aware ja Spybotiga ei näidanud midagi. Samamoodi ei näidanud midagi kahtlast ka Anti-Spy 1.6c, mis on midagi Task Manageri sarnast (mul pole isegi task manageri, kuna arvutis pesitseb viirus nimega win98se, mis tuleb põlema panna), aga hindab ka iga töötava programmi ohtlikkust. Kõige ohtlikum töötavatest progedest oli tema jaoks MSN Plus (potentially dangerous). |
Ma ei ole just jõuluraiku aga selle trooja nimi on Trojan.JS.Steal, Kaspersky võttis selle asja vabalt kinni 8)
Kommentaarid: 80 loe/lisa |
Raiku
24.12.2004 09:09:38
artur- kirjutas: |
Ma ei ole just jõuluraiku aga selle trooja nimi on Trojan.JS.Steal, Kaspersky võttis selle asja vabalt kinni 8) |
McAfee samuti.... kusjuures kasutasin Firefoxi.
45 |
erkinem
24.12.2004 09:17:22
Mul ka Kaspersky peal ja sai looma kätte.
Kommentaarid: 329 loe/lisa |
284 |
UB
24.12.2004 09:28:24
Katestasin oma viirusetõrjet ka, F-secure sai selle ilusti kätte ja nimetas ümber
Kommentaarid: 45 loe/lisa |
39 |
k2iguvahetaja
24.12.2004 10:36:05
Mu nod32 ei teinud muffigi. Äkki trooja sees nüüd.
38 |
UB
24.12.2004 21:58:00
Kindlasti on. Ma avastasin hiljem ta veel olevat peitunud ühtede mängufailide vahele. Kiire tegelane saatanas. Kuigi viirusetõre andis temast märku ja sai ka jagu, ikkagi jõudis arvutisse pugeda
39 |
k2iguvahetaja
24.12.2004 22:03:31
Kus asub täpsemalt? Ja kas ainult Internet exploreriga tuleb? Ma kasutan firefoxi.
/edit: skännisin housecalliga läbi, ei leidnud midagi.
38 |
D3vil.ee
25.12.2004 14:15:12
Arvan, et see link tuleks ära koristada, või hoiatus vähemalt panna.
Kommentaarid: 41 loe/lisa |
38 |
svenman
29.12.2004 12:50:35
k2iguvahetaja kirjutas: |
Mu nod32 ei teinud muffigi. Äkki trooja sees nüüd. |
Kasutasin ka enne rõõmsalt nod-i, kuni jutukas hakkas keegi paukuma, et tee oma arvuti viirustest puhtax. Sai siis f-secure peale pandud ja ennäe 10 troojat, üks nendest istus kuskil mirc scripti failide seas. üks viirusetõrje nüüd jälle juures, mida usaldada ei saa
71 |
neros
29.12.2004 13:13:16
Proovi pigem kasperskyt, tundub et NOD-i ustavus hakkab langema...
_________________ GitHub
.NET Core & Azure baasil lahendused ja arhitektuur - kontakt. |
Kommentaarid: 48 loe/lisa |
40 |
Metsjeesus
29.12.2004 23:29:38
Keegi saaks anda usaldusväärsete viirusekaitsete kohta lingi? St. kas trialiga või siis tasuta
ise olen kasutanud AVG peamiselt ja ka NOD, Nortoni jätsin ammu maha kuna ei olnd ta kuskilt otsast palju etem ja lisaks lasi mälu mõnuga (oli 256 siis).
_________________ Füsioteraapia alane hindamine & nõu ¤ treeningfilosoofia & toitumine ¤ kaela- ja õlavöötme lihaspingete leevendamine |
Kommentaarid: 108 loe/lisa |
94 |
