KENWOOD
29.11.2004 22:06:43
NTLDR is missing !!HELP!! |
siuke värk tuli ette peale restart
NRLDR is missing
Press Crtl+Alt+Del is restart
arvatav jama on kõvaketas olen proovind cmos ja ainuke asi on see mida pole teind veel aken lahti ja minekut
kõvaketas ise on suht uus vana umbes 2kuud, üle formatida ei lase ka lasta kogu aeg sama värk tuleb ette mis kamm on
80GB Hitachi 7K250 et see täpne mark kurat kas tõest anndis otsad
ei viitsi praegu teist kõvakat välja tirida et proovida kas ikka kõvaketta süü
99 |
.phonkyp.
29.11.2004 22:46:47
Vaata siia.
_________________ Ärge uskuge, mida teised teile räägivad. |
| Kommentaarid: 11 loe/lisa |
9 |
KENWOOD
29.11.2004 23:47:58
kurat ei oska teha seda kas garantii ajaks selle korda 8)
99 |
dr.Jobelbaum
29.11.2004 23:52:35
Mis nimelt selles jutus arusaamatuks jäi ?
If your computer is using Microsoft Windows 2000 and you are encountering the NTLDR error. Create the below boot.ini file on the floppy diskette drive.
[boot loader]
timeout=30
default=multi(0)disk(0)rdisk(0)partition(1)\WINNT
[operating systems]
multi(0)disk(0)rdisk(0)partition(1)\WINNT="Microsoft Windows 2000 Professional" /fastdetect
Copy the NTLDR and NTDETECT.COM files from another computer using the same Operating System. Both of these files are located in the root directory of the primary hard disk drive. For example C:\NTLDR and C:\NTDETECT.COM should be the locations of these files on many computers.
Please keep in mind that these files are hidden system files, if you need additional help with viewing hidden files in Windows please see document CH000516.
Once these files have been copied to a floppy diskette reboot the computer and copy the NTLDR and NTDETECT.COM files to the root directory of the primary hard disk drive. Below is an example of what commonly should be performed from the A:\> drive.
copy ntldr c:
copy ntdetect.com c:
After the above two files have been copied, remove the floppy diskette and reboot the computer.
Windows XP users
Insert the Windows XP bootable CD into the computer.
When prompted to press any key to boot from the CD, press any key.
Once in the Windows XP setup menu press the "R" key to repair Windows.
Log into your Windows installation by pressing the "1" key and pressing enter.
You will then be prompted for your administrator password, enter that password.
Copy the below two files to the root directory of the primary hard disk. In the below example we are copying these files from the CD-ROM drive letter "E". This letter may be different on your computer.
copy e:\i386\ntldr c:\
copy ntdetect.com c:\
Once both of these files have been successfully copied, remove the CD from the computer and reboot.
suht arusaadav eks ? Lihtne pealegi ... 8)
.phonkyp.
29.11.2004 23:52:59
Cause:
1. Computer is booting from a non-bootable source.
2. Computer hard disk drive is not properly setup in BIOS.
3. Corrupt NTLDR and/or NTDETECT.COM file.
4. Misconfiguration with the boot.ini file.
5. Attempting to upgrade from a Windows 95, 98, or ME computer that is using FAT32.
6. New hard disk drive being added.
7. Corrupt boot sector / master boot record.
8. Seriously corrupted version of Windows 2000 or Windows XP.
9. Loose or Faulty IDE/EIDE hard disk drive cable.
Siit on näha, et kui sa ise winniga suranud, biosis möllanud, faile kustutanud (ega sa enne näiteks adawaret või spyboti ei jooksutanud) jne pole, siis võib viga olla näiteks lahtine või vigane IDE kaabel, äkki panid mingisuguse teise HDD järgi, ning süsteem üritab selle pealt bootida jnejne
9 |
dr.Jobelbaum
29.11.2004 23:54:34
Kaks õlut ja olen nõus eelneva teksti paanema maakeelde, tegema puust ja värvima punaseks.
.phonkyp.
29.11.2004 23:56:56
Muig.
9 |
KENWOOD
29.11.2004 23:58:15
| dr.Jobelbaum kirjutas: |
Kaks õlut ja olen nõus eelneva teksti paanema maakeelde, tegema puust ja värvima punaseks.  |
ei tea kas cargoka tasub tegeleda et õlut saata sulle
99 |
Elof
30.11.2004 00:53:25
Enne seda kui hakata asja parandama on soovitav kindlaks teha - mis asja põhjustas.
Uuri ketta sisu mõnes teises arvutis kui ise kindel, et näiteks kaabelduse viga pole
175 |
KENWOOD
01.12.2004 15:48:16
| TanElofJ kirjutas: |
Uuri ketta sisu mõnes teises arvutis kui ise kindel, et näiteks kaabelduse viga pole |
ma arvan et viga on faili kustutamises sest väike vend surkis enda arvates arvutit ja arvas et seda faili ei ole vaja aga ei ole kindel mida tegi seal ta ise ei jaga eriti matsu
99 |
svenman
01.12.2004 16:34:58
Kusjuures käisin just eile sellise arvutiga maadlemas, millel ka NTLDR missing. Tüüp ise väitis et ei näppinud midagi ja lambist shut down ajal viskas sellise kirja. Sain asja küll korda, aga krt küsimus jääb ikka rippuma. Samas üks teine tuttav oli mingit programmi win2000(ei mäleta enam mis proge oli) installind ja poole pealt oli pange pannud. Peale resa sama probleem. Krt seda siis teab
| Kommentaarid: 80 loe/lisa |
71 |
XYZ
01.12.2004 16:49:37
| svenman kirjutas: |
Kusjuures käisin just eile sellise arvutiga maadlemas, millel ka NTLDR missing. Tüüp ise väitis et ei näppinud midagi ja lambist shut down ajal viskas sellise kirja. Sain asja küll korda, aga krt küsimus jääb ikka rippuma. Samas üks teine tuttav oli mingit programmi win2000(ei mäleta enam mis proge oli) installind ja poole pealt oli pange pannud. Peale resa sama probleem. Krt seda siis teab  |
Mis siin teada, loe eespoolt, kus on nimekiri võimalikest põhjustest/apsakatest, millega bootimist ära rikkuda... tulemus lihtsalt, s.t. veateade, jääb samaks ja peab ise tegeliku algpõhjuse välja selgitama.
| Kommentaarid: 81 loe/lisa |
12 :: |
56 |
KENWOOD
01.12.2004 17:17:27
käisin proovisni juhtemd üled cmod ka ikka sama jama kuidas sa sevnman selle korda said
99 |
svenman
71 |
KENWOOD
01.12.2004 21:02:08
lehndus olemas format mis juba tehtud confisin win ka ära nüüd asi tunduvalt kiirem
99 |
