praegune kellaaeg 25.10.2026 00:26:32
bigbossu16
19.10.2004 12:11:27
lexpps |
Probleem selline, et installisin mängu, kuid kui tahtsin mängu sisse minna, siis lõi arvuti restarti, noh mõtlesin, et probleem mingisuguse Open Glidega, sest selle mängu demo oli ka open glidega välja löönud. Mõtlesin, et panen siis 3D peale graafika. aga enda kontole sisse minnes tõmmas arvuti nii aeglaskes, et my computer kausta avamine võttis 2-3 minutit aega. Järsku lõi ette win xp sp2 tulemüüri hoiatus, kus seisis, et tulemüür on takistanud faili lexpps neti ühenduse või midagi sarnast . 10 minutit panin siis enda kontot log offi . Tegin restarti ja läksin teise konto peale, mis ka adminitrator. Seal oli kõik korras aga ette tuli sama lexpps hoiatus. Arvasin, et tegemist mingisuguse tõsise viirusega, sest prose kasutus oli esimese konto peal kogu aeg 100%. Teise konto peal sain korralikult neti ja uurisin, et lexpps on lexmark prinetrite draiverite jne fail.
Aga seal seisis veel ka nii:
lexpps.exe explanation:
This file is a part of drivers for printers, published by Lexmark International company. It is used in the network to access the printer from the remote computers. This process can cause system errors, but if you use the printer in the network, you have to keep this process running. Such functionality is useful in corporative networks, offices and in small networks. However, even if your computer is not connected to such network or you do not want to share your printer, lexpps.exe process runs by default on every system startup. Sometimes it causes problems and system errors, under some environments it runs itself as a server application and may cause system's instability. In such cases and if you don't want to share your printer, it is recommended to disable lexpps.exe process and prevent it from starting automatically. Lexmark printers work fine without lexpps.exe loaded into memory.
Special info about lexpps.exe:
By our records File lexpps.exe is not harmful to the computer system. But this filename can be used by dangerous spyware and adware programs to mislead the user.
Dedicated 2-files portal advices to scan your computer and terminate all the files and processes that are related to spyware.
Kui keegi oskab midagi pakkuda, esiteks tõmman adaware se ja NOD 32 üle siis vaatan edasi.
| Kommentaarid: 6 loe/lisa |
bigbossu16
19.10.2004 12:14:14
siin on kirjas et eemaldada saab mingi win task 5 proga, aga paistab, et see on tasuline
EDIT: Adaware leidis 40 ühikut aga üksi polnud väga ohtlik. aga NOD32 ei suutnud millegi pärast ~100 faili kontrollida. Kõik need failid algasid NTUninstallKB837001, kas need pole mitte win xp turvaparandused .
Kui keegi oskab aidata, siis oleksin väga tänulik
TzigaLind
19.10.2004 15:03:14
Kui ei kasuta, tuleks ära keelata mikisofti file/print sharing tcp/ip propertaz alt.Samuti vaadata kas on võimalik seda lexmargi võrguprintimise servicet kuidagi kinni keerata(head kohad uurimiseks oleksid *msconfig;services.msc)
NTUnunstallKBxxxxx on windowsi paranduste uninstall failid.Miks ei oska NOD32 neid lahti pakkida?
_________________ Piix! |
| Kommentaarid: 16 loe/lisa |
14 |
t-force
19.10.2004 16:20:41
win tasks -iga saab protsessi blokkida aga seda see ei eemalda
proovi kas spyhunter leiab midagi
| Kommentaarid: 27 loe/lisa |
22 |
bigbossu16
19.10.2004 17:33:33
Asi vast korras ei ole aga kontos liikumine on jälle nagu headel päevadel.
Printerit kasutan küll. Aga mind huvitab ka see, miks ütleb NOD32, et NTUnistallKB ei saa avada, esiteks ma ei ole Windowsi turvaparandusi unistallinud ja siis ütleb, NOD 32 et ei saa ka pagefile alt 4 ühikut avada.
Võibolla on viga selles, et uued kontod tegin alles hiljuti, ning nende kontode alla võib jääda mulje nagu poleks turvaparandusi installinudki, ei tea tõesti.
Spyhunter on ikka tasuta 30 päevase limiidiga, sest ostma küll ei hakkaks?
TzigaLind
19.10.2004 17:59:45
Kas sa kasutad printerit läbi võrgu?
Kas oled otsinud/proovinud uuemaid drivereid?
14 |
t-force
19.10.2004 18:48:06
| bigbossu16 kirjutas: |
Spyhunter on ikka tasuta 30 päevase limiidiga, sest ostma küll ei hakkaks? |
spyhunteril on mingisugune trial et näitab mis on arvutis aga midagi nedega teha ei saa. Kui näed millega tegu saad otsida nede vastu midagi tasuta... proovida tasub
22 |
bigbossu16
19.10.2004 19:44:08
| TzigaLind kirjutas: |
Kas oled otsinud/proovinud uuemaid drivereid? |
Tegelikult tõmman kõik wordi ja prindin seal
EDIT: draivereid just kontrollisin, kõik olid juba updatitud
Spyhunter leidis mingisuguse Kontiki registry ja ütles, et see on väga ohtlik, muuda midagi ei peale cookide ei leidnud
Nüüd proovisin aga spyware doctorit ja olen selles positiivselt üllatunud, leidis ligi 80 ühikut, tunduvalt rohkem, kui Adaware se, ning tal on ka palju rohkem võimalusi aga lexppsi ei suutnud ka tema avastada .
